Old 05-30-2012, 11:11 PM   #1
Trailer: 1973 trillium
Skylite in Trillium
Hi There
This is the skylite I added to our Triilium
Also a new vent to replace the leaking inadequate aluminum one (and that annoying chain) as well as beefing up the warped FRP with a .25 in ABS panel.
PhillyPhixy is offline   Reply With Quote
Old 06-05-2012, 08:43 AM   #2
Trailer: Volvo 245 pulling '71 Trillium 1300
This is very cool - I was just dreaming about a skylight in our trillium - and my ceiling is sagging a bit near the skylight so I need to reinforce it. I thought of doing something similar to modify the entire centre ceiling ridge. Can you share some of your materials and construction info? THanks so much!
coalminecanary is offline   Reply With Quote
Old 06-05-2012, 04:36 PM   #3
skylite process
Thanks
I was beginning to believe no one liked it (although I loved it...) I am in Ontario so maybe I`ll run into you someday.
The impetus for doing it was pretty much the problem you describe: saggy ceiling as well as a leaky vent. Something you can`t tell from these pics is that there is a pc of ACM (aluminum bonded to plastic) sheet that slides over the opening on the inside so you aren`t cooked to death in the morning when the sun comes. I will have to take more pics when I get it back out of storage. I`ll post what I can find if it helps you move ahead with it. Basically, there is a .25" Polycarbonate window with a scratch resistant coating. I am hoping it doesn`t yellow too bad over time. Used butyl rubber to seal to the .25" ABS sheet, then used bonded the sheet to the roof with automotive urethane adhesive. (the type they use for autobody work) The screws were stainless # 8`s i think. Acorn nuts to the inside w/ washers and created a groove with more .25" ABS 1" and 2" strips so I had a channel for the ASM to run in....this would probably seem much easier to understand if I had pics..OK I found a few. There was quite a bit of "dry fitting" before I started gluing. I generally work alone but I had to break down when it came to getting someone to hold the nuts on the inside while I was on the roof tightening them. I used self sealing stainless washers on the outside. Dumped copious amounts of water on it (from the roof of the house) to see if it leaked and so far so good...
Old 06-05-2012, 05:40 PM   #4
theresa p's Avatar
New Brunswick
i like it. does the skylite open similar to the vent or is it closed?
Old 06-05-2012, 07:00 PM   #5
No, it is sealed shut. I was afraid I would have leak problems right over the bed...not good.
Old 06-06-2012, 08:05 AM   #6
Emily R.'s Avatar
Trailer: 1975 Trillium 13 ft (Fluffer-Nugget)
Nice job....A project my Trillium surely could use!
Emily R. is offline   Reply With Quote
Old 06-06-2012, 05:16 PM   #7
THanks for posting those photos, I may tackle a similar project one day (not this season though!)
Old 06-06-2012, 06:13 PM   #8
Spanke's Avatar
Trailer: 1978 Trillium 1300
Indiana
Thanks for the cool pics. Very nice mod!
Spanke
Trilliums Rock!
Spanke is online now   Reply With Quote
Old 06-06-2012, 07:24 PM   #9
How did I miss this? I LIKE IT. And if you like it, that's all that matters Thanks for posting the pictures and information.
Double Yolk
1988 16' Scamp Deluxe
trillium
OH | 1981 Trillium 1300 Trade for a Trillium 4500 Gene Griffin For Sale: Molded Fiberglass Travel Trailers 13 03-06-2011 07:27 AM
1976 13' Trillium and 1980 Trillium 5500 18' Jenn Classified Archives 10 05-19-2010 02:36 PM
newbie confused..which trillium to buy,,Outback (canada) or Trillium u lloyd cicetti General Chat 17 08-04-2008 07:46 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
