Shelves above dinette - Fiberglass RV
Old 04-01-2019, 03:51 PM   #1
judi z's Avatar
Trailer: 76 Trillium
Hi, I would like to fabricate shelves above my Trillium's dinette, maybe also above the front gaucho. How would I go about doing this? Do I need to affix backer plates to the FG or just go off the window support? Thoughts on shelving material and other considerations greatly appreciated.
Cheers,
Judi
judi z is offline   Reply With Quote
Old 04-01-2019, 05:10 PM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Judi, all of the shelves in my Trillium 4500 are fastened metal brackets that are fastened to the interior window frames.
EDIT: I neglected to state that there are shelves on every wall, and that the where shelf terminates at a cabinet, the shelf is also fastened to the cabinet.
Old 04-01-2019, 05:16 PM   #3
Trailer: 2013 Escape 19
It goes without saying that rotten wood makes a poor shelf support. So be sure to make sure wood is good.
Rear shelves are attached to the upper cabinet and the closet. as well as the top wood on all three windows. Front shelf is attached to kitchen cabinet, then the wood above front window. And as I recall, the bulged two layer vertical fiberglass beside the door.
Old 04-01-2019, 06:39 PM   #4
judi z's Avatar
wood is good!
Re-did the windows last year. I used pvc wood composite in lieu of wood - will never rot again. Couldn't find any info on it being used by others, but so far I'm happy with it. For the shelving that exists with cupboards, is there a backer board glassed/glued to the fg to attach cabinets?
Cheers,
Judi
Old 04-01-2019, 09:23 PM   #5
Trailer: Trails West
Cheers,
Judi
Composite pvc wood typically does not have the same screw holding power that real wood has. Those white trim pvc boards sold at Home Depot or Lowes have a softer foam inner core. So don't use heavy shelving material or put heavy objects on those shelves if that is the type of PVC lumber you used.
For the structural types of PVC lumber used for building decks and deck railings you need to use a #7 screw that has a coarse thread to get good grip power.
Old 04-01-2019, 10:08 PM   #6
Took over 40 years for three pieces of wood to rot on my Trillium, with no signs of any maintenance ever. So I replaced them with new wood. I plan to maintain trailer and it’s stored inside too.
Shelves are all attached to the window wood. Lightweight fiberglass shelves. They are nice but not super useful. But better than no shelves.
Check my Trillium Project Page: https://www.facebook.com/Bills-1977-...dmin_todo_tour
Old 04-02-2019, 01:44 PM   #7
Kai in Seattle's Avatar
We put a white truck lining food-safe plastic shelf above our galley to hold things like cups, tea canister, Kleenex, etc. It needed a center support because it was slightly bendy and sagged until Paul braced it up. But Amerigos have an inner paneling so attaching it was easier than to single-hulled rigs.
Semper ubi sub ubi.
Adding a temp bunk above dinette? Lorrie Modifications, Alterations and Updates 2 06-30-2018 08:35 AM
Help with cabinet height and depth above dinette area SojournBill Problem Solving | Owners Helping Owners 3 09-09-2013 12:37 AM
Wanted: Above Dinette Storage Shelf with light for Trillium 1300 Rodre Classified Archives 2 04-15-2011 10:25 AM
Heat protection above stove Legacy Posts Problem Solving | Owners Helping Owners 7 07-15-2003 06:07 PM
