Solar - Fiberglass RV
Old 07-16-2015, 05:15 AM   #1
Trailer: 2015 Escape
Solar
A long time ago I saw a reference to a portable solar panel that folds like a suitcase. I'd like to know the folded size and how it does at keeping batteries charged. Anybody know about these? Thanks
Old 07-16-2015, 03:21 PM   #2
Trailer: Escape 19 ft 2010
Check out Solar Cells, Solar Panels, Renewable Energy, Wind Energy, Charge Controllers, Solar Trackers - Solarblvd, They are one seller I have purchased from. It seems the sizes and availability changes frequently so you need to look at their web site for what they are currently stocking.
I believe they are listed as kits. The kits are pretty useless, the reason being the built in controller, wiring and connectors are low quality. I threw all that stuff away and had a pretty good panel with 140 watts. They are heavy at about 45 lbs for my model.
Paul Braun is offline   Reply With Quote
Old 07-16-2015, 03:45 PM   #3
cpaharley2008's Avatar
Robert,
Why did you not have ETI install your solar at the factory?
Jim
Never in doubt, often wrong
Old 07-16-2015, 03:57 PM   #4
Trailer: 2015 Oliver Legacy Elite II - Hull #69
South Carolina
I have one of these:
http://www.amazon.com/gp/product/B00...rch_detailpage
From GoPower! It's usually good for 5-8 amps depending.
More than enough to keep ahead of light loads and a refrigerator.
Dimensions are in the link. I find the quality of the components and the wiring to be just fine. Comes with a nice, padded carrying case.
Follow my blog - https://www.wincrasher.blogspot.com
Ron Merritt is offline   Reply With Quote
Old 07-16-2015, 04:07 PM   #5
Trailer: 2010 Scamp 16
http://www.amazon.com/Renogy-Foldabl.../dp/B00HR8YNK6
Couple of additional options also on Amazon.
When you get right down to it a set of swing down legs with bottom limiter and a cross piece between the legs on any panel give you a portable stand. Hinge two of them together and there you go. But the posts I have seen on DIY version have shown a non-trivial level of workmanship going into making them nice.
Kind of expensive. Wonder if anyone has wired panels for daisy chaining? E.G one 30 panel for a weekend just to keep the battery from running down but if one is going for a long stay in the boondocks carry a second panel of say 50 watts and plug it in to the system to make sure you can withstand or recover faster from a couple of rainy/cloudy days.
Old 07-16-2015, 06:15 PM   #6
The Minimalist's Avatar
Louisiana
Originally Posted by Ron Merritt View Post
More than enough to keep ahead of light loads and a refrigerator..
I guess you're talking about powering the board on an absorption refrigerator in propane mode. My Dometic pulls 10 amps on DC, so I run on propane, or AC if available.
Checking truckfridge.com average usage on their basic 12v compressor unit is 2 amps/hr that's 48 amp hours a day. Under the best sun conditions, no clouds, no trees, panels perfectly aligned to the sun, the Go Power! GP-PSK-120 would only produce 53.6 amp hours of replacement energy with 8 hours of sunlight, at 6.7 amps output (data per the Amazon page). That would be cutting it pretty close even if you had no other loads.
Just saying............
Before you go looking for solar panels determine what your expected daily amp hour load is, then you can make a better decision on panel and battery requirements.
Clif
Old 07-17-2015, 05:48 AM   #7
Raz
Raz's Avatar
I recently bought two 30 watt Renogy panels for $50 each or $1.67/watt. Like horse power and engines, solar panel wattage is a figure of merit so manufacturers tend to be optimistic. I assume 1 amp output for each 20 watts of panel in full sun as a conservative estimate. After figuring my use at no more than 10 amp-hrs a day I sized a panel to meet that need in the location I usually camp. I wanted 2-25 watt panels figuring 50 watts total. The 30 watt panels were cheaper and still within my size constraints. Hope this helps, Raz
solar
ENERWATT SOLAR EWC-30 Solar Controller Robert50 Electrical | Charging, Systems, Solar and Generators 7 09-14-2014 04:00 PM
Crank'n'go solar/crank am/fm radio Legacy Posts General Chat 12 09-03-2006 11:12 AM
Solar charger questions Steve Rosenberg Care and Feeding of Molded Fiberglass Trailers 17 12-01-2005 02:00 AM
Solar System Advice Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 05-13-2003 10:03 PM
Solar Panels Legacy Posts Electrical | Charging, Systems, Solar and Generators 13 04-24-2003 09:09 AM
