Scamp 16' New Flooring - Fiberglass RV
Old 01-30-2017, 02:51 PM   #1
Hello All,
My wife and I have recently purchased a 2008 Scamp 16'. We are interested in working on a few improvements over the next few months. One thing we are interested in accomplishing is new flooring. It currently has laminate flooring (i believe from the factory) that is in good condition, but really love the look of a vinyl wood flooring. I have read all different opinions but are curious what some of you think about this topic. Here are some of the questions I have!
1. Should I remove the laminate before installing the new flooring? If so, should I expect to see glue underneath the laminate from the factory?
2. Should the Allure Vinyl Flooring be installed "floating" or should I add glue for good measure?
3. Do you have to remove the benches to install flooring? If you do remove the benches, then do you drill through the new flooring for reinstallation?
4. If no glue is used for this flooring, then how do you get the one strip required for the step up to the dinette to stay?
Thank you so much for your help!
Craig
camaertens is offline   Reply With Quote
Old 01-30-2017, 03:07 PM   #2
Scamp has never used laminate from the factory. Carpet or sheet vinyl only. It's probably a floating installation, but since it was done by a previous owner, there's no telling what might be underneath.
My tentative thoughts are...
(1) Yes.
(2) Floating
(3) No.
(4) Not sure- probably glue.
Best wishes! And welcome to the forum, Craig!
Old 01-30-2017, 03:58 PM   #3
Trailer: Scamp 16, previously Scamp 13
None
Originally Posted by camaertens View Post
Hello All,
I just got done installing Allure vinyl plank. I'm no expert, but I'm pretty happy with my results. If the existing floor is in good shape, then I would probably just install over top. Might want to try a small corner, see if it's glued down, or just floating If it's floating it would be an option to remove it without a lot of trouble. The Allure can be installed over any rigid floor that is in good shape. If your floor is currently glued down, you are in for a lot of work to remove it and get the glue off - that was the most time consuming part of my project, getting the carpet and glue off. Not an option to install over carpet. One good thing for me, when I pulled the old carpet, I found a small area of rot starting. I was able to repair that, prior to proceeding.
The recommendation and instructions say floating, so that it can expand and contract with temperature changes. That said, you have no warranty anyway, since it is only warranted for installation in a 100% temperature controlled environment. I have read, and it makes sense, that in these small trailers, any contraction and expansion is pretty minimal, not like the combined effect in a 15 X 30 foot room would be.
I did not remove my benches, due to some complications in my particular trailer to doing so. If your's is standard install of the benches, it is supposed to be pretty easy to remove them, and makes for a neater install with less need for moldings or caulk. But it works either way.
Once the carpet was off the step, I was left with just bare steel framing. EXTREMELY cold which caused much condensation, and acted like a "cold" radiator. I had some left over 1/8" foam vinyl siding underlayment. I cut strips of this to cover the bare metal, then fit the vinyl plank to cover the foam. The steel was so cold and wet with condensation, that I figured no glue would stick to it, so they are just held in place with metal step edging on the top. Once I get the matching quarter round (special order from Home Depot), I will add that to secure the bottom. Caulk should work as well. I think the foam has helped a LOT here in Michigan in the winter. No condensation now after several days of low 20 degrees with the trailer heated and me working in it.
Craig
Hope this helps. As I said, I'm no expert. I will say that if I ever do this again, I will try the Allure Ultra - the click together, instead of the glue strips. I just think it might be a little easier, but either way, it's a pretty easy install.
LyleB is offline   Reply With Quote
Old 01-31-2017, 01:29 PM   #4
Trailer: 2016 -13' Scamp
Massachusetts
Make sure you buy vinyl flooring that resists water stains. Many brands look pretty beat up after just a few drops of water set in. You won't want to be afraid to spill something, have a refrigerator spill, or track in rainy footwear.
herons is offline   Reply With Quote
New Allure Flooring - Scamp 13' Shannon Thompson Modifications, Alterations and Updates 26 09-24-2015 12:22 PM
New Flooring-Laminate or Vinyl Tim Wood Care and Feeding of Molded Fiberglass Trailers 49 03-08-2015 03:11 PM
new Scamp flooring beardrum Modifications, Alterations and Updates 6 09-04-2013 12:40 AM
New flooring- What to do with door edge trim? Kevin K Problem Solving | Owners Helping Owners 10 11-02-2011 09:03 AM
1974 Boler : THE TANK - new flooring Jayson Wall Modifications, Alterations and Updates 10 07-05-2007 08:16 AM
