Sheet of plywood as finished floor? DIY parquet? - Fiberglass RV
Old 01-05-2016, 02:50 PM   #1
Trailer: 1979 Scamp 13'
I'm sort of tossing around a few ideas for a floor to replace the vey worn carpet in my 1979 13' scamp
Number one is a painted floor, with some sort of design, either medallion in the center or full time like effect. Thinking of possibly using a sheet of 1/4" plywood? Does that even sound feasible?
Idea 2 is to cut triangles out of 1/4" plywood and basically nail or glue them into place to make a homemade, no tongue and groove floor. Thoughts?
Zennifer is offline   Reply With Quote
Old 01-05-2016, 03:06 PM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Think I'd paint the floor and find a carpet runner with a pattern you like before trying to do a puzzle on the floor.
Old 01-05-2016, 03:21 PM   #3
No carpet!!! . I have a big aversion to carpet...probably because half of our camping is on a beach.
But, you think that a sheet of plywood properly attached would work? Could I just put it right over the existing carpet, I wonder?
Old 01-05-2016, 03:33 PM   #4
Trailer: Bigfoot B-17 CB
Wood flooring is made from harder wood. Plywood is usually soft fir or pine which will wear quickly. A few coats of good varnish would help some but you would not have a long lasting finish. Nailing or gluing would make later floor replacement harder. I want to do a new floor and have been looking at some very reasonable flooring at a nearby Habitat for Humanity store. I think the free floating plank flooring is the way to go but I'm sensing your creative instincts are kicking in. Also pay attention to the weight you are adding. I would love a ceramic tile floor but do not want the weight. Best of luck with your project.
Old 01-05-2016, 03:46 PM   #5
I assume you've considered and ruled out the more conventional choices such as sheet vinyl, Allure vinyl strips, laminate…? And eco-friendly options such as linoleum, cork,…? Nice thing about a 13'er is the small square footage allows you to experiment with pricier materials. Personally, I'd look for something that can be installed as a floating floor, no glue.
I'm not keen on the parquet floor option, having grown up with wood floors. They'd require some ongoing maintenance, they'd be subject to warping in the extremes of temperature and humidity in a travel trailer, and, if you glued it down, it'd be a bear to re-do down the road.
But what the hay… if you really want to give it a whirl, I say go for it! You could even stain the pieces several different shades and create a mosaic. The only person you have to please is yourself.
Old 01-05-2016, 03:53 PM   #6
We also camp at the beach often. We have a large 3'x3' rug that covers most of the center floor, and I LOVE it!!! I can pick it up and shake it outside once or twice a day in less time than it takes to sweep a hard floor, and between shakings, it doesn't feel gritty underfoot.
I think I'd take up the carpet. How old is it? What's living in it? If it's foam-backed (which I suspect), the 1/4" plywood you mentioned would probably flex too much.
Old 01-05-2016, 05:57 PM   #7
Trailer: 1975 Boler
Quebec
I have used Traffic Master vinyl flooring in my basement and in my business: TrafficMASTER Flooring and TrafficMASTER Allure Flooring .
They imitate all kinds of finish, even ceramic! Being 100% vinyl, it's durable and easy to install. And the pieces stick to each other but not to the floor...
Uncle Cereal is offline   Reply With Quote
Old 01-05-2016, 06:50 PM   #8
I lucked into a couple of rolls of 1/4" cork underlayment and I used that to cover the 3/4" fiberglassed plywood. Over this I installed a vinyl plank fake wood floor. It looks good and has a little more insulation and cushion.
We also have some carpet runners down the middle that can be pulled out and the dirt shaken out.
Our hope is that a small broom will sweep the dirt out and the runners provide a little more comfort.
redbarron55 is online now   Reply With Quote
Old 01-05-2016, 06:56 PM   #9
Saskatchewan
Our Trillium is getting new flooring in the spring. We've been thinking about it for a couple of years and the time has come. What is going down is a chunk of leftover stuff from re doing the house floors. It is like linoleum in a weathered wood plank pattern. Guaranteed for ten years which should last our our camping days which are only years of six months!
Hazel in Sk is offline   Reply With Quote
Old 01-05-2016, 07:56 PM   #10
Name: Frederick / Janis
Trailer: Previously Scamp 13 2002,2016. Scamp 16 on order
I had saved some left over oak colored pergo type flooring in the basement. When I re-did the floor in the 2002 Scamp, there was plenty to do it. Not enough left over for another room in the house, but plenty for the Scamp.
bpfick is offline   Reply With Quote
Old 01-05-2016, 10:50 PM   #11
Yes, it's more about being unique and pleasing myself than anything else. Though I am cheap. Cork is actually another other option i am strongly considering...especially since it is warmish to bare feet.
We might be gifted the remainder of a stash of Brazilian cherry 3/8" engineered floating floor from my FIL's airstream redo a number of years back and might use it as its held up beautifully under high use in that trailer...but I'm not quite sure I want the look of strip wood floor, either.
I've also toyed with those commercial type flooring tiles cut into mosaics type patterns. Just coalescing ideas into a cohesive "design plan" so the small space looks like it was meant to be��
Old 01-05-2016, 10:52 PM   #12
I couldnMAYBE come around to a fee standing carpet. kids and sand and dog and mud and carpet....
Old 01-05-2016, 11:05 PM   #13
Maybe bring in some Buddhist monks when you have enough sand on the floor.
Old 01-06-2016, 06:00 AM   #14
CampyTime's Avatar
Trailer: Scamp 13' Standard
My Scamp 13 came with the factory carpet. It is what it is. I would prefer a vinyl one piece floor myself. No seams, just broom and sweep away grit. Although I keep an entrance mat at door, I am frequently using a whisk Broom on sand, dirt and dog hair. When I get home, I take out my handheld Shark and vacuum away. I would think a one piece vinyl would provide for no seams and a lot less work, but possibly chilly under foot? This is really a preference thing. Jon's idea of a free floating floor is good too. If you don't like it, no glue to remove. But you do have seams. If it's not installed "tight" enough they can separate. This is what's going on in my mud room at home (installed by a friend if mine). Your choice, but I'd prefer no carpet if I had a choice. This is how trailer came to me, sos I lives with it.
Plywood subfloor over original floor???? shumiron Problem Solving | Owners Helping Owners 5 10-15-2015 02:00 PM
Plywood floor - what do I look for? Melanie Problem Solving | Owners Helping Owners 6 07-03-2011 08:38 AM
Plywood floor replacement supplies Mike Shackelford Problem Solving | Owners Helping Owners 3 10-08-2009 07:17 PM
Floor replacement Options - OSB vs Plywood. Oliver P Problem Solving | Owners Helping Owners 11 08-11-2009 08:34 PM
Plywood Floor Replacement 72 Boler Annie T Problem Solving | Owners Helping Owners 5 07-24-2007 10:19 PM
