Shur Flow pump add on - Fiberglass RV
Old 01-20-2008, 11:59 AM   #1
I had a surpump put in for the shower drain and sink... they had redone the shower drain which was find, but the sink if any water was in it kept backup up thru the floor.
even tho you cant see it.. they put this nice enclosure around it. Its accessible to clean the filter ......
even tho I do have RV antifreeze put in I am putting some cardboard around it tonite as this week its to get into the "teens'..... cardboard makes pretty good insulation...
Old 01-22-2008, 06:00 PM   #2
Paul and Libby Smith's Avatar
Trailer: 1994 19 ft Scamp 19 ft 5th Wheel / 2001 4wd 6cyl Silverado
I recently tore out the bathroom floor in my 94 5th, removed the awful looking canvas wall. installed a new shower wall and I dropped the floor approx 6 inches, built a box and fiberglassed it drilled a drainhole and painted with gelco, the walls were covered with fiberglass re enforced plastic panels, recently installed a shurflo 2.8 gallon water pump underneath, and will hope for the best Paul
Paul and Libby Smith is offline   Reply With Quote
Old 01-22-2008, 07:03 PM   #3
Paul.. i am sure you did a great job... and everything will work good.. should have showed some pics...!!
My bathroom has that horrible elephant skin on the bottom half on one wall and in the back of the toilet. i dont like... but its in good shape so I will just leave it. I scrubed and cleaned it up really well when i first got the trailer so its tolerable..
I do like the box they put around the pump.. then its not exposed to the outside of the trailer and will keep it alot cleaner and protected from road grime or whatever.. My trailer is a 89. At this point I have to say its probably been 98 % redone on replaceing and repairs!
Old 01-23-2008, 07:47 AM   #4
Trailer: 17 ft Casita Spirit Deluxe 2008
Well, you know the old saying that a hammer will last forever if you just change the head and handle once in a while.
Mike
Michael J is offline   Reply With Quote
best technique for air flow with Maxx Air Fan with 13 footer lloyd cicetti General Chat 4 06-18-2010 05:04 PM
Fantastic Fan Install - switch to change air flow? Kurt in BC Problem Solving | Owners Helping Owners 29 11-11-2007 04:58 PM
Fantastic Fan Air Flow Kurt in BC Modifications, Alterations and Updates 3 08-11-2007 05:36 PM
Over-Flow Campgrounds Nancy in Oregon Oregon Gatherings 0 05-15-2007 09:51 AM
Anyone heard of an Air-Flow Roger Smith Care and Feeding of Molded Fiberglass Trailers 16 01-04-2007 06:15 PM
