Side Table *Photos* - Fiberglass RV
Old 11-03-2008, 05:04 PM   #1
Flygal's Avatar
adding side table for the "lounge".....found these hinges for 15.00 at the rv store had the shelf already left over from another project installed this so I have extra shelf space for my beverage when the u dinette is set in place...a dvd player for when the bed is up....or a what not shelf when needed
Flygal is offline   Reply With Quote
Old 11-03-2008, 06:16 PM   #2
Flygal's Avatar
what nobody loves this????/come on show a gal some love here!
Old 11-03-2008, 06:19 PM   #3
Well I do. I don't have an area to put a table like this, but I can appreciate the effort. Where you mounted the table the area looks like it might be over the wheel well? I was just wondering why you didn't mount the table on the cupboard door and make another opening into that particular area. But without seeing it, I can only speculate. Great idea, good job
Old 11-03-2008, 06:31 PM   #4
Flygal's Avatar
I didn't put the shelf on the door because I always open that thing...afraid the extra weight might pull on those 6 screws holding the door on.........you are correct that is the wheel well area but there is a large gap when you open the closet so the machine screws that go thru are still inside the trailer. The shelf sits low like a coffee table...just another spot to set stuff (dvd player...my drink...ect)
Old 11-03-2008, 07:05 PM   #5
Charlene Urso's Avatar
Trailer: 2008 21 ft Bigfoot
You are indeed a clever one, Brandy. Of course, I realized that from the first time I saw your "name tag" hat with the fish avatar so cleverly prominent in front. You are one to watch! Nice work.
Charlene Urso is offline   Reply With Quote
Old 11-03-2008, 07:55 PM   #6
Dave Mac's Avatar
Trailer: Burro 13 ft 1979
Very nicely done!
Dave Mac is offline   Reply With Quote
Old 11-03-2008, 08:20 PM   #7
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Well, seeing as how I just got back on here and noticed this creation Brandy, I'm STEALIN' IT!!!!
What s souper idea for mo'space!!
Old 11-03-2008, 09:08 PM   #8
Trailer: Fiber Stream
Talking
Ya gotta adjust the nomenclature here...
Instead of a dinette with a side table... call it a [b]Lounge with a [b]flip-up Cocktail Bar.
That would go better with the Disco Ball and the Red Lighting.
Old 11-03-2008, 09:24 PM   #9
Gina D.'s Avatar
West Coast USA
I did this in my 13 foot Burro. I used one of the overly finished cubby covers the former owner made.
when in bed, was VERY handy as a side table for snacks, drinks and my glasses.
Old 11-03-2008, 09:30 PM   #10
Flygal's Avatar
brilliant.....gotta come up with a trailer name now........hum...
Old 11-03-2008, 09:32 PM   #11
Flygal's Avatar
must not look at floor.........so ...so nice
Attachment 16617
Old 11-04-2008, 09:26 AM   #12
Doug Mager's Avatar
Brandy, if you are concerned (as we were) about the closet door falling down/off (remember we added a full length mirror to the outside of the door?), replace the screws ONE AT A TIME with a nut n bolt assembly. It may not look all that sharp, but ours turned out not too too bad. Just be sure to do this one screw at a time (to help insure proper door/hinge alignment and rid the possibility of the door falling down in the process), drill the screw hole all the way through the door and insert an appropriate sized bolt (think small here) through to the other side and add on the nut. We used stainless ni-lox nuts and stainless bolts to avoid any problems with oxidization from condensation.
....an adendum to this BORING idea. First drill a very small 'pilot' hole through the door (in the screw hole, from the inside, out), then switch to the drill bit size you intend to use for the project and then drill this larger sized hole FROM THE OUTSIDE going in. If you drill from the inside out, the drill bit will 'explode' the other side of the hole in the door, making a bit of a mess.
Old 11-04-2008, 10:03 AM   #13
Carolyn Patterson's Avatar
Trailer: 16 ft U-Haul VT / 2004 GMC Safari
Just FYI...
I was in my local Big Lots store, and there on the shelf in the cleaning/organize section, was a flip up shelf - complete with brackets and made of thick PVC. $12.00. I don't remember all the specifics, but do know that it's 36 inches wide - I just don't recall how deep they were. Came in white. Nice! I just can't figure out where I could put it in my trailer, but I'm still thinking about it!!
Carolyn Patterson is offline   Reply With Quote
Old 11-04-2008, 10:52 AM   #14
Tim Wood's Avatar
Trailer: Class B for now
NY
Nice Job and those flip -up tables always seem to be very handy, I'll have to make one for the Horizon. Tim
cutting table bench side opening johnsoba Problem Solving | Owners Helping Owners 4 04-20-2009 08:50 PM
2000 Watt Yamaha vs Honda side by side Larry Harmon General Chat 13 03-05-2009 08:00 AM
TAKEN - Casita 17'SD side table top Paul Bostick Classified Archives 3 11-04-2007 03:44 PM
1978 Trillium Side Table Question Daisy Problem Solving | Owners Helping Owners 1 05-17-2006 04:55 PM
side table james kent Modifications, Alterations and Updates 4 04-05-2006 01:54 PM
