scamp cushions for boler? - Fiberglass RV
Old 07-04-2017, 05:43 PM   #1
Manitoba
I couldn't get a conclusive answer from Scamp so I'll ask here and hopefully someone can give me a clear answer.
My cushions/upholstery in my '74 boler is beyond the point of salvage so it will be brand new, either custom or bought from Scamp. I have no reason to think new cushions from Scamp wouldn't be a near perfect fit, so that's my question... Has anybody replaced their original Boler cushions with new Scamp ones?
If there is any mis-fitting, is it minor? And where does the fitment not work well if there is?
Thanks
Humpty is offline   Reply With Quote
Old 07-04-2017, 07:04 PM   #2
likeair2me's Avatar
Trailer: SCAMP
Glenn, I haven't tried swapping the cushions from a Scamp to a Boler, but if all else fails, find yourself an upholsterer. Either the kind that rebuild furniture, or a marine upholsterer should be able to make you the cushions you need, and even give you custom fabrics that suit your style. Off the shelf will be pretty generic.
likeair2me is offline   Reply With Quote
Old 07-04-2017, 07:13 PM   #3
rbryan's Avatar
Arkansas
A good upholstery shop for sure. Better quality, you get to select the density of the foam based on your preference, and your choice of fabric.
Old 07-04-2017, 09:39 PM   #4
Manitoba
Have definitely considered that but cost being a major concern is why I'm thinking about "off the shelf" vs custom
Old 07-04-2017, 09:39 PM   #5
Another option is to order only the covers from Scamp and source the foam locally. That would save you a lot on shipping and also allow you to choose the foam density you prefer. There were a couple of threads about people who replaced the Scamp foam, which they thought too hard for sleeping, with a different grade or, in one case, a foam sandwich of two different grades of foam.
Ordering the covers from Scamp will be way cheaper than custom upholstery, and I find the quality acceptable.
What I don't know is whether they are a close enough fit for your Boler. My strong suspicion is yes, but I'm not sure. If you don't hear from someone who has actually installed Scamp cushions in a Boler, send me a PM and I can take some measurements for you.
Old 07-04-2017, 11:02 PM   #6
Manitoba
As I'm only 3hrs away from the scamp factory, shipping wouldn't be much of an issue. I'd likely bring them across the border myself.
Old 07-05-2017, 07:08 AM   #7
In that case, could you just take the trailer with you and do a test fit? Perhaps make a long weekend of it at a nearby campground?
Old 08-20-2017, 05:52 PM   #8
Manitoba
Attended the Manitoba Fiberglass and Vintage Camper Rally this weekend and found the opportunity to measure the cushions in an '08 Scamp and got the answer I was looking for. They are as near an identical match in dimension as I could hope for. Hadn't really expected otherwise, but its good to have a conclusive answer.
boler, scamp
Old schmushed 13' Boler cushions Deb H Problem Solving | Owners Helping Owners 5 07-31-2012 12:23 AM
Replacing Boler cushions with Scamp cushions? Jerry71 Problem Solving | Owners Helping Owners 12 07-17-2009 05:26 PM
New Scamp cushions in a Boler Brian Scott Problem Solving | Owners Helping Owners 7 05-17-2008 12:11 AM
My 74 Boler Re-Ulpostered Cushions Jayson Wall Modifications, Alterations and Updates 10 05-22-2007 12:10 PM
buying replacement cushions for Boler and where to get propane tank MRowe Problem Solving | Owners Helping Owners 11 07-24-2006 05:18 PM
