Rust-O-Leum paint on bedliner on my CT-13 - Fiberglass RV
Old 08-10-2011, 02:47 PM   #1
Trailer: Uhaul CT-13
Ohio
Finally decided to cover up the rock chips on the bottom front of my CT-13. I used the Rust-O-Leum paint on bedliner, used 1 quart which was enough for 3 coats on the area shown. Cleaned the area with alcohol, sanded with fine 220 grit and then wiped with alcohol again. Masked off areas and used a small foam roller to apply it, went on very easy like regular paint. Here are pics after the second coat. I'll post pics of the finished product later tonight.
Panoz77 is offline   Reply With Quote
Old 08-10-2011, 03:37 PM   #2
Ohio
Three coats total with enough left over for future touch ups if needed. Finished pics, it now baking in the afternoon sun and breeze.
Old 08-10-2011, 03:43 PM   #3
Trailer: gave up!!
I think it came out great James. Good job!
John_M is offline   Reply With Quote
Old 08-10-2011, 06:22 PM   #4
Looks very nice James!
Old 08-10-2011, 08:07 PM   #5
Brian E Moon's Avatar
Trailer: 72 Boler 13'
Nice job! Good to know how much did the job.
Thanks.
Brian E Moon is offline   Reply With Quote
Old 08-10-2011, 08:33 PM   #6
Ohio
Yes, no need to buy a full gallon unless you are doing a larger area. A word, use the smaller foam rollers not regular sized rollers with the deep napp or you will soak up a whole lot of wasted bedliner. Also use the smaller trays not the big ones. Got the supplies for like $5.00 at walmart. The roller I used was similar to this, I think it said for cabinets and trim.
Amazon.com: FoamPro 4" Mini Trimmer, Paint Roller: Home Improvement
Old 08-10-2011, 10:53 PM   #7
Paul Chet's Avatar
Trailer: Vixen Motor Coach
really nice!
considering this exact job to my Play Pac. after 37 years, its had its fair share of nicks and dings - some right through to the glass.
looks great! thanks for sharing.
Paul Chet is offline   Reply With Quote
Old 08-10-2011, 10:56 PM   #8
Vickie B.'s Avatar
Trailer: 1988 Perris Pacer ('Bean') / 2015 Ford F-150, 2017 Winnebago UltraLite 27BHSS
Nebraska
I'm impressed! You made it look not so scary!
Vickie B. is offline   Reply With Quote
Old 08-10-2011, 11:01 PM   #9
Ohio
If you can paint a wall you can do this. Another tip is to wear rubber gloves, this stuff is hard to get off your hands. Also, make sure you tape well.
The hardest part of doing this is taping off the radius, especially on rounded trailers. I didn't measure and had to eye everything because the reference points on each side are different, the hardest part was trying to make sure the curves looked the same and terminated at about the same spot on each side.
Old 08-10-2011, 11:11 PM   #10
Vickie B.'s Avatar
Nebraska
James, you read my mind as I was wondering "how'd he tape that off so nicely?!"
Old 08-11-2011, 12:13 AM   #11
Ohio
I have a pretty good eye and a very steady hand, LOL
Old 08-14-2011, 08:44 AM   #12
theresa p's Avatar
New Brunswick
LOOKS FABULOUS!!! thanks for all the hints and advice....now, off to the paint store.
Old 08-14-2011, 10:03 AM   #13
Used it on the inside floor of my VW Thing and it is tough as nales when dry.
Old 08-14-2011, 10:30 AM   #14
jen b's Avatar
Trailer: 1980 13 ft. burro
Nicely done!
I want to do something like this to my Burro when my dad and I do its makeover this winter. I am sad that there are so few colors to choose from, though. I want something in brown and can't find a product that offers much more than black/red/gray.
jen b is offline   Reply With Quote
paint
Has anyone tried spray on bedliner inside? Gumpit Modifications, Alterations and Updates 22 04-20-2017 01:31 PM
Truck bedliner spray on outside of a trillium? rhettelliot Care and Feeding of Molded Fiberglass Trailers 3 09-11-2010 03:44 PM
Truck bedliner spray on outside of a trillium? rhettelliot Care and Feeding of Molded Fiberglass Trailers 4 09-08-2010 08:25 PM
To sand and paint, to paint, or to leave it be...these are the questio JenPB Care and Feeding of Molded Fiberglass Trailers 8 12-07-2008 10:39 AM
Rust Legacy Posts Care and Feeding of Molded Fiberglass Trailers 6 02-27-2003 06:36 PM
