Scamp adds drain valves on 13' - Page 2 - Fiberglass RV
Old 03-24-2016, 07:49 AM   #15
CampyTime's Avatar
Trailer: Scamp 13' Standard
Is your kick plate sheet metal? Looks silver in color. How'd you fasten it? Cheers for posting!
Old 03-24-2016, 08:05 AM   #16
It's actually aluminum "flashing" cut to fit. There's a "hump" on the door at the top of the "kickplate" I call it. I stuck the perimeter down into the molding but I did NOT remove any rivets!! And I tucked the top of it into the ratfur. I siliconed around the edge where you see it in the molding. It's been there for nearly 6 yrs now and still looks good.
I did use some waxed paper to make a pattern before cutting the aluminum. It's only about .020 thick. Very thin and easy to work with. But, you could easily use plastic there as well.
And, you're very welcome.
Old 03-24-2016, 09:08 AM   #17
I noticed water under the very bottom black trim every time it rained, and was concerned about water wicking up to the hidden wood reinforcement and rotting it similar to the way others have documented. You had to look pretty close to see the water but sticking a slip of paper in behind the trim would also reveal it.
I also had some of the trim near the handle come loose in the hot sun. Kent Eveland at Scamp told me the trim was held on by friction (except where it was riveted) but that I could use adhesive also where it came loose so I did that. He thought his would stop the water but it did not. Next, I used ProRV sealant on the entire trim on the door exterior. It made no difference, water would still be present after a rain. So I next used the sealant on the interior of the door, along the trim up to the top of rubber strip at the door bottom.
I have not seen any water since HOWEVER (and this is important), I am not recommending this action because it is very possible that water is still getting into the bottom of the trim but now I have masked the problem and made it harder for it to dry out. I just don't know if it is better this way or not - time will tell.
How to keep gate valves on black/grey operational? rabbit Care and Feeding of Molded Fiberglass Trailers 11 11-09-2012 11:21 AM
Google Adds Tamid Forum Admin, News & Announcements 1 03-17-2011 10:06 PM
Tire pressure indicator valves Bobbie Mayer Problem Solving | Owners Helping Owners 11 03-21-2009 04:05 PM
My dump valves work! Gina D. Plumbing | Systems and Fixtures 20 02-24-2007 03:09 PM
shower drain scamp 5th wheel Legacy Posts Problem Solving | Owners Helping Owners 1 12-27-2002 06:45 PM
