Simple question about rivets and nuts - Fiberglass RV
Old 10-23-2013, 09:01 AM   #1
Trailer: scamp
New Mexico
Hi, we just bought a 16' scamp and there are a number of changes I plan to make but some of them require removal of the fiberglass interior parts.
I cannot figure out how to remove the nuts from the rivets. Are they meant to be permanently on there? When I turn the nut, the whole rivet turns. I could drill the rivet out but then I'd need to use some bolt/nut combo when I rebuild.
What are others doing? If this has been addressed elsewhere, I'd sure appreciate getting pointed to that discussion.
semievolved is offline   Reply With Quote
Old 10-23-2013, 09:16 AM   #2
The nut is not used as a nut its a decorator item. The rivet is swelled into the nut just to hold in place. Drill out the rivet from the outside and pull out the rivet. hold the rivet body with a pair of vice grips and unscrew the nut from the rivet shank. Now when you reassemble put in the rivet and have someone hold the nut on the end while you set the rivet. the rivet swells inside the nut and pulls the assembly up tite.
Old 10-23-2013, 09:28 AM   #3
Trailer: scamp
New Mexico
Steve - thanks much for that answer. I was afraid that's how they worked. So, is there a good place to get a bunch of those rivets that you know of and are there typical lengths that are used? It looks,like the ones that pass all the way through the exterior shell are maybe 1.25" or so?
Old 10-23-2013, 09:39 AM   #4
ShawnKK's Avatar
I don't have a Scamp but looking at the Scamp website they only show the 3/16 rivets. No idea scamp used the ones with the "nut".
When you drill out the rivet check the hole where it came from. If the hole is over sized from wear and or drilling out you would want to go to the next size up.
When drilling out a rivet head try not to go into the FG, just drill enough to break the head of the rivet. You may have to go counter clock wise on the drill before you drill it out. "I" would not grind off the head. Were working on FG not metal.
I looked for a you tube vid on it but saw nothing that will help you out. If you never drilled a rivet out before , try it on something else first. Don't use too much pressure.
Hope this helped a little bit?
PS, if the rivets starts to spend, have someone hold it on the other side like with vise grips or your 3/16 hole will be over sized and another 3/16 rivet wont do much good in a over sized hole.
ShawnKK is offline   Reply With Quote
Old 10-23-2013, 09:54 AM   #5
There are a number of threads on this list that will help you regarding the correct sizes to use. Remember though that when making changes to your trailer that a number of the interior fiberglass cabinets are actually supporting the trailer - hate seeing a cracked eggs due to the removal of something that was were it was in order to give it structural support.
If you cant be bothered to search for all the right sizes, you can buy from Scamp a package that contains all the rivets and snap rings and caps they use on their trailers. Enough to replace the whole trailer if needed. Not sure if it shows on their online shop or not but if you call the 1-800 number and talk to the parts department they will be able to advise you on it.
Scamp Rivet Size List
Scamp Pop Rivet Lengths
Rivets, caps washers and acorn nuts
Old 10-23-2013, 11:03 AM   #6
I bought my rivets from Scamp. Its very hard to find 3/16" rivets in lengths longer than 3/4" or so. Even then I had to cut some longer rivets down to fit properly. Since getting the Harbor freight air riveter to set these rivets it been no fun, my gal loves to use the air gun so I am reduced to helper instead of the other way around. Last week we added new caps and bases to almost a third of the rivets in the trailer in a few hours. And our hands didn't even hurt any.
3/16" Air Hydraulic Riveter
Old 10-23-2013, 11:12 AM   #7
Roy in TO's Avatar
Originally Posted by stevebaz View Post
the Harbor freight air riveter 3/16" Air Hydraulic Riveter
Thanks for the heads up. Reasonably priced. Will have to get one on my next trip to the USA.
Old 10-23-2013, 11:42 AM   #8
I actually ended up having to cut down by hand a number of rivets and that doesnt always work out to well - depending on the size of the rivet, so I had to buy a real *BIG* box of one size I only needed about a dozen off as I could not find anywhere in smaller quantities - now have a bunch of rivets I will never use up in my life time or the trailers. In hind sight buying everything I needed in one bag from Scamp would probably have been a lot cheaper than buying packages of all the sizes I needed and then never using 3/4 of them not to mention the time wasted trying to find the right sizes.
Old 10-23-2013, 11:51 AM   #9
Trailer: scamp
New Mexico
Carol - I'll buy your extra rivets!
I was wondering about the structural issue. The main wasted space in ours is the entry closet where the whole bottom half is inaccessible and really unusable other than for geologic layering. I was planning to cut a large part of the front out and install shelves or drawers as a number of others have done. In most of those projects, I don't see any attempt to provide structural frame support so I assumed it would be OK. Has anybody checked with Kent at Scamp about this? Any long-term experience of problems this could cause?
The other thing I'd really like to change if I get time is the area where the water tank resides. The tank is in the middle of the compartment and kind of angled such that it uses almost all the space. I haven't measured yet but it looks like the tank could be placed perpendicular to the trailer and slid all the way to the front of that space which would improve center of gravity issues and would free up much of that space for usable storage.
Any comments, anybody?
Old 10-23-2013, 11:58 AM   #10
Call Scamp. I believe you can get small quantities from Scamp, but you have to call. It's hard to get some stuff via their web site. They'll sell you the exact size(s) needed.
Old 10-23-2013, 06:33 PM   #11
Scamp sell "blank slate" trailers where there's nothing inside EXCEPT added structure around the door and the closet across from the doorway. If you remove either of those parts you must replace with something to hold up the roof. Every vent and every window takes away from the structural integrity of the shell. Eggs do crack...
Old 10-23-2013, 07:04 PM   #12
ShawnKK's Avatar
I didn't know you could buy a blank egg. Any idea how much they are selling for?
Rivets can be bought any where. I bought a bunch of 3/16 from HF for other projects but used them on the Boler. Oh, if you need a shorter rivet, you can always put a washer behind it.
Old 10-23-2013, 07:59 PM   #13
Roy in TO's Avatar
I bought a kit instore from www.brafasco.com that had a variety of sizes in a nice metal storage case.
Old 10-23-2013, 08:40 PM   #14
As silly as it sounds mailing you the rivets will cost more than they are worth.
Canada Post seems to charge more than US Postal.
I cut out a door hole in the bottom section of my main closet space as it was as yours - one big pit where you just dropped things down into. Bought a door from Scamp to match the upper door and installed wire shelves in it. No issues with doing that as Scamp themselves will do it as an optional item. But I am puzzled by your first post as you dont need to drill out any rivets or remove the closet to do that. Removing the rivets or the main component of the closet cause a structural issue though.
Rivets, Acorn nuts, Rivnuts etc. Dan B Care and Feeding of Molded Fiberglass Trailers 45 11-22-2016 07:21 AM
rivets, caps, washers and acorn nuts beardrum Care and Feeding of Molded Fiberglass Trailers 30 09-12-2013 09:48 AM
Simple question gage Problem Solving | Owners Helping Owners 19 06-03-2013 09:20 PM
Nuts n' bolts instead of rivets? dylanear Modifications, Alterations and Updates 20 05-31-2012 01:57 PM
Rivets and Acorn Nuts Steve L. Modifications, Alterations and Updates 6 11-16-2005 08:36 PM
