Scamp( 2nd chance ) - Page 6 - Fiberglass RV
Old 10-29-2015, 08:12 AM   #71
Trailer: 2015 Scamp 16' deluxe 2008 FJ Cruiser
Fridge
Well we are finally moving on the fridge repair. The new coil assembly will be in next Tuesday. The install is to be done on Thursday. Service center sail Dometic is giving them 2 1/2 hours to do. I need this done!
Ken
Ken in Pa is offline   Reply With Quote
Old 10-29-2015, 08:17 AM   #72
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
They may have to do the replacement of parts in stages. When my Dometic refrigerator failed within the warranty period the repair shop knew the cooling unit failed. Domestic insisted they replace the heater. 1 1/2 weeks later replacing the heater didn't change anything; then Dometic sent a cooling unit. No charge, but it took a month to get it fixed...
Old 10-29-2015, 10:51 AM   #73
Shop knows the electric heater and the propane heater both work. The fridge was leaking yellow liquid. They said the cooling coils were being sent. I need this done so I can put it away for the winter.
Ken
Old 11-13-2015, 09:16 AM   #74
Still on going. Dometic has sent the wrong cooling coil assembly twice. Now they said it was to be sent next day on tues. It was picked up at the factory on weds. This is fri. I do not call that overnight delivery. Rv service is upset with Dometic same as me. Thank goodness this is not June.
Ken
Old 11-18-2015, 09:58 AM   #75
Well we got our "2nd chance" home today all fixed. I have mixed feelings. the refrigerator works but it toke so long. Dometic has to get their act together. They sent two coil units and one whole refrigerator before getting it right. The Rv service replaced everything yes everything but the case saying they could not get it out of the trailer or the new one in. Said the trailer was built around the refrigerator.??? One good thing this did not cost one dime. I guess I would be more upset if this was June.
Ken
Old 01-04-2016, 09:41 PM   #76
Trailer: Shopping
Looks great keep up the good work.
limp1144 is offline   Reply With Quote
Old 01-05-2016, 11:13 AM   #77
Thanks Tommy. 2nd chance is under cover for the winter. We are now planning our trips for the coming summer
Ken
Old 05-19-2016, 11:25 AM   #78
Just a small update. The frig. works. Funny it works better than it ever did. (knock on wood) We have been out for two long weekends and used it on propane and electric all is good.
Ken
Old 06-07-2017, 07:27 AM   #79
TIRES
I just wanted to let you all know. We had a blowout on rt90 in NY. Which happens. I checked the date on the tires once it was off the trailer. 0313 The trailer is a 2015. The tires were two years old when we picked it up at the factory. Also C rated and the trailer I was told at the factory is 2500lb.Really they can't put on D rated tires. It has them now. Check your tires.
Ken
Old 06-07-2017, 07:46 AM   #80
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
"Check your tires" should include pressure testing or measuring. A slow leaking tire that runs hot (flexing of the sidewall) is a time bomb.
Old 06-08-2017, 09:18 AM   #81
Are these 13 or 14" tires? Scamp USE to use 13's on the 16's!
Ken
Old 06-11-2017, 03:25 PM   #82
13" tires not sure 14" would fit. Close on the one side in the front.
Last chance 13' scamp parts 81scamp Classified Archives 5 09-29-2011 09:23 PM
AB LAST CHANCE Sept 11-13, 2009 Craig B. Rallies, Get-togethers, Molded Meets (Archive) 13 09-15-2009 06:57 PM
AB Last Chance Lainey Rallies, Get-togethers, Molded Meets (Archive) 44 09-30-2008 11:26 AM
Second Chance Legacy Posts Care and Feeding of Molded Fiberglass Trailers 48 12-23-2002 06:20 AM
