Shade for Mouse. - Fiberglass RV
Old 05-18-2012, 11:47 AM   #1
Mouse's Avatar
Trailer: U Haul CT13
Shade for Mouse.
Going to the Lake San Antonio rally I was worried about being in Mouse during 90 degree weather. So I hacked together a shade for her that did not rely on nearby trees.
There are two curtain rods holding up a cross ways curtain rod with curtains stretched between them. This is the only picture I have...
It did a really good job in lowering the temperature inside to the ambient outside temp. A big improvement over baking in the sun! It got to be 99!
And it keeps bird dropping off the fiberglass!
This is version two.
Still with the curtain rods.
I attached the base to the vertical seam.
I will pull this side out like a tent. Difficult to do now with all the cars driving by!
Currently a curtain rod is attaching the curtains to my awning pole. When I have my awning up I will attach it to that so that more of Mouse's roof is covered.
Mouse is offline   Reply With Quote
Old 05-18-2012, 02:50 PM   #2
Thomas G.'s Avatar
Neat concept - like a fly on a tent.
Old 05-18-2012, 02:52 PM   #3
Which is better than a mosquito on a tent.
Old 05-18-2012, 02:52 PM   #4
Mouse's Avatar
Exactly except for the water proof part.
Old 05-18-2012, 02:54 PM   #5
Mouse's Avatar
Is anyone else putting an awning over their trailer instead of installing an air conditioner?
Old 05-18-2012, 04:03 PM   #6
Noreen Bradshaw's Avatar
Brooke, I have not tried your idea but it looks like it would help to keep the camper shaded.
When I was in Florida I found another way to help keep the sun from heating the inside of the camper.
I cut an insolated window cover (such as you use to cover the windowshield of your car) the right size to clamp on the top window of the jalousie windows on my Trillium. I cut it bigger than the window and clamped to top window it would shade the entire window opening. I found it made quite a difference and I could still see out the windows and the air could still move through them.
So while I do not have an AC, I found that with the help of a small fan and by keeping the sun out of the windows, I was able to keep the inside of the camper reasonably comfortable for myself and my cat.
Noreen Bradshaw is offline   Reply With Quote
Old 05-18-2012, 04:40 PM   #7
Rick G's Avatar
Trailer: 74 Boler 13 ft / 97 Ford Aerostar
Smile
Great idea. I have been seriously thinking about something similar to shade the fridge exterior vents so that the fridge does not get too hot on hot sunny days. That would be easier than maneuvering the trailer so that the fridge is always on the shady side!
Rick G
Rick G is offline   Reply With Quote
Old 05-18-2012, 05:36 PM   #8
Mouse's Avatar
The window shade is a great idea!
Maybe I could attach a couple to the top of my cover to add sun reflection to my sun shading.
Old 05-18-2012, 05:42 PM   #9
jen b's Avatar
Trailer: 1980 13 ft. burro
That's a neat idea!
jen b is offline   Reply With Quote
Old 05-18-2012, 06:31 PM   #10
melissab's Avatar
Trailer: 2008 20 ft Flagstaff Pop-Up (206ST) / 2005 Sienna
How did you attatch the curtain rods to each other at the top (the cross bar to the support bars going down) and how did you attatch the framework to the center seam? Couldnt tell in the pix.
Melissa in Florida
1999 Toyota Sienna XLE
melissab is offline   Reply With Quote
Old 05-18-2012, 06:46 PM   #11
Mouse's Avatar
I used curtain rod holders that came with the rods.
I screwed them into the top of the rods.
I tighten this ring to hold the rods in place.
Drilled holes and bolted them on to the seam.
I'm going to try towing Mouse with them in this position. I'll see if I need to support the bottom of the rods better.
Old 05-18-2012, 07:56 PM   #12
melissab's Avatar
Very Clever!!! Thanks for the add'l pix/explanation. I've been pondering a way to provide shade as not all Campgrounds in FL have shade trees at every site. Those little palm trees dont do a whole lot.
Melissa in Florida
Old 05-18-2012, 08:00 PM   #13
Mouse's Avatar
Be sure to post your version!
BTW: The cost was about $40 at Ikea!
Old 05-18-2012, 08:25 PM   #14
Trailer: Cardinal (Restoring)
I liked your set up @ Aqua Caliente too. Brooke you are the smartest. Who needs men???? Nothing like a very accomplished woman. I think all us handy gals should plan our own NOG. Are you coming to Lake Casitas?
RRIZZO is offline   Reply With Quote
Old 05-18-2012, 08:30 PM   #15
Mouse's Avatar
I'm not good at planning that far in advance!
But I had a great time at Agua. So maybe.
Guys are useful! Mine just texted me that he has a Patxi's pizza and is coming home!
Old 05-18-2012, 09:01 PM   #16
Could you come to train mine.....bringing home dinner! You can always get into Lake Casitas at a closer date.
Would love to see ya again
Old 09-21-2012, 07:42 AM   #17
Bonnie n Claude's Avatar
Name: Bonnie and Claude
Trailer: N/A
...I cut an insolated window cover (such as you use to cover the windowshield of your car) the right size to clamp on the top window of the jalousie windows on my Trillium. I cut it bigger than the window and clamped to top window it would shade the entire window opening. ...
What did you use to clamp the car windshield cover on?
Bonnie n Claude is offline   Reply With Quote
Old 09-21-2012, 09:35 AM   #18
I started out using dollar store clamps, which worked fine. I had to remember to remove them bf closing the window if the evening got cool enough to want the windows closed. Since then I have used wide elastic bands, which also work and the window can close almost completely shut without removing them.
Old 09-21-2012, 12:29 PM   #19
Trailer: N/A
Thanks, Noreen. Looking forward to trying this when in Florida next month. Great suggestion!
Tarp for Shade? melissab General Chat 19 03-18-2012 05:05 PM
I just bought Mouse a U-Haul CT 13 Mouse Hi, I am.... 14 02-05-2012 06:46 AM
Mouse Calibrator Bob H Jokes, Stories & Tall Tales 1 09-02-2007 01:38 PM
Mouse Proofing Sonny Care and Feeding of Molded Fiberglass Trailers 21 06-25-2007 10:06 PM
Wow my mouse works Legacy Posts General Chat 19 05-22-2003 04:02 PM
