Scamp door... - Page 2 - Fiberglass RV
Old 01-24-2014, 02:41 PM   #15
Brand's Avatar
Trailer: 76 scamp
P.S. are you thinking the hinges = crooked door, while bulge = gap at bottom?
Brand is offline   Reply With Quote
Old 01-24-2014, 02:44 PM   #16
Brand's Avatar
Trailer: 76 scamp
Thanks for your help Roy!
Old 01-24-2014, 04:35 PM   #17
Trailer: 77 Scamp 13
The aluminum hinges after decades are going to have worn sockets allowing some door shift. Typically with door hinges it is the top hinge that takes the most wear. You might test for this by swapping top and bottom hinge, or just order two pair from Scamp store. If you can call and order and ask to have shipped US Postal you might save a chunk of money. UPS and FedEx have steep rates in that part of the country, web site store the shipping is murder.
The hinges themselves have a little play at the mounting bolts. Not a lot but with a second person helping one can loosen the bolts, shift the door, hold it in place and re-tighten the bolts to adjust the angle a bit.
You might also check for where the fiberglass is attached to the floor between door and front corner. The fiberglass sides are attached to the wood floor with fiberglass cloth and resin used like a tape. Moisture can cause wood surface to deteriorate and allow fiberglass to pull free of the floor allowing wall to shift a bit.
Floor does not have to be rotted or anything just softened enough on the inside that the surface wood allows the soaked in fiberglass resin to pull loose. At that corner of the trailer you have the door (never noted for a great seal) the door window and possibly a front window, all points that will allow water in.
Take a look at the square tube that braces the wall along the hinge side of the door opening, make sure it is riveted tight to the wall and has not pulled loose.
I'm pretty sure after over 30 years some wall sag is inevitable, think about it, gravity has been pulling the roof down so the walls can tend to bow outward, it's like our little marshmallow has been squished just a bit. Even a stationary house gets some shifting in the door frames after 30 years.
Old 01-24-2014, 07:00 PM   #18
Start cheap and move to the more expensive or more effort. You can buy the hinge kit (brass ball, spring and bolt) from a local Range Rover dealer (if there's one in your area.) DOOR HINGE KIT SERIES II, IIA & III, DHK111 - Rovers North - Classic Land Rover Parts
BTW: there's a difference throw between the top hinge on the Scamp and the bottom hinge. That's why the cast aluminum is stamped #1 and #2. They are NOT interchangable.
Old 01-24-2014, 07:42 PM   #19
Brand's Avatar
Trailer: 76 scamp
"Little marshmallow..." Hahaha, that is cute! Will check those areas in the morning. Thank you guys again for your help! Updates to come!
Old 01-25-2014, 07:38 AM   #20
Roy in TO's Avatar
Originally Posted by Brand View Post
...have seen a couple of posts where there is a "brace-type" mechanism used. Wood frame glassed to the inside by the door. Is that what you suspect?
Yes, they are trying to solve the symptom, not the problem. Much like someone has tried to on your trailer
You got it, Roger and Donna provide a lot of good advice.
Originally Posted by RogerDat View Post
You might also check for where the fiberglass is attached to the floor between door and front corner. ...
Floor does not have to be rotted or anything just softened enough on the inside that the surface wood allows the soaked in fiberglass resin to pull loose. ...
One other thing to look for is a cracked or bent frame.
I've attempted to solve the problem by using an aluminum frame around the door. Improving door fit due to body sag
In hindsight, I think that one could help support the hinge side of the body wall and tie all the pieces together with a piece of wood and do the screen door mod at the same time.
Old 01-25-2014, 05:34 PM   #21
sugermc's Avatar
Trailer: 1983 13 ft Scamp and 1985 13 ft Scamp
#1 #2 hinge
so Miss Donna, is the #1 hinge on the top or bottm
and where are the numbers on the hinge
Thanks
sugermc is offline   Reply With Quote
Old 01-25-2014, 07:48 PM   #22
Oh my stars. Wish I could tell you. I've never needed to replace the hinges on my Scamp, I was just parroting information I've read here on the forums.
Unless someone answers up, perhaps your very best info would be to call the Scamp parts department...
Old 03-26-2018, 01:27 PM   #23
Maryland
Crooked Door
I'm following this thread, I've got a similar issue on my "new" '83
nickzanin is offline   Reply With Quote
Old 03-26-2018, 01:32 PM   #24
rogerdat standing inside looking out the door I notice a crack in the right side of the door at the bottom when the door is closed. I have tried weather stripping helps some. I have ians hinge repair kit will this close this gap? do you think?
I hate to work on this I am not good at geometry
thanks
bob
Old 03-26-2018, 02:08 PM   #25
IllAnnoy
New to the scamp (1976), found online through this site and fell in love at first sight. I am having a couple of difficulties...1. The door hangs a bit cock-eyed. Unsure if you can tighten the hinges or would they have to be replaced...any help would be great!
most commonly the hinges wear and make the pin holes oblong.
One simple fix is to remove one hinge pin at a time with the door closed.
drill the hinge out (including the ball) to 11/32 or until round again. Replace the hinge pin with a 5/16 stainless steel shoulder bolt short spring and a Nylock nut. Then do the other hinge, no need to remove the hinge from the door or the trailer.
This will usually restore the door to its original attitude.
THE SCARY PART....
Look under the trailer at the tray part of the frame to be sure that the floor tray material is not rusted out allowing the frame to settle at the doorway.
Old 03-26-2018, 02:32 PM   #26
good ideas floyd
I think ians hinge repair kits solves some of things you mentioned i can move the door at the hinges so i know something isn't just right. we have had rain here today and again tomorrow.
weds. is trouting trip but instead of fishing all day we are cutting off at 12pm so while the barb coals are getting started I may take a look.
trouts have priority over everything here
thanks
bob
Old 03-26-2018, 02:33 PM   #27
oh i forgtot to mention the door at the bottom is in good shape
bob
Old 03-28-2018, 10:00 AM   #28
IllAnnoy
thanks
bob
Actually, the hinge casting tends to wear more than the bolt, so drilling it makes a better repair... Short of replacement.
How to fix a scamp door Mary Ann in MN Problem Solving | Owners Helping Owners 9 05-07-2011 06:06 AM
Scamp door catches Weinel, Alan Problem Solving | Owners Helping Owners 4 02-26-2010 11:19 PM
scamp door Isaac Problem Solving | Owners Helping Owners 7 03-28-2008 05:48 PM
Scamp Door Jackie Problem Solving | Owners Helping Owners 10 02-04-2007 04:02 PM
Scamp Door Legacy Posts Modifications, Alterations and Updates 11 05-23-2003 07:02 AM
