Scamp 16' door and gravel shield renov - Fiberglass RV
Old 04-26-2009, 06:16 PM   #1
Yvon Chayer's Avatar
Trailer: Bigfoot 17 ft 1992
Quebec
Today i finish the renovation on my Scamp
I have some problem with my door
First the hinge have some loose , i replace it not great renov
Second the lower front end of the door don't close tight , i correct it , i remove the door and remove carpet, and make 3 saw cut on the inside fiberglass, i bent the door with a ratchet strp and make fiberglass to maintain it in the good position i use premix (fiberglass fiber mix with resin )
Premix fiberglass
saw cut
gelcoat application
Now the door fit exactly with the body of the scamp, before i have 1/2 inch opening on bottom
Perfect fit
the third problem , i don't like that the door was sealed on the carpet , i cut them and resuface the contact part of the door with gelcoat , now the seal is in contact with gelcoat not on the carpet
the seal seat
The other correction was the gravel shield i take my old door hinge and modified it
I cut it and reweld with 30 degre angle and use it for sield hinge
old hinge modified
hinge installed
closed
open
Now the rust on fiberglass is finish , i make new lock on the bottom make with a stainless stell flat bar
this job finished my spring modification , next week i start from Quebec Canada to one month vacation to Louisiana
I take some information in the site, when i can give on i make it
Thank again Yvon Chayer
Yvon Chayer is offline   Reply With Quote
Old 04-26-2009, 08:48 PM   #2
Jeanne and Steve's Avatar
Trailer: Casita 16 ft 1984 and U-Haul CT13 1985
Hi Yvon,
Your door looks fantastic now - great work! Plus it's neat that you retained some of your trailer's history by using the door hinges on your gravel guard. Thanks for the interesting report.
Best wishes for a fantastic camping trip!
Jeanne
Jeanne and Steve is offline   Reply With Quote
Old 04-26-2009, 10:06 PM   #3
Raya's Avatar
Thanks for the report and photos, Yvon! It's always so nice to see photo-essays about how people fix up their trailers.
I wish you a wonderful camping trip, and of course we would love to hear how it's going if you get a chance Will you look up Cajun/French-speaking people in Louisiana?
Raya
Old 04-26-2009, 10:18 PM   #4
Roy in TO's Avatar
Yvon,
Your work looks good.
May I suggest you post pictures rather than links. Sometimes outside photo hosting services stop hosting and we lose the pictures forever. For example Lance did a great slide show on his blue boler and his provider said they would not provide the service just this year, now we have to wait for him to post his pictures all over again.
Here is a link to the tutorial on posting pictures here:
http://www.fiberglassrv.com/board/in...howtopic=20738
Plus there are others that tell you how to resize if need be.
Roy
Old 04-27-2009, 03:05 AM   #5
Pete Dumbleton's Avatar
Your next project should be a screen door for your visit to Louisiana, where lots of mosquitoes live!
One way to do this is to use wooden inserts on the door jambs to make them straight, then you can fabricate a door from a window screen kit from hardware store and some pop rivets, plus a little scrap aluminum for added stability.
Old 04-27-2009, 07:19 PM   #6
Quebec
Hi Pete I have the factory screen door install in my scamp
After my vacation in Louisiana the next modification is remove front bunk and make a front dinette
I have make some research and after planification it is possible
Roy it's ok , i have read the tutorial and next time i make it
Yvon Chayer
Old 04-30-2009, 09:17 PM   #7
Raya's Avatar
Yvon, I am curious about something:
Did you use fiberglass cloth (or biaxial, etc.) to reinforce your repair? Or was it just resin with some fibers in it? (I'm not sure what is in the can that you show.)
I would have thought one would need cloth, but then I don't know the product you used.
Raya
Old 05-01-2009, 06:19 AM   #8
james kent's Avatar
Trailer: Boler 1984
Interresting concept. I know that Plasto makes compounds for the repair of plastic bumpers and injection mold plastic. Does it also make fiberglass products?
Let us know how it turns out.
Old 05-01-2009, 04:00 PM   #9
Trailer: Trillium 13 ft.-1974, Scamps 16 ft.-1996 & 13 ft.-2003
Hi Yvon: I'd like to know what rods you used (aluminum?) and how they are held in place, while holding up the rockguard? It looks great!!Have a great/safe trip -Mary Lynn K.
Mary Lynn K. is offline   Reply With Quote
Old 07-16-2009, 03:20 PM   #10
Kirby and Adele's Avatar
Trailer: 13 ft Scamp
I would also like to know what Yvon is using to hold up the gravel shield. When we bought the Scamp we wondered why the gravel shield hadn't been set up to open like an awning. Are they supposed to?
Yvon, répondez s'il vous plait.
Kirby and Adele is offline   Reply With Quote
Old 07-17-2009, 04:11 PM   #11
Quebec
For holding the gravel shield , i use a set of main door hinge from Scamp
I replace the main door hinge on my scamp and use the old hinge after modification of the angle of the old hinge
Yvon Chayer
Old 07-21-2009, 03:01 PM   #12
Joy A provides some instructions on making some struts to hold up the Gravel Guard. They're simple to make... I made mine two years ago and they work great! You'll find her instructions and others too in this topic:
Scamp Window Cover
Gravel Guard window covering Iris T. Care and Feeding of Molded Fiberglass Trailers 4 06-08-2010 04:29 PM
Wanted Scamp Rock Shield jimtesla Classified Archives 2 04-25-2010 07:03 PM
Scamp 16 renov Yvon Chayer Modifications, Alterations and Updates 17 04-10-2009 06:09 PM
gravel shield help tarek Problem Solving | Owners Helping Owners 3 06-25-2006 12:31 AM
