Simple Water Heater door lock mod - Fiberglass RV
Old 06-03-2013, 12:14 PM   #1
deryk's Avatar
New Jersey
I did not like the way the water heater door stayed closed. One tab broke because it was plastic...the 2nd popped off while traveling. I looked into some options and wandered the hardware isle at HomeDepot and came up with this for about $4.00. I used the spring, a threaded 2" eye hook and a locknut. Tightened the locknut till the spring compressed a little bit for tension when the door is closed, added the clip as a secondary stay closed piece... could put a lock through the eye hook if need be but it seems to be working fine.
deryk
Old 06-03-2013, 12:41 PM   #2
Good idea Deryk, maybe you can hire out as a mechanical engineer to Parkliner. From what I've been reading it appears they need to fine tune a few things. We were impressed though with the one we saw, nice looking trailer.
Old 06-03-2013, 01:01 PM   #3
Administrator
Mary F's Avatar
... And, of course, the water heater's door latch isn't something Parkliner or any other trailer manufacturer designed. The WH is (probably) a Suburban component.
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
Old 06-03-2013, 01:08 PM   #4
deryk's Avatar
New Jersey
Yeah its that way from the manuf. I just wasn't happy with it...so found something better.
deryk
Old 06-03-2013, 01:10 PM   #5
cpaharley2008's Avatar
This water heater fix is common to all trailers, not just Parkliner. In fact I'm going to do it to mine on my Escape. Good job Deryk...
Old 06-03-2013, 01:51 PM   #6
ShawnKK's Avatar
This is what I like to see. Good job! Keeps me from thinking.
ShawnKK is offline   Reply With Quote
Old 06-03-2013, 03:06 PM   #7
The old water heater door from Suburban on my trailer has a metal door latch and its on a spring as well. Wonder why they changed making them that way. Suppose just cutting costs where they can.
Old 06-03-2013, 03:22 PM   #8
deryk's Avatar
New Jersey
Carol, mine was like that too but the original piece that went through the door was plastic and broke...ordered a pair of replacements.... one popped off while driving so its either order another pair...or come up with a better solution. I think this should last longer.
deryk
Old 06-03-2013, 05:10 PM   #9
Matt in SV's Avatar
Trailer: U-Haul VT16
Thanks for this mod. My Dometic water heater on the U-Haul had the same issue. But, maybe I ought to replace the whole unit after 30 years? It probably didn't help that I used the plastic ring as a toggle for the car cover!
Regards,
Matt
Planning our next Escape!
Old 06-03-2013, 06:04 PM   #10
Bill MacDermod's Avatar
Trailer: 1999 17 ft Casita Spirit Deluxe ('Inn EggsIsle')
the knob on mine was plastic but the shaft metal, when the plastic bit the dust I threaded a 1" diameter key ring through it, pull on the key ring, twist and drive on. been there about 7 years now and going strong
Love being Inneggsile
heading sloowly up the eastcoast to our next 2 month (Aug and Sept) camp hosting gig at Camden Hills State Park in Maine
Bill MacDermod is offline   Reply With Quote
RV Water Heater door deryk Modifications, Alterations and Updates 7 04-29-2013 11:09 AM
hot water heater door Christi V. Problem Solving | Owners Helping Owners 9 05-05-2008 09:00 AM
Need new water heater door. BOBSMITH Problem Solving | Owners Helping Owners 7 12-06-2005 05:42 PM
