Scamp Faucet Question - Fiberglass RV
Old 02-14-2015, 12:14 PM   #1
Pineapple Man's Avatar
Trailer: Scamp 13'
Ohio
Hi,
Tried a search, but couldn't find anything (or I'm not searching correctly).
I'd like to replace the faucet in our Scamp 13' with a Hi-Rise faucet.
Has anyone done this before ? Does any size RV faucet fit ? If not, how do I take measurements ? Any installation tips ?
Thanks !!
PineappleMan
Pineapple Man is offline   Reply With Quote
Old 02-14-2015, 12:26 PM   #2
Trailer: 16' Standard
Ohio
Sink
I changed a faucet in a 19' Scamp because it had froze. I found exact replacements at the local RV store. There are many options there, they are cheaply made to cut down on weight but work fine. You can go to Home Depot too. Just remove the one you have and measure center to center of the Hot n Cold handles. Remember, the higher to faucet, the more it splashes around.
Kenny in Ohio is offline   Reply With Quote
Old 02-14-2015, 12:33 PM   #3
Ian G.'s Avatar
All RV faucets are usually cheap and plastic. I think you will find that the faucet in your Scamp has the handles spaced 4" apart which means any household faucet with 4" centers will fit. I used a high rise bar faucet in my Boler and it worked great. Check your local home improvement store like Home Depot.
Old 02-14-2015, 05:55 PM   #4
Trailer: Scamp 13'
Ohio
WHEW !! Buttercup is Beautiful !!! We're "doing" our Scamp in Pineapple colors. Just got done sewing curtains and am starting on the cupboards. Helps keep my chin up in these blizzard conditions... Thanks for the info !
PineappleMan
Old 02-14-2015, 09:19 PM   #5
Ian's correct. Skip the RV stuff and go right to someplace like Lowes or Home Depot (or even online). 4" centers mean either something considered a bar faucet or even a bathroom faucet. I'd suggest getting one with paddle handles.
Old 02-14-2015, 10:44 PM   #6
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
What ever faucet you decide on, it will install much easier if you remove the sink first. There are wing nuts in each corner, and you must remove the drain hose......that's it. We went with a shower handle attachment so we could more easily rinse large pots, or wash our hair. The sprayer could also be passed out the kitchen window into a portable enclosure for showering.
Dave & Paula
Old 02-15-2015, 12:12 AM   #7
Trailer: Bigfoot 17' DLX
Alaska
Here's an inexpensive 4-inch on-center pull-out faucet I installed in my Bigfoot last year. It is from Home Depot and made for a laundry sink. I've used it quite a bit since the install and it still works great and makes the chore of washing dishes much easier than it was with the previous bar faucet I had in there.
Inexpensive 4" on-center pull-out faucet
trainjunkie is offline   Reply With Quote
Old 02-16-2015, 10:38 PM   #8
CampyTime's Avatar
Trailer: Scamp 13' Standard
Hi Trainjunkie,
Well, I went straight on the Internet and bought your very nice laundry tub faucet with center sprayer. Seemed a great idea to me, and i anxiously await it's arrival, along with spring, to install it. It was 64 bucks and shipping here. Thanks also to Dave for suggesting the sink and drain hose removal first. I am so tired of -20 degree temps I could scream. It's so boring in Buffalo. I need to camp!
Kitchen Faucet for a 2008 Scamp LarryTheresa Modifications, Alterations and Updates 7 03-12-2013 04:09 PM
Priming hand pump faucet on Scamp JudyL Problem Solving | Owners Helping Owners 7 11-13-2012 08:49 AM
Shower Faucet Assembly - Scamp fusedlight Problem Solving | Owners Helping Owners 8 10-17-2012 10:15 PM
Scamp sink faucet - no clearance Doghaus Modifications, Alterations and Updates 10 09-26-2011 06:37 PM
Scamp faucet - can it be replaced easily? Sheryl M Plumbing | Systems and Fixtures 9 02-14-2010 06:56 PM
