Well I did it again with another "improvement". With a little help from Don Willis and Carl Chinn.
Not sure about the rest of you all but with my
Casita 2000 16' SD I have the AC in the front of the TT and above the AC is a closet. Well this is where I built a Shelf unit with 2 platforms. This make 3 seperate areas for Mine, Julies, and Michaels clothes. And now they won't be all mixed up together.
I made then out of Birch Plywood and PVC pipe and fittings. It is able to break down and take apart so that if I even need I can get the shelves out of there to work on something... say the AC (which I have already replaced so I hope that will not be the case)!
Thanks Don and Carl for your help... now to move the fire extinguisher to the right of the closet door for easy access. here is a photo of it in place.<img src=http://www.fiberglassrv.com/board/uploads/3e82437e5371bP3260002.jpg/>
