03-29-2007, 01:11 AM
One of the down-sides of my Scamp is there's a fair bit of storage space under the street-side dinette bench, but some of it is unusable because (by design) the shore-power cable gets stuffed in through a hole in the side of the trailer into that space, and it does not stow into that space neatly. It just piles up all over the place.
I cut the cord and turned my shore-power cord into an extension cord that plugs into a 30 amp locking connector designed for yachts.
I made plywood disks that fit inside the old power cord port and around a "Marinco 304EL-B Contoured 30A Power Inlet with Rear Safety Enclosure" that I got at West Marine ($70). I used lots of 5-minute epoxy to glue the two 1/2" plywood disks to the new power connector rear housing, cut my cord so about 6 inches could be pulled out the side of the trailer, trimmed and stripped the wires and attached a Home Depot female locking connector ($14) to the longer wire cord I'd cut off. By this time the first round of epoxy had set, so I wired up my new Power Inlet connector and used more 5-minute epoxy to glue the assembly into the old trailer cord port. I made a butyl-tape gasket, pre-drilled some pilot holes and used three 1-1/2" sheet metal screws secure the connector to the plywood ring after the second round of epoxy had cured.
The new port closed.
The new port open.
And plugged into my newly made extension cord.
Inside wiring. Note I had to cut the old cord port so the power cable had room to pop up and through the old housing.
Now I can neatly coil and store my shore power line with the rest of my "setup" supplies.
--Peter
03-29-2007, 05:39 AM
03-29-2007, 08:46 AM
Trailer: 1972 MKP Grandesse T (made in Denmark)
Absolutely thank you! Great idea!
03-30-2007, 05:13 PM
Mine does the same wadding back there.
In my 13, the former owners actually glassed in a "Box" to contain the cord. Pretty cool! In the 17, I am going to use a tote bin to block the cords snaking into the rest of the cubby. It can snake into the bin instead.
I will have to crawl into the cubby and fasten the bin to the floor. Fortunaetly.. I fit in there!
03-30-2007, 05:24 PM
Here's one done by Nevin Lescher on his Scamp 13' (before he sold it); he didn't use the commercial twist-lock (if someone trips over it, it will just disconnect rather than risk breaking something) and he also made a convenient outside GFCI-protected outlet.
03-30-2007, 05:28 PM
Trailer: Bigfoot 25 ft / Dodge 3500HD 4X4 Jake Brake
Oooo, I like it. Very nice.
ALL, these ideas are good.
03-30-2007, 10:26 PM
That's nice, too. I would have considered doing something like that, but we already have a (very convenient) curbside 110 outlet, and our power hookup is on the (less useful for an outlet) streetside.
I hadn't thought about there being advantages to not twist-locking the power cord, though. Chances are that, if I'm hooked up to shore power, I'll probably also have a garden hose hookup to the water spigot inches away from the electric hookup. If you were gonna trip on one, you'd probably trip on both.
What I'd like to find is a twist-lock connector with a 90-degree bend in it so the power cord and connector drapes down the side of the unit rather than sticking straight out several inches, but that's a minor worry.
--Peter
03-31-2007, 02:01 PM
Trailer: 1987 17 ft Burro
That's really NICE. My shore line cord fills my entire closet - but - if I detached it,there's always the chance I'll forget where I stuffed it!! . Gina's box sounds like a foolproof idea for us. Little things make a lot of difference when every square inch counts.
03-31-2007, 05:19 PM
When I ditched the converter in my Scamp 13', I also ditched the 30Amp@120VAC power cable because I didn't have a/c and saw no reason for the weight and space penalty for the cord -- I replaced it with a short 15A@120VAC cord and use a household extension cable for the infrequent times I am connected to shore power -- The extension cable does double duty (I like double duty stuf!) between the inverter clipped to the truck or trailer battery and whatever I'm powering inside the egg.
I gave the 30Amp cable to a friend and he put a female end on it to use as an extension cable for his Avion 26'.
04-02-2007, 06:28 PM
Trailer: 87 Scamp 13 ft
Pete, I now own this trailer. The trailer AC is wired to the load side of the GFCI protecting the entire AC system.
04-03-2007, 07:28 PM
I know this sounds good, but it actually doesn't do that much for a fiberglass RV owner, where just about everything in the trailer is insulated from the ground.
In electricity the current into a load always equals the current coming back out. GFCIs monitor the current going in the "hot" wire connection and the current coming back on the "neutral" wire; when one wire has more current going through it than the other the GFCI knows that extra electricity is finding its way "out" somewhere else (such as through the feet of someone standing on the ground while using a power tool with a frayed electric cord) and it turns the electricity off.
