Scamp front bathroom window mod. - Fiberglass RV
Old 06-17-2012, 12:27 PM   #1
Trailer: 2008 13' Scamp
The window leaked. I opened it as much as possible and could see the rubber seal was messed up. Nothing could be done with the window in place so I removed it.
The window does disassemble without much effort and it's much easier to deal with the seal. The window tilts back. The extrusion is a "U" shape. Water sits in it. Any problem with the seal and the water will find a way past it.
I was surprised that there weren't any drain holes to the outside. Letting the channel drain reduces the work of the seal at keeping water out. I drilled 3 drain holes. I cut the damaged part of the seal off and put that side at the top with some replacement material. I used double backed tape to hold the seal in.
Two days of heavy rain and all is dry. dry rain
Ron
Old 06-17-2012, 12:31 PM   #2
I ended up having to drill a few holes in the frame of my side bath window frame as well for the same reason... wonder why they dont put weep holes on the small windows.
Old 06-17-2012, 03:18 PM   #3
Tim Wood's Avatar
Trailer: Class B for now
NY
Way to go Ron that's using the old noodle. Its always nice when things do work out isn't ?
Replacing the front window... Scamp 13' Matthew Lyon Problem Solving | Owners Helping Owners 31 06-23-2013 06:59 AM
Casita- Bathroom Window Mod Aids10 Modifications, Alterations and Updates 4 03-25-2012 12:54 AM
MO | 2009 13 ft. Scamp w/ front bathroom for sale Jo Cervi Classified Archives 9 10-10-2011 07:08 PM
No front window on '87 Scamp 16ft Mikes Problem Solving | Owners Helping Owners 2 01-24-2011 06:37 PM
Scamp 5er--front or side bathroom? Aaron Borovoy Care and Feeding of Molded Fiberglass Trailers 6 02-23-2008 02:04 PM
