Simple question about rivets and nuts - Page 3 - Fiberglass RV
Old 10-24-2013, 01:23 PM   #29
Originally Posted by ShawnKK View Post
Someone said something to the fact of a nut on the end?
Scamp shots rivets into acorn nuts where they will be visible on the inside of the trailer - usually around cabinets etc. Just to pretty it up.
Old 10-24-2013, 01:40 PM   #30
ShawnKK's Avatar
I just had to call Scamp. They use all Alum rivets with washers and to fancy it up he said acorn nuts. So yes they are just pop rivets. Buy them at your local store people.
The washer would be used to expand the area that it holds on the inside. It also can be use if the rivet is too long. Scamp sells nothing special on the rivets. So buy the cheapest you can find. I also noted the size they use on their web site if your not sure. Remember to always use the Butly tape and or seal and make sure the rivet goes in easy and not tight. A rivet hole should never be a tight hole.
ShawnKK is offline   Reply With Quote
Old 10-24-2013, 02:29 PM   #31
I just had to call Scamp. They use all Alum rivets with washers and to fancy it up he said acorn nuts. .
Did they actually say they used washers? Never seen a Scamp with washers on the rivets - only acorn nuts or nothing ...... must be something new. Only have seen washers used on bolt on parts such as awning holders etc.
I know I and a few others here put a bit of butyl tape on the bottom of the snap cap retaining ring prior to attaching the rivet. Works well.
Old 10-24-2013, 02:38 PM   #32
ShawnKK's Avatar
I have no reason to lie about that. But putting a washer on a rivet is a norm. Nothing wrong with that at all. Matter of fact it is better to use a washer. It covers more area for the hold. Just make sure you add it to the thickness so you put the right size rivet in. The "Military" does it too! We know how you like that so I guess it is sold now. Lol.
Has far as putting Butly or seal on the bottom of the rivet is also a norm. But make sure you put it under the head of the rivet too. Not sure if Scamp does it but I would say they don't. Time is money.
Old 10-24-2013, 02:57 PM   #33
I have no reason to lie about that..
Wasnt suggesting you were just wondered if perhaps there may have been a miscommunications in regards to under what circumstances they use washers. As said none to be found on my scamp where they have used rivets and I have helped a number of folks fix a few things on much newer than mine Scamps and had never seen one... simple that. Agree using them is a good thing and wonder when they started to use them.
Your also correct Scamp does not use butyl tape on rivets.
Rivets, Acorn nuts, Rivnuts etc. Dan B Care and Feeding of Molded Fiberglass Trailers 45 11-22-2016 07:21 AM
rivets, caps, washers and acorn nuts beardrum Care and Feeding of Molded Fiberglass Trailers 30 09-12-2013 09:48 AM
Simple question gage Problem Solving | Owners Helping Owners 19 06-03-2013 09:20 PM
Nuts n' bolts instead of rivets? dylanear Modifications, Alterations and Updates 20 05-31-2012 01:57 PM
Rivets and Acorn Nuts Steve L. Modifications, Alterations and Updates 6 11-16-2005 08:36 PM
