Scamp 16 renov - Page 2 - Fiberglass RV
Old 11-20-2008, 11:31 AM   #15
brian m.'s Avatar
Trailer: 17 ft Casita Spirit Deluxe
Have you considered laying something over the SS floor pan for those cold days? I'm thinking of something like either of these products below might be nice.
Anyone know where I could find something like this wood/plastic shower floor?
brian
2003 Casita SD 17'
http://www.coolcampcreations.com/
brian m. is offline   Reply With Quote
Old 11-20-2008, 01:31 PM   #16
Jake Jacobson's Avatar
Trailer: Scamp 16 ft and Trillium 4500
[quote]Anyone know where I could find something like this wood/plastic shower floor?
Attachment 16877
Here is one:
http://www.rvtoyoutlet.com/p-RV5294.html
You can also get "DryDek" from Westmarine:
DryDek
I have it in the shower in my 16'. 2 pieces fits the shower floor perfectly, and it doesn't mar the fiberglass. If you read the description, it actually is designed to protect fiberglass from abrasion.
Jake Jacobson is offline   Reply With Quote
Old 04-10-2009, 05:13 PM   #17
Trailer: Columbus Coach Liberty
How did you get the plywood off of the resin? And to replace you just resined up the new piece and put it down and then put weights on it to hold it down?
Dirk A is offline   Reply With Quote
Old 04-10-2009, 06:09 PM   #18
Raya's Avatar
Dirk,
I'm not Yvon, but I'll chime in and say that you cannot remove plywood from resin because it's a coating. It would be like "removing the wood from the varnish" - not possible.
When you put in new wood you can re-coat it with resin (and/or add fiberglass cloth or reinforcement, as suitable). This is in general, since I can't see your specific trailer.
Oh, and resin alone will not be enough "glue" to hold a floor down. You would need to tab in with cloth, or use fasteners, I would think (again, not looking at your trailer).
Raya
Scamp 16' door and gravel shield renov Yvon Chayer Modifications, Alterations and Updates 11 07-21-2009 03:01 PM
