Scamp Table - Page 3 - Fiberglass RV
Old 01-03-2013, 12:50 PM   #29
Name: Steve and Rosemary
Utah
Thanks! It looks tricky but with a little investigation I might be able to figue it out. Thanks again.
Steve and Rosemary is offline   Reply With Quote
Old 01-03-2013, 01:04 PM   #30
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
You could probably refit the table you've already got, assuming it's the swingdown hinge/folding leg type. Since in your case you're trying to increase the length, adding a section would probably require resurfacing the whole shootin' match (unless you'd only use the extra when in bed form, in which case who cares if it doesn't match finish-wise, right?)
The slides themselves are readily available, and here's an interesting short video showing how to measure for/install them:
Francesca
Old 03-28-2014, 10:38 AM   #31
Utah
Hey all, we're FINALLY going to put our table together. Last year, we didn't take the trailer out ONCE and part of the reason was because I'd removed the table.
Anyways, I've copied the ideas I've seen here and am using drawer rails to extend out for support of the second half of the table. Line Ron in BC, I would like to have the drawer rails positioned how they'd be in a drawer. In other words, Norm put his "flat" and I'd like to put them on their edges.
The problem I'm having is figuring out how to attach the "front" pull piece to the drawer rail. I don't believe mine have holes in them pre-drilled. Do you drill them through yourself? Do you glue that piece on?
Thanks for your tips! I appreciate them.
SERENITY 1989 Scamp 16' Side Toilet | Steve, Rosemary, Maude Pod & Tripawd Hope | Next trip: The Weber for some fishing
Moab Maiden Voyage 03/10 * The Swell 5/26/11 * Antelope Island 12/31/11 * Strawberry Res 6/12 * Whitney Res 6/14 * Uintahs 07/15 * East Fork of Black's 06/16
Old 03-28-2014, 12:46 PM   #32
Roy in TO's Avatar
There's also a set of instructions for the removable-leaf version here in the document center that's a good line drawing of the way the convertible version works.
link to doc.
Francesca
Link that works
Fiberglass RV - Document Center - Trillium Table Instructions
Old 03-28-2014, 01:06 PM   #33
Utah
Thanks for that link to the Trillium table. I think I took a look at it a couple years ago and decided it was too complicated for me. Ha! As if what I have done is not complicated!
Anyways, next time I'll give that one a try with the leaf but the one I've built is like Norm's -- It just folds in half on top of itself.
Does anyone have a tip for attaching the front "pull" piece of wood to the drawer supports? I double checked and there's no hold drilled. I'm not opposed to drilling a hole through the metal but I want to make sure it's necessary since there's really not that much metal to work with.
Thanks!
Old 03-30-2014, 01:16 PM   #34
Utah
Sorry, I just noticed my typo -- "hold" should be "hole". There is not a hole drilled in the drawer support through which I could attach the front piece if wood.
Old 03-30-2014, 03:27 PM   #35
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Steve & Rosemary, I believe you could simply get small metal angle and drill a couple of small holes in the slides as close to the edge as possible, then attach with self taping screws. You then could simply use short screws in the same fashion for attaching the wood pull. When I did mine I simply used a piece of slim aluminum flat stock, bent an "L" or 90 degree at each end and used the self taping screws to the brackets.
Hope this helps.
Dave & Paula
Old 03-30-2014, 04:40 PM   #36
Utah
Thanks David & Paula! That helps a ton and makes a lot of sense. I'll give it a try. Thanks!!
Made New Table for Scamp barryra Modifications, Alterations and Updates 1 06-17-2012 11:34 AM
Scamp table alan H Problem Solving | Owners Helping Owners 3 04-10-2010 07:26 PM
scamp table dimensions? andy vaughan Problem Solving | Owners Helping Owners 5 07-29-2008 11:16 PM
WTB: Scamp table andy vaughan Classified Archives 1 11-25-2007 04:37 PM
Scamp table Legacy Posts Problem Solving | Owners Helping Owners 7 06-10-2003 11:21 AM
