02-08-2012, 04:31 AM
Trailer: currently shopping
now in new orleans, going to florida then michigan
small bathtub install?
My biggest question is has anyone put a small bathtub in a ft trailer? Are the tanks big enough to hold enough for a small bath? If i have this right no tubs showers in 13 footers? From trying to live self sufficient, I've learned the bath is the most important thing to me, We hauled water into our earth ship. I'd rather have a tub than a kitchen or living room! Thanks so much.
02-08-2012, 04:45 AM
Actually the whole trailer is a bath tub, you just need a good door seal.
02-08-2012, 05:08 AM
You are so right!!! I needed to laugh thank-you! I need the tub for muscle aches, nothing works like hot water. I'd love to put a whirpool in but figure it would add too much weight.
02-08-2012, 05:17 AM
bathtub under the dinette yes!!!
"I was checking out the vintage vacations website. The trailers are not fiberglass but the restorations are fun to look at. In a 1961 globetrotter airstream there is a dinette like the one many of us have for a double bed. When you lift the plywood cover for the storage area there is a bathtub! It's a little thing, but you could take a sit down shower. Why don't they sell these at Lowes?"
In the similar posts it shows a bathtub under the dinette, that would work great, i think
02-08-2012, 05:38 AM
Seriously, I think that you could build a tub out of fiberglass and put it in the front. Maybe have a topper with cushions to double duty it.
If you have never worked with fiberglass, do a Youtube search. It is not that hard.
02-08-2012, 05:55 AM
Not sure what the intent here, but small tubs like 2x3 are available, (I have one in my unit) but if you want or need to lie in in like a residential tub and fill with hot water, you will need a bigger boat. In a 13 or 16 foot fg trailer there is not enough room. Maybe a SOB or bigger Airstream will have it but it would have to be at least 8' wide, strong frame and you would need a lot of hot water, maybe a 10g water heater would fill it.
02-08-2012, 06:50 AM
I see RV bathtubs up to 46" long on line. If you wanted it longer, you could buy two and cut and join them with fiberglass matting. Then build a wooden frame to set it in and finish it.
02-08-2012, 08:36 AM
Prior to the hack, we had pictures of a fabrcated bathtub that was in the rear dinette on the door side. It took up the entire cabinet which made it nearly 44" long and cabinet "high". You just have to remember, if you're putting a tub in... something else has to go. In the one I remember, there was no longer a fresh water tank, because that's where the bathtub was. I'd be more inclined to buy a kids blowup pool and fill it when I wanted to rather than have something permanent. You could even put it in a screen house with an outdoor cooking stove and a big pot of water, you could then add hot water as needed.
02-08-2012, 09:02 AM
thank-you thank-you
What awesome ideas. ok it can be done. that was my main worry with this whole deal. thanks again
02-08-2012, 09:33 AM
I took this photo of a bathtub in a 1935 15' Masterbilt Pioneer at a Tincan Tourist meet last year. So it can be done in a small trailer.
02-08-2012, 11:47 AM
Trailer: 2008 20 ft Flagstaff Pop-Up (206ST) / 2005 Sienna
Oh wow Carol, that is cool! Did it convert back into a bench seat when not being used as a tub?
Melissa in Florida
1999 Toyota Sienna XLE
02-08-2012, 12:01 PM
yes Melissa it did.
02-08-2012, 04:31 PM
Trailer: 93 Burro 17 ft
I suggest that your first step is to locate a little Scamp, Burro, or Casita to look at, if you have not yet done so. You need to see the size and the way things are arranged. Think about where you would try to put a tub, and would it be practical and economical to do so. Things theoretically can be done, but that doesn't mean those things really should be done. You have to see an egg for yourself, sit in it a bit, and try to visualize where you'll put your stuff and how it will all work (if it will work) for you.
The hot water heaters on these trailers are only, what, 4 or 6 gallons? And the fresh water tanks are about a dozen gallons... you'd empty your tank with one bath, and then what do you use to drink, wash dishes, etc?
I guess if I were setting up a tub, I'd probably try to rig something up in the aisle. But really, a shower would seem a lot easier. You get some sort of container to stand in, suspend a hula hoop from the ceiling, hang your shower curtain from the hoop, and you're in business. A "navy" shower can be had with 3 or 4 gallons of water, which is easier to deal with than a tubful.
02-08-2012, 04:47 PM
Trailer: 1980 13 ft. burro
I can see how the tub thing would work with a water hookup and an on-demand water heater. Oh, I'd love to be able to take a hot bath after a day toting 25 pounds of camera gear over hill and dale!
On the other hand, think of the condensation you'd get!
I really love the tub in the little trailer photo.
02-08-2012, 06:30 PM
02-08-2012, 06:34 PM
If you take one whole cabinet for the tub... where are you going to put the freshwater tank? In my Scamp the freshwater tank is on one side of the dinette... the hotwater heater and converter... plus wiring is in the other....
02-08-2012, 06:49 PM
Maybe you could just use the tub for the fresh water tank.
Wash thoroughly when done.
02-08-2012, 07:38 PM
I think that inside the trailer is too small
02-09-2012, 06:06 AM
I want the inflatable spa!!! Maybe I'll forgo the brakes and I'll be able to afford it!! TOTALLY kidding.
02-09-2012, 11:02 AM
We had the small bath tub in a 24 foot stick built. With the 6 gallon water on propane and emptying it, you get maybe 6 inches of water in the tub because you basically need to run it on hot and not mixed with cold so you will need an on-demand water heater unless, you hang some of those black shower bags out each day and heat the water with the sun but they are heavy and I think ours are 5 gallons each, 40 lbs full! We needed the bath tub because our son did not like the shower. This works best in warmer temps as when the temps are cold, the condensation is unbearable. I have a book "Silver Palaces" and it has that bath tub in that little Airstream and it says the interior was 16' (a 19' trailer minus the hitch) and 7 feet wide. Are you just wanting to basically spray yourself with the water or are you hoping to "soak"? I know when we had the wet bath, that you could just sit on the toilet (tall husband had no choice) to bathe and just spray yourself, etc. I like the wet bath since some in our household are like ducks in water!
