SnoozyRedoozy II - Fiberglass RV
Old 09-26-2013, 04:40 PM   #1
Gleam B's Avatar
Trailer: lil snoozy
South Carolina
SnoozyRedoozy II
It's hard to be in the trailer for seven weeks, as we did this summer on our trip to Nova Scotia, without thinking about some improvements one would make upon returning home.
Our refrigerator, a Majic Chef 3.6 cu/ft, crapped out on us about the forth week into the trip. I wanted to install a Danby DAR125SLDD, which is a little bigger 4.4 cu/ft. and has no freezer compartment, which is useless anyway.The Majic Chef fit into an 18.5 in. wide opening and the Danby needed 21 in. I had little trouble widening the opening, and hoped I didn't need to modify the countertop for height. Caution is needed when pulling out the existing refrigerator so as not to damage the vinyl flooring. I wanted to install wooden flooring, so I had to route the countertop about 1/4" to account for the flooring thickness. I also installed a shelf above the sofa, so that I could install some LED reading lights, as we do a lot of reading in the trailer. I chose GoWise GW21500 and also installed one over the bed, so we could read there as well. Then I designed a sliding support to do away with the metal table support. I did not like having the base for the table located where it was. I stubbed my toe one night and that was enough. I am enclosing some photos of the remodel. Note the security light I installed on the door so I could see the key lock at night. Next I'll be mounting my spare on the side of the trailer and get it out of the storage well. Happy Trails
Gleam B is offline   Reply With Quote
Old 09-26-2013, 06:20 PM   #2
Nice, very nice!
Old 09-26-2013, 07:08 PM   #3
Melanie B in NC's Avatar
Trailer: Lil Snoozy "Marigold"
Alabama
Is the light over the bed stuck onto the fiberglass or did you actually penetrate the surface with screws? I would like such a light, but am afraid to put screws or nails into the fiberglass.
Melanie B in NC is offline   Reply With Quote
Old 09-26-2013, 07:24 PM   #4
Thomas G.'s Avatar
Melanie, meet 3M VHB tape. 3M™ VHB™ Tape
Old 09-26-2013, 07:25 PM   #5
honda03842's Avatar
Name: Norm and Ginny
An alternative to screws is very high bond strength tape. We use it to hold up a spice rack and a medicine rack. In 1000'2 of miles they are still in place.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-26-2013, 08:34 PM   #6
SusieinNC's Avatar
Trailer: 2012 Lil Snoozy #151 - sold in 2018
Very nice! I particularly like the shelf over the sofa and the back door light.
SusieinNC
SusieinNC is offline   Reply With Quote
Old 09-26-2013, 09:01 PM   #7
Gleam B's Avatar
Trailer: lil snoozy
South Carolina
I glued the wood backing and wire mould but sure like the tip about the tape
Old 09-26-2013, 09:15 PM   #8
carlkeigley's Avatar
NE Oklahoma
The shelf over the couch is on my wish list.
The wood floor and that oak table sure change the looks.
Big improvement. Looks great.
Old 09-28-2013, 07:42 AM   #9
MCDenny's Avatar
Trailer: Lil Snoozy
We have screwed lots of stuff to the our Snoozy's walls with half inch self taping metal screws. That ability is one of the reasons I bought that brand.
MCDenny is offline   Reply With Quote
Old 09-28-2013, 07:45 AM   #10
MCDenny's Avatar
Trailer: Lil Snoozy
Did you consider any 12v models?
Old 09-28-2013, 11:14 AM   #11
Gleam B's Avatar
Trailer: lil snoozy
South Carolina
I don't know anything about 12v refrigerators, but would like to learn about them for future consideration. Any info on brands and where one could purchase these would be appreciated.
The wooden backing for the light over the bed was both glued and screwed. I have used 1/2" screws in other remodel applications with no problems. Just be careful!!!
BTW... how long would such a refer run without draining the battery. I am considering adding another deep cycle marine type battery to supplement the one we have. Any suggestions??? Thanks
Old 09-28-2013, 11:28 AM   #12
Brian B-P's Avatar
Nice work
The cantilevered table support is clever and nicely done.
There have been quite a few discussions of these refrigerators in this forum. To find them, I suggest using the Google search option (or a regular Google search qualified by "site:fiberglassrv.com") for the term "danfoss". That brand name (of a compressor used in 12V refrigerators) occurs in almost every one of these refrigerator discussions, but not in any other context.
Old 09-28-2013, 03:44 PM   #13
NE Oklahoma
My shell must be thinner than everyone else's.
I've gone through in a couple places.
What I've done is used double sided tape and then
a 1/2" screw just to make the tape stick tighter.
Old 09-28-2013, 05:21 PM   #14
SusieinNC's Avatar
table base
Last night we saw the latest Snoozy design at the RV show in Greensboro. Apparently Glenn is not the only one to stump his toe on the table base mount. Now the base is flat on the floor. Alan said it took a while to find a supplier that makes a decent mount that didn't cost a fortune, but this one should do the trick. If we get down that way, we will stop by and get the flat kind installed.
SusieinNC
Old 09-28-2013, 05:21 PM   #15
MCDenny's Avatar
Trailer: Lil Snoozy
I make sure the thing I am screwing to the wall is at least an 1/8" or so. No protrusions so far.
Old 09-28-2013, 05:33 PM   #16
NE Oklahoma
Thanks Denny, I'll keep that in mind.
The paper towel rack was not that thick.......lol
Old 09-28-2013, 05:46 PM   #17
Alabama
Susie - did you notice if the model they were showing (which is the one we saw in the show room, I think) had a rear bumper? Does your unit have such a bumper?
Old 09-28-2013, 05:50 PM   #18
NE Oklahoma
If this is the same display,
HATCHERY PHOTOS
there was no bumper on it.
Old 09-28-2013, 06:08 PM   #19
SusieinNC's Avatar
bumper
There is no bumper on my Snoozy or the one we saw last night.
SusieinNC
Old 09-28-2013, 06:19 PM   #20
NE Oklahoma
I only know of three of us that have the bumper.
