Scamp:missing cover for electric hook-up - Page 2 - Fiberglass RV
Old 04-30-2013, 10:02 PM   #15
Lora's Avatar
Trailer: 89 Bigfoot 17G & 73 Compact II
Northern Neck, VA
Originally Posted by FTTRV View Post
Another type of square cable hatch.
Looks like a round hole in a square hatch.
And, since we are talking about these hatch covers. The last trailer I used had the round hatch. I noticed that one of the little pegs that is supposed to snap down to keep it closed had broken off. The two square hatches seem to use a different mechanism for closing. Any comments on experiences with the different mechanisms?
And, can the second one be closed when the cord is extended (is there an opening in the cover?)
Lora is offline   Reply With Quote
Old 08-03-2017, 07:30 PM   #16
JC_In_Austin's Avatar
Trailer: 13' Scamp "La Cucaracha"
Door for the Scamp cord port...and rubber closure things...
Originally Posted by steve dunham View Post
Yes there is a door for the cord port . I replaced mine -Not hard to do- Cost about$7.00
I know this is an old thread, but I've looked and looked and cannot find a replacement door for the cord port; it's completely missing. Can you tell me where you found yours?
Also, 3 of the little rubber grommets that turn to keep the big doors on the electrical switches on the outside secure are gone. Suggestions? I didn't find anything like them on the Scamp website.
Thanks for any help! / JC
_______________________________
Life is short, but it's wide! #TravelOn
JC_In_Austin is offline   Reply With Quote
Old 08-03-2017, 09:54 PM   #17
Trailer: Bigfoot B-17 CB
Please post pictures.
Old 08-03-2017, 10:48 PM   #18
Pictures of port and panel
Actually, I'm only missing 1 of the grommets, but it's getting hard and may break. It's about half an inch wide, and when you turn it so that the horizontal ridges are vertical, you can pull the panel off.
I don't know why they're appearing sideways (tilt to the left to see them properly); in the preview, they were correctly situated.
It's nighttime, so if you need better pics, let me know.
Thanks!
Old 08-03-2017, 11:08 PM   #19
https://www.amazon.com/RV-Designer-C...tor+vent+latch
http://www.rvplus.com/zebra-rv-acces...All%20Products
https://www.amazon.com/rv-power-cord...20cord%20hatch
Old 08-03-2017, 11:19 PM   #20
[QUOTE=Jack L;654347]https://www.amazon.com/RV-Designer-C...tor+vent+latch
So sorry; I should have posted the inside view, as well. The whole thing is about an inch ~ front outside to inside rear.
Oddly, when I turned the front from horizontal to vertical just now, I found that the inside does not move at all, so it must be more complicated than just a little rubber thing. The front part apparently locks over something in the horizontal position.
Old 08-03-2017, 11:21 PM   #21
ZEBRA RV ACCESSORIES RM208P - Zebra RV Accessories Cable Hatch Polar White RM208P - RV Plus
Yay! This is the cord port I need! Thank you very much!!
Old 08-03-2017, 11:27 PM   #22
I just tried it again ~ to see if the inside just compresses to hold it in, but ~ no, turning the front part actually locks something. It won't come off unless it's turned to vertical.
Hope I don't have to buy a whole new panel to get it right; I'm just afraid it's going to fly off going down the road.
Old 08-03-2017, 11:56 PM   #23
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Turning that 90* left or right locks the vent cover in place. There is nothing but plastic to plastic contact. They can be a bit stubborn to turn once in a while but a quarter works pretty well in the slot. Some members keep a few extras on hand....just in case. BTW, if you should have one break while out camping, I'd take the cover off and stow it away so it doesn't sail away somewhere.
Borrego Dave is online now   Reply With Quote
Old 08-04-2017, 12:44 AM   #24
I would gladly buy some extras, if only I could find out where to buy them. I only have the one on this panel. Do you have a link? I could not find them anywhere on the Scamp site.
Thanks, Dave.
Old 08-04-2017, 03:33 AM   #25
Thanks, Dave.
I don't have a link but I would think most RV stores have them as they are somewhat common now. I do believe Little House Customs carry them and they are a member of this site.
Old 08-04-2017, 06:21 AM   #26
Are those turn latches on the vent cover by the fridge? On our Casita , after removing the cover, there are two places where a screw can go into at the bottom of the part that is attached to the trailer (the frame for the cover) I drilled two holes in the cover at those locations so I can put in sheet metal screws for extra security to hold the cover on. I don't trust the plastic latches. As for the cord port, I bought one on eBay, then found it didn't fit the hole in the trailer and had to order another the correct size, so you need to know the hole size
Old 08-04-2017, 07:14 AM   #27
No; it's a Scamp, but yes ~ it's the outside fridge control cover. I'll look into the sheet metal screw fix, and I'll be sure to measure the cord port. Thanks!
Old 08-04-2017, 08:24 AM   #28
Thanks, Dave!
Wish there were "like" or "thanks" buttons for these threads. I feel guilty if I don't acknowledge a good suggestion or answer. Having a couple of acknowledgement buttons would make the threads much shorter, IMO.
Missing screw for Boler electric hatch jlbails Problem Solving | Owners Helping Owners 9 08-27-2012 01:24 PM
Electric/water vs full hook-up MinnesotaJill General Chat 6 07-02-2012 07:50 PM
front electric jack cover Oliver elite Problem Solving | Owners Helping Owners 1 06-10-2012 08:51 PM
Where to find plastic cover for water/electric? Panoz77 Problem Solving | Owners Helping Owners 10 01-18-2012 04:11 PM
BATTERY hook-up for 16' Scamp lenny247 Care and Feeding of Molded Fiberglass Trailers 2 03-25-2006 06:50 PM
