sink finish - Fiberglass RV
Old 08-20-2014, 01:41 PM   #1
Name: J and V
Trailer: 71 Boler
sink finish
Our Boler sink has a spot the size of a quarter that is damaged and rusty. I really love the vintage green of it and want to restore it, while we are also replacing the plug part. Can you paint a sink with just enamel paint? Do I need to do any special prep work, special paint? I'd love to hear from anyone who has done this before.
jandv is offline   Reply With Quote
Old 08-20-2014, 03:02 PM   #2
The Minimalist's Avatar
Louisiana
There are kits available at the big box lumber stores for repairing ceramic sinks and tubs; available in the common colors....avocado??
Clif
Old 08-20-2014, 03:11 PM   #3
Louisiana
Just noticed you're in BC. Your Boler wouldn't be yellow, would it?
Clif
Old 08-20-2014, 04:24 PM   #4
Trailer: 77 Scamp 13
Had an old guy pass on this approach to fixing ceramic fixtures, worked well on an old tub.
Use the eraser on a new pencil (use the flat like a stamp) or a small paint brush to just apply enamel paint as a drop or dab. Want to avoid brush strokes and keep the paint all inside the damaged spot.
After it dries hit patch area lightly with really fine wet/dry sandpaper using water around 400 or 600 grit as I recall. The wet sanding is just to keep from getting a ridge at the edge of the repair or high spots in it and to help the next coat stick.
Apply more paint dabs and repeat sanding until the chipped area is filled in level with the rest of the enamel. Polish with some rubbing compound.
Doing a white tub in an old house it worked pretty decent to make the repair blend in.
Old 08-20-2014, 04:58 PM   #5
chris cooper's Avatar
You could try a powder coat paint
chris cooper is offline   Reply With Quote
Old 08-20-2014, 05:08 PM   #6
Name: J and V
Trailer: 71 Boler
Yes, we are in BC, but no, our Boler is not yellow. It is all white but we have plans for it. I really like Black and White but our tow vehicle is forest green and we are contemplating that one too.
Old 08-21-2014, 04:33 PM   #7
I have the same green sink with a rust spot, I found that the paint was more expensive than a sink at Ikea at $35. The sink loses the vintage look though.
Nelmes is offline   Reply With Quote
Old 08-21-2014, 06:20 PM   #8
tractors1's Avatar
Trailer: Escape 21 - Felicity
Bathtub refinishing is done with an epoxy paint; probably doesn't come in a matching color though. If you REALLY want to refinish it right, take it to a sandblasting shop and strip the whole thing and put a finish on it you like.
Charlie Y
Old 08-21-2014, 06:57 PM   #9
Your sink is porcelain over steel (hence the rust). Yes you can "fix" it with epoxy, etc., but it's NOT the same. With epoxy, you must be careful... cleaners, pots 'n pans, knives... whatever, are going to affect that repair.
I only know of one business that will re-porcelain a sink (there maybe others!). It's not cheap... Gigi's Hollydale Appliance & Reporcelain
IMHO, I'd "fix" it the best I could, make a sink cover (so know one knows what's underneath)... then go camping and make MEMORIES! YMMV
Old 08-21-2014, 07:25 PM   #10
Reason I mentioned repair with enamel paint was you can possibly color match. Emphasis on possibly. You might have better luck at a paint store rather than a big box store, and it may end up being a close match that looks better than rust stain rather than identical.
re-porcelain service such as Donna mentions would be the only way I know to maintain vintage color and porcelain. Powder coat painting would probably be less expensive but I imagine they would have to sandblast to metal then coat so it would also be all new finish same as re-porcelain. Both options are worth phone calls in my opinion. My suggestion only has cheaper going for it.
Vertglas - a finish restorer Clark Martin Care and Feeding of Molded Fiberglass Trailers 4 11-18-2009 11:31 AM
Finish this sentence Ron Wrighton Jokes, Stories & Tall Tales 37 10-08-2009 12:41 PM
Stovetop finish KarinP Problem Solving | Owners Helping Owners 15 07-22-2009 04:09 PM
Restoring the Finish on Bigfoot DwayneR Care and Feeding of Molded Fiberglass Trailers 9 05-14-2009 02:05 AM
interior finish JIM DUNNE Problem Solving | Owners Helping Owners 5 05-09-2009 11:56 PM
