"Senga" - 1991 Scamp 13' renovation - Page 3 - Fiberglass RV
Old 06-03-2012, 08:39 PM   #29
Harlequin's Avatar
Trailer: 1991 Scamp 13'
Virginia
Icebox repairs:
So, there were lots of pre-existing cracks around the hinges and screw holes.
Someone decided to hold the whole thing together with a massive mass of hot glue.
We got all of that outta there. Then put in a piece of aluminum as reinforcing,
epoxy-plastic-welder holding it in place.
Then started epoxy-plastic-welding the pieces into place.
Had to drill for the thicker areas around the holes.
Last piece in, and hole from missing piece filled in with epoxy
Sanded down. looks pretty nasty still because the epoxy is translucent.
Hmm. guess it still needs a bit more sanding, but looks much better.
Harlequin is offline   Reply With Quote
Old 06-03-2012, 08:43 PM   #30
YES it does!
Old 06-03-2012, 08:44 PM   #31
CindyL's Avatar
Illinois
We showed our Uhaul with our Eurovan today at the FunFest. A few lookers, but Sunday is a really slow day.
We did have a new Beetle in our campground pulling a popup. Beetle had a sign in the window that it had 375,000 miles on it.
CindyL
CindyL is offline   Reply With Quote
Old 06-03-2012, 08:56 PM   #32
Virginia
Cool- would love to see pictures Cindy!
Was the beetle a diesel?
FelixVW is offline   Reply With Quote
Old 06-03-2012, 09:08 PM   #33
CindyL's Avatar
Illinois
Sorry, I don't know for sure. I don't think it sounded like a diesel.
Pix later when downloaded. We only took pix of the old pink Beetle with the teardrop yesterday, the cruise, and our setup today. We have lots of pix of VWs from past years, many of which come year after year.
We bought a child's new Beetle electric car at the swap meet that Kevin is planning to try ot match to my new Beetle convertible for our granddaughter to use when she visits and for us to use when showing the car.
CindyL
Old 06-03-2012, 10:07 PM   #34
Virginia
The electric beetle sounds like a fun project! Is it a ride-on/power wheels or an RC car? There aren't a whole lot of 2.0s around over 300k- that would be pretty cool! No rush on photos
Happy Scamper
Old 06-04-2012, 08:12 AM   #35
CindyL's Avatar
Illinois
OK, who is the cartoonist? What an adorable picture! Send it to these folks for your tire cover: Tire Cover Art
As requested, pix of the VW show. We only took pix of the pink beetle towing the teardrop and our setup. I don't know if the pink one got a ribbon. We did not. I will post our setup in the next posting. We also took a picture of a cute tent.
CindyL
Old 06-04-2012, 08:13 AM   #36
CindyL's Avatar
Illinois
Our Eurovan and Uhaul at the VW FunFest
CindyL
Old 06-04-2012, 08:31 AM   #37
Roy in TO's Avatar
Originally Posted by FelixVW View Post
does anyone have any suggestions for where to mount one permanently in the Scamp?
Considering you won't use it all the time, I don't see any reason to mount it permanently. Freestanding allows you to use it outside, in your vehicle or for your pets if you have them.
If you flip out the clips by the handle it will hang from the upper lip of the window. That is how it works on our jalousie. Then if you take a piece of plastic conduit (a little wider than your rear side window) and cut two slots in it, to fit the lower legs it will hold the fan off your window.
If it does not hang from yours, I'd try to find a way to hang it from your new large upper vent. The fan and conduit will store behind the front bunk.
Old 06-04-2012, 08:57 AM   #38
Virginia
Thanks Roy! The ones I have don't have clips on top (or they are in a box somewhere) but they do have the holes through the base of the handle so easy enough to make some wire hooks to the window. The feet seem like they'll prop it away from the window ok but the pvc pipe may be better depending on how much noise the feet make against the glass/wall. I guess the only reason I was thinking about permanent mounting was so that it would be a little less likely to get tripped over, hit, otherwise damaged - good point about using it outside!
Cindy- thanks for the great pictures- the pink bug is pretty cool The Eurovan and Uhaul look awesome! I actually saw two Westy Vanagons (one air, one water) and a white Eurovan westy this morning- the tourists are back in Colonial Williamsburg
The cartoons are mine Neat idea about the spare tire cover! I'll see if I can draw one that would be good in that size.
I put a few non-Senga specific cartoons here:
Egg Toons
Here's one more- just doodles from while I was away this weekend that I colored last night
Old 06-04-2012, 06:16 PM   #39
Hot dang! I can't draw a straight line without a ruler, so I'm totally impressed
Old 06-04-2012, 07:54 PM   #40
Harlequin's Avatar
Virginia
Today's progress.. got the lower bench cushion cover done
Did a bit of removal also. An old owner got "creative" when the floor went to pot. Delightful holes, aren't they.
They took a sheet of 3/4" OSB, covered it in carpet, and just laid it in there on top of it as is. it's getting yucky now too.
CindyL-
Saw a picture from the show.
We know the owners of the red one with white\yellow flames, the baseball bug, and the orange color concept one on the left, if you happened to see those.
Old 06-04-2012, 08:01 PM   #41
CindyL's Avatar
Illinois
We see the baseball one every year, if you mean a New Beetle. We looked closer at it this year. Amazing interior! We also saw the flame one - it matches my VW visor. The orange one did not catch my eye. It may have been there, but I don't remember it. Is it the orange one in the background here?
CindyL
Old 06-04-2012, 08:12 PM   #42
Harlequin's Avatar
Virginia
Nope, not that one. All 3 were New Beetles. It's parked just next to the baseball one, opposite side from the flamed one, with the black bra. it's pretty much stock, so aside from being the color concept limited edition, there isn't much to jump out.
My 1991 Scamp renovation KevinScamps Modifications, Alterations and Updates 64 05-03-2014 06:13 PM
SOLD - 1978 Scamp 13 "Custard Deluxe" For Sale floyd Classified Archives 2 06-02-2009 06:53 PM
1991 "Burro Skamper" (Scamp) on eBay Raya Classified Archives 0 02-22-2009 08:17 PM
"U" Molding & Cabinet doors needed 76' Scamp Dave Baston Problem Solving | Owners Helping Owners 4 06-03-2008 04:27 PM
