I have been planning to install a stereo system in my
Escape 19 for some time and originally experimented with a dual-DIN auto CD/DVD player, but I didn't like much about it. It ran warm, the touchscreen was fiddly and the remote was cheap. The amplifier was pretty good, but I could cook an egg on the back of the unit. I wound up taking it back.
Looking at some of the RV electronics available online, I saw one of the Concertone RV
Genesis GT-3.0 DVD radios on eBay a couple weeks ago. It was missing the remote and plug-in connectors and was supposed to have a problem playing discs, which was okay with me as I mainly wanted the Bluetooth, radio and 5.1 audio decoder. The amplifier also supports two additional stereo output channels, one I will use outdoors and one in the dinette area.
The auction closed at just $20 plus $25 shipping. I was able to find the connectors for $14 and a remote for $11. To my surprise, when the radio arrived last week everything worked including the DVD/CD player.!Now I had to find room for mounting, and the only likely spot in my 2009
Escape 19 that is tall enough is the rear overhead cabinet, shoehorned between the two access doors.
Currently, that spot is occupied by the Carbon monoxide sensor, but that's small enough to relocate, and I can steal its 12V power right there!
I picked up one of those weird square Canadian screwdrivers at Harbor Freight and pulled the CO monitor. Then I did a bit of measuring and confirmed that I could just squeeze the panel between the existing cabinet doors with a 3/8 inch clearance from the doors, but the top and bottom clearances would require a 1/2 inch bite into the lower brace inside the cabinet, and 1" bite into the upper brace.
Masking tape was used to mark the required cutout and the bulk of the sawing was done with a multi tool and half moon sawblade. I cut about 1/8 inch oversize, and just a tiny cleanup cut was required in the left top corner to square things up. The radio slid right into place and is powered using the former CO Monitor DC power.
The next step will be to install the 5.1 speakers. I am planning to use five Yamaha NS-AW-150W indoor/outdoor speakers under the cabinets ($200 for six, new) and possibly a Kicker 8-inch powered subwoofer (about $300 new).