That's a good thing, because it saves lives, but since almost all the surfaces in our trailer are things like fiberglass, plastic, and wood, which don't conduct electricity, the only way for the "current in" to get back "out" is through the neutral wire, so the GFCI will never trip. Once again, this is really OK, because with no other way "out" the electricity can't go through someone inside a trailer using that same power tool with a frayed electric cord
--Peter
04-04-2007, 02:16 PM
Trailer: 1978 UNIK
Attachment 7060
Attachment 7061
Attachment 7062
The new port open.
Attachment 7063
Attachment 7064
--Peter
Peter,
Thanks for the insight.
I was thinking about doing the same thing, but am putting the trailer's receptile INSIDE the unit and just passing the power cord thru the opening. That way I don't have to modify the outside cover. I can even unplug from inside and start coiling it up from there.
David & Terry Sergison
04-04-2007, 06:03 PM
What about the situation where a defective appliance, plugged into the trailer's 120VAC, is being used outside the trailer by someone standing in a puddle? Or someone inside the trailer has one hand in running water from the city water connection and the other hand on a defective appliance? To say nothing of the fact that the frame is grounded both through the shore power cord, the tongue jack and the stabilizers.
I prefer GFCI on the basis that it doesn't hurt and it might help (I had one trip at home once when I was standing barefoot on the ground and had a hand on a reversed connection, which was an excellent setup for a heart-stopping experience, so I am a believer). I replaced one of my factory 120VAC outlets inside with a GFCI and configured the wiring so all the outlets were protected. It's likely overkill in my case, because in the few instances where I use shore power, I am using the CG's GFCI-protected 15A@120VAC outlet, but it wouldn't be overkill for folks using the CG's 30A@120VAC unprotected outlet or when I am just plugged into someone's unprotected outlet.
04-05-2007, 05:33 AM
Trailer: 1996 19 ft Scamp 19 ft 5th Wheel ('TOGETHERNEST' SLEEPS 8
Just a litle hindsite here I also did this many years ago with a regular 3 prong plug and after about 4 days of being plugged it at a camp using the air I found that the non locking conecter would slowly work itselfe out and as it got near unpluging and was making less contact and would get hotter as it came out . So replaced it with turn to lock type. I found that a 10 foot cord will work at most sites and carry an extension for the others. I also added a small LED lite just above the plug so when you plug it in you can see that you have power.
04-08-2007, 01:19 AM
Having just stumbled around in the dark in the rain disconnecting my trailer those LED lights are sounding real useful right now!
--Peter
04-08-2007, 01:29 AM
Peter,
I didn't actually modify the outside cover/door: I just popped it out of its hinges. The cover you see there now is part of the new shore power connector.
One thing you might consider before making your modification is mice and other vermin. I don't know about your shore power access port, but mine looked like an easy way in for mice and other pests that might climb up the power cord and into the trailer.
--Peter
04-09-2007, 05:32 PM
Trailer: 17 ft Oliver Legacy Elite
Hi Peter and thanks for posting that great idea. # 2 on the honeydoo list now. Did you screw fasten the wires to the new connector like a household plug? Being electrically challenged (took 3 tries to get 3rd brake light to work) the only thing I hate more than 12v is 110!
Thanks again, Chuck H.
04-09-2007, 10:23 PM
Yes, very similar. Green wire to green screw connector, white to silver, and black to brass. It might be a good idea to plug in when you're done with a wiring tester like this SnapIt Circuit Tester.
There is one additional wiring complication, though. When I did my wiring job I simply cut the heavy rubber case on the 30 amp cable back with a utility knife to expose the insulation covering the black, white, and green wires. The challenge with cutting the shore cable back is if you goof and cut past the rubber sheath into the insulation covering the individual wires you have to strip the cable back even further and go for a clean cut. If you blow it multiple times you may wind up eating a couple feet of shore cable up and not have enough left to run from the inverter box to your shore connector.
Given that you're not an electrical wiz I'd suggest another method: go to the hardware store and buy some 10 guage Romex NM-B 10/2 cable. Get enough Romex to make it from your inverter box to the shore connector port with a couple of feet to spare.
By going with the Romex you'll be able to use the pre-stripped ends of the shore power cable for the plug at the trailer-end of the cable, you'll wind up with a longer shore power cable, and you'll find stripping the Romex back is very easy to do.
--Peter
09-09-2012, 05:06 PM
Trailer: U-Haul VT16
