setting up a new thermostat for Suburban NT-12-SE Furnace - Fiberglass RV
Old 09-09-2013, 09:39 PM   #1
beardrum's Avatar
Trailer: Scamp 16 Deluxe
We're really enjoying our 2005 13' Scampp, purchased just this summer. Unfortunately, I managed to just about smash the old thermostat with the seat cushion, so I ordered a replacment from Scamp. The new thermostat seems to be exactly like the original. But the installation instructions suggest being sure the heat anticipator setting is correct. According to the instructions I could do that by pulling the whole furnace out to look at what's stamped on the gas valve, but I'd rather not. The furnace documentation itself is woefully unhelpful.
Can anybody tell me what the proper anticipator setting should be? Somewhere between .15 and 1.2 Amps. It is set just uner the cover on the little rotating dial.
Thanks!
Chuck
Chuck
2015 16' Deluxe Scamp, Layout "B"
2007 Highlander
beardrum is offline   Reply With Quote
Old 09-10-2013, 07:16 AM   #2
cpaharley2008's Avatar
That is normally the draw when running, you maybe able to hook up a meter and check it that way. Personally, I'd switch to a digital, where you can set the anticipation which, if too much, can cause heat swings.
Jim
Never in doubt, often wrong
Old 09-10-2013, 07:42 AM   #3
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
....you can set the anticipation which, if too much, can cause heat swings.
'splains a lot about my wife.
I agree with Jim, I finally switched to a digital thermostat this year. It gives you way better control over the heat setting, is more accurate, and displays the temperature in a way you can actually tell what it is. Plus, it allows you to display temps in either C or F.
We pretty much leave ours set at 10C (50F) at night, up to 18 (64.4 F) for rousing in the morning and for evenings should we be in for some reason, and off the rest of the time.
Chuck, with the thermostat you got, you can just install it, then adjust the anticipator a bit either way if the cycling is either too often, or not often enough.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Most folks are about as happy as they make up their minds to be. Abraham Lincoln
Old 09-10-2013, 08:09 AM   #4
Ice-breaker's Avatar
Can either Jim or Jim provide a link to a digital thermostat that you have used in your FG rv's?
Ice-breaker is offline   Reply With Quote
Old 09-10-2013, 08:21 AM   #5
White Rodgers 1E78-140
This is a heat only one, with no programmed settings. What I wanted, sweet and simple (kinda like me ).
2017 Escape 5.0 TA
Old 09-10-2013, 08:23 AM   #6
Can you just look at the old thermostat and adjust the new one to the same position. If your furnace cycles ok you should be fine. If cycles are too short or long you can adjust further as has already been suggested by Jim B.
Old 09-10-2013, 08:50 AM   #7
Here is one I have installed in a couple of units, Coleman 8330A3241 Thermostat Trailer camper RV | eBay
Jim
Old 09-10-2013, 08:54 AM   #8
beardrum's Avatar
As I was changing the bed into a dinette, the cushion swept the old thermostat cover off and bent/broke some of the thingys inside. I have no confidence that what I'm looking at (a setting of about 1.2 Amps) is correct. Hence the question, What's the original setting supposed to be?
It's easy to see, you just have to pull the plastic cover off and read the fine print on the dial inside (or even give me a clock position of the pointer, such as 5:00 o'clock, or 7 o'clock).
But I hear you, it's not a big deal to adjust it after the cycle establishes itself.
Thanks
-c
Chuck
2007 Highlander
furnace, scamp
Suburban thermostat glennco Problem Solving | Owners Helping Owners 9 04-24-2013 11:57 AM
Suburban GT6-3A furnace help, please. Raya Problem Solving | Owners Helping Owners 15 06-22-2012 10:08 PM
Quieting a Suburban Furnace Rob and Linda Modifications, Alterations and Updates 29 04-05-2011 10:05 PM
Furnace and thermostat Diane D Problem Solving | Owners Helping Owners 10 02-28-2011 03:17 PM
Need help with reassembly of 70's suburban furnace Michael Collins Problem Solving | Owners Helping Owners 1 10-13-2010 06:32 PM
