Scamp restoration and mods - Fiberglass RV
Old 07-05-2011, 07:49 PM   #1
Justin Aasland's Avatar
Trailer: Scamp 1989 13 ft
Here's a link to photos of the work and progress to my Scamp since I bought it almost a year ago. I've done a few things to it. Just added the fantastic vent on the 4th. Check it out. Scamp web album
Justin Aasland is offline   Reply With Quote
Old 07-05-2011, 07:58 PM   #2
Thanks for sharing the pics Justin. Isn't it fun making a trailer uniquely your own!!
Old 07-05-2011, 08:27 PM   #3
Pam Garlow's Avatar
Trailer: U-Haul 1985
I like the front counter area!
Old 07-05-2011, 08:31 PM   #4
It was not fun to remove. The epoxy had seeped deep into the fabric and had to be cut out. I still need to fix the front wall fabric.
Old 07-05-2011, 09:20 PM   #5
Vickie B.'s Avatar
Trailer: 1988 Perris Pacer ('Bean') / 2004 Element
Great job Justin!
Vickie B. is offline   Reply With Quote
Old 07-05-2011, 09:26 PM   #6
Trailer: Casita Freedom Deluxe
Beautiful. How did you get it soooo shiny?
rlazenby is offline   Reply With Quote
Old 07-05-2011, 09:32 PM   #7
3M rubbing compound and Nufinish. That 3M stuff took off so much oxidation. It was amazing.
Old 07-05-2011, 10:00 PM   #8
I have used the 3M stuff. How is Nufinish applied? It look amazing.
Old 07-06-2011, 06:52 AM   #9
It's just wiped on then wiped off after it dries to a haze. I used a power buffer to apply it in a nice even coating. I've used it on my vehicles for years.
Old 07-06-2011, 07:30 AM   #10
Thanks. Will have to try that out. I read some reviews after reading your response. The reviews seem to agree with you. It did say to make sure you get read of the oxidation really well first (as you said to use the 3M stuff) because if you didn't, results wouldn't be good.
Old 07-06-2011, 07:38 AM   #11
sugermc's Avatar
Trailer: 1983 13 ft Scamp and 1985 13 ft Scamp
great job on the scamp Justin
Could you give me some details on the leds in the fan area? How did you get power to them? Is the switch for them on the trim of the fan or somewhere else? Or are they battery operated? thanks suger
sugermc is offline   Reply With Quote
Old 07-06-2011, 09:07 AM   #12
The LEDs are 12v flexible strips that are made for under cabinet mounting.
They are the warm white variety and are nice and bright.
The have a 3M adhesive and can be cut to what ever length. I bought an 8ft strip off of ebay for $28. I There is a 2ft strip under the front upper storage and a 2ft under the galley side upper storage and then 3 1ft sections on 3 sides of the vent.
I ran new wiring under the rat fur and insulation for all of them to the new power center/converter. So they will run whether it's plugged into AC or off the battery. The switches are on the cabinet upper middle.
I made a recessed area on the custom cabinet where I can put the switches.
70's Scamp Restoration Jay B. Modifications, Alterations and Updates 28 08-01-2011 08:42 PM
1977 Scamp 13 Restoration Project ReilleyS Modifications, Alterations and Updates 29 05-14-2011 02:22 PM
1976 scamp restoration DannyH Modifications, Alterations and Updates 21 07-29-2010 03:39 PM
Used Portable AC in '86 Scamp restoration Gary Little Modifications, Alterations and Updates 5 05-11-2006 08:45 PM
Pix of Restoration 13' '77 Scamp Legacy Posts Problem Solving | Owners Helping Owners 7 01-06-2003 01:13 AM
