Scamp 13 slight lift - Fiberglass RV
Old 07-17-2013, 08:03 PM   #1
Trailer: 2014 Escape 21
Virginia
I wanted to slightly raise a 2005 Scamp 13 for a little more axle and plumbing clearance. The original axle was not worn completely out and the brakes appeared not to have been used at all. I ordered a blank axle and reused my bearings and brakes. The specs. were the same as the original but I went with a 0 degree axle instead of a 22.5 up angle axle. The axle cost about $225. picked up from the distributor.
The specs said I should get a 2" lift but with the wear on the original axle I actually gained about 2.5". The mod. worked out really well for me. I could have gone with a steeper angle axle but it would have raised the hitch and door threshold too much. I just thought I would pass on the information.
Eddie
Old 07-17-2013, 09:00 PM   #2
Roy in TO's Avatar
Originally Posted by Eddie Longest View Post
reused my bearings
Why?
Other than saving a few $$?
Old 07-18-2013, 09:14 AM   #3
Virginia
Roy
The old hubs and brakes were like new and the trailer seems to have had very little use. I cleaned, inspected and repacked the bearings and hubs and matched the bearings to their old race. There was no pitting and the surfaces looked like great. No more than a normal repack. The only issue was finding double lip seals for the #9 EZ lube axle.
Eddie
Old 07-18-2013, 10:44 AM   #4
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Roy
Eddie
Nuthin' wrong with reusing good bearings. If properly lubed they will last just about forever.
Old 07-18-2013, 11:21 AM   #5
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Originally Posted by Roy in TO View Post
Why?
Why not? They'll go for several hundred thousand miles, if cared for. We had a lot of vehicles over 200k, up to 400k, think they all had original bearings.
Old 07-18-2013, 11:43 AM   #6
Roy in TO's Avatar
OK, I understand now. I was taught to replace the small stuff that wears out when replacing the big stuff.
Old 07-18-2013, 11:54 AM   #7
Jared J's Avatar
Kansas
The only time I've had to replace trailer bearings was because the seal failed and let water in. I do not reuse dust seals, ever. I know some people do, but the a rubber wear part, and new ones are cheap prevention, IMHO.
I also don't believe in ez lube axles, or lacking them by pushing old grease out with new. Remove all grease, clean in solvent tank, spray with brake clean to remove any solvent that could harm new grease, then repack.
Old 07-18-2013, 04:06 PM   #8
IllAnnoy
They're real , trust me!(and they work great!)
You are right about one thing, grease seals are cheap, I paid big money for some new "brand name" seals which were barely worth installing. I can't find any with a flange, for a straight spindle axle.
Old 07-18-2013, 09:25 PM   #9
Jared J's Avatar
Kansas
Oh, I have an ez lube axle, but it'll never see a grease gun.
Old 07-31-2013, 04:36 PM   #10
Trailer: '79 Boler 1700RGH
You're argument is similar to the argument between synthetic oil vs natural dino oil - people say you can run synthetic longer but the cost is higher..
The argument the other way is that it's better to change your oil four times regardless of the oil 'quality' than it is to have a better oil you change less frequently.
You aren't going to re-pack your bearings every time you go out or probably not even every season. If you do you are a nutter or you go Bolering too much (not possible)
On the other side of the coin, it's easy to grab your grease gun and give your axles a shot every couple of trips and even though it's not the ABSOLUTE BEST POSSIBLE THING for your bearings, it is a lightyear away from the worst.
Boleroleroleroleroleroleroler
Kinslayer is offline   Reply With Quote
Old 07-31-2013, 05:19 PM   #11
Jared J's Avatar
Kansas
I clean and repack my bearings on my trailers the first time they're used every year. It's quick (only takes 15 minutes or so per wheel), I know the condition of my bearings/seals/brakes, and there's no risk of pushing grease into my brakes.
Each to their own, that grease zerk will never be touched on mine.
Old 08-04-2013, 05:56 PM   #12
bearing buddies are a great help in maintaining steady grease to the bearings
mike g is offline   Reply With Quote
Old 08-04-2013, 06:11 PM   #13
Hi Mike, to FiberglassRV, we're glad you're here
Bearing buddies are designed for boat trailers, it keeps the water out of the bearings. I don't advocate bearing buddies on axles for travel trailers... I'm sure others will offer their opinions as well.
However, my Scamp does have an EZ lube axle, which is VERY different than Bearing Buddies.
Old 08-04-2013, 06:15 PM   #14
Brian B-P's Avatar
Oh no!
Another discussion of boat trailer hardware used on travel trailers! Do we really need to do this again?
Bearing Buddies are to keep water out of the bearings of boat trailers which are submerged in water; they are not to provide a continual supply of grease, which is not needed. They risk pushing grease into the brakes of trailers equipped with them. They are completely unlike Dexter's E-Z Lube or similar grease-flushing systems from other axle manufacturers.
Axle winterizing... To lift or not to lift??? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 22 12-12-2015 05:47 PM
79 Trillium Roof- Slight sag or normal shape? rcaulen Problem Solving | Owners Helping Owners 9 08-18-2011 05:54 PM
Front lift wheel on a 17 Herb P Problem Solving | Owners Helping Owners 9 05-12-2007 09:42 PM
When do drooping axles need a lift? Isaac M Towing, Hitching, Axles and Running Gear 7 05-09-2007 10:59 AM
backpacking (a slight detour) John Mc General Chat 8 12-21-2006 04:27 PM
