Screen Door Opener - Fiberglass RV
Old 09-09-2016, 07:24 PM   #1
Trailer: Casita, 2002 Liberty Deluxe
Screen Door Opener
On my older 2002 Casita, when using the screen door, you had to slide a panel back to access the screen door latch. I took a piece of wire coat hanger and now use it to open the screen door from the inside.
1. Drill two 7/64 holes, one in the top of the screen door panel as shown and one in the latch handle also as shown.
2. Cut the wire coat hanger to 18" inserting one end in the top hole and then make a 90 degree angle at the bottom and insert into the hole you made in the latch handle. Then crimp the end up to make sure it stays in the latch handle.
3. At the very top, trim the wire to about 1 inch showing and put a tiny curly que in the end for your finger to press down on.
4. Cut a small notch in the slider door, to clear the hanger wire you installed.
Now you can use this wire to open the screen door without opening the sliding panel.
Jim er is offline   Reply With Quote
Old 09-11-2016, 06:47 AM   #2
Lercs's Avatar
That's a good mod. I never understood why the manufacturer couldn't make something like this. It is solo annoying to slide that sucker open and then it always gets left open!
Lercs is offline   Reply With Quote
Old 09-11-2016, 11:27 AM   #3
Trailer: 2008 Casita 17 SD
I installed one of these gizmos which seems to work pretty well. Just "bump" it to release the screen door latch without having to open the slider.
Screen Door Opener
Some others have done a different "mod" where they've applied small magnets and ferrous steel disks to their screen door/frame in lieu of the standard handle and striker catch. All they have to do is push against it to have it open outward or just pull on it from the outside to get in. No latch to release, just magnetic holders.
Screen door for Burro Legacy Posts Modifications, Alterations and Updates 28 06-18-2012 05:40 PM
Tire Pressure Eye-opener Ruth C. General Chat 4 06-18-2011 07:07 PM
Looking for screen room or screen panels Deb & Chuck Classified Archives 0 09-19-2009 05:07 PM
Front door holder opener thingy, where to put Kenny&Jackie Problem Solving | Owners Helping Owners 7 06-27-2007 10:08 AM
screen door Legacy Posts Modifications, Alterations and Updates 9 06-20-2003 12:38 PM
» Virginia Campgrounds
