Solar Charger and Panels - Page 6 - Fiberglass RV
Old 03-08-2008, 12:56 PM   #101
Trailer: Play Pac ('Egg Krate')
For connections, I am using premade housings from a product at work and fitting them with standard plugs and receptacles I can get for free. I am using 1/4 phone jacks/plugs like what is on the end of guitar cords, but you can also use a variety of other types of robust connectors. I was using speakons, but they are a bit of overkill and rather large.
Thanks for the reply. Am I correct in thinking I can drop into Radio Shack and get their 1/4" phone plugs/jacks and wire this up? Or would it be better to use something else. For some reason (inexperience?) I am not visualizing the hook up part very well.
If I figured my amp loads correctly, this one panel should work for everything I need. I may upgrade later, if I add a lot of juice hogs, but this will at least get me started and be a keeper if I need more solar watts later.
I'm looking forward to your future posts on how you're rigging things. Pictures would be grand.
Plotting my next adventures...
Bonnie is offline   Reply With Quote
Old 03-08-2008, 01:02 PM   #102
Gina D.'s Avatar
You could, but you need to know how to solder correctly, and you need to build a box to hold all the jacks.
Your panel will come with connectors that are well suited for your needs with just this one panel for now. I would go ahead and just use them until you feel the need to upgrade.
Old 03-08-2008, 02:06 PM   #103
Gina D.'s Avatar
Here is the "junction box". It is the housing for our foot switch assemblies for switching functions on guitar and bass amps. They are designed to sit on the floor and literally be stomped on all night.
Unfortunately, the largest one we have easily available will only support 3 panels unless modified heavily. (We have "4 bangers", but they don't come round as scrap very often) We chuck these things in the recycling all day long for cosmetic reasons, so instead of bribing our metal shop to add more holes to support more jacks, I will just "add on" more boxes and daisy chain them together if needed. Right now, 3 suits my system.
This is what they normally look like:
Here is how it's is gutted and converted
I don't feel a need to paint over the functions. I know what they do, and they are powder coated, so you don't get a much more robust surface than that.
Here is the inside.
The screws you see are simply filler to cover up the square holes intended for the LEDs from the electronics of the switch when it is actually made into a foot switch. The larger holes that the jacks are mounted in are for push switches.
The jacks are rated for high current outputs of power amplifiers, and in this application, they will never see the type of current they are capable of. They are also corrosion resistant.
I also have them normaled through one jack, as you can see, rather than daisy chaining them together. This will prevent one jack down the line from bringing the next ones in line down in the unlikely event of a failure. If the jack and connection on the noramled jack fail, well, all bets are off.. Anyway, this is a common technique used in speaker cabinets using multiple speakers. If one goes down, you still have 3 (or more) working ones.
This "box" can sit on the ground under the panels and be protected from water reasonably. I can also put in dummy plugs to prevent water from going down the jack holes if I am not using a panel in it.
Old 03-09-2008, 03:05 PM   #104
Greg A's Avatar
All of these briefcase products appear to be manufactured by Topray Solar out of China.
They are difficult to get supplied.
Here is the product page:
Solar
I do have a wholesalers license and will see what I can get.
Looks like the HF set is coming out of this company as well.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 03-10-2008, 12:25 AM   #105
Gina D.'s Avatar
I looked them up some time ago and noted the same thing.
I would be interested in seeing what kind of pricing you get. They look like they want you to pick up large QTYs at Large $$$$$
Old 03-10-2008, 12:05 PM   #106
Greg A's Avatar
That's OK, you'll buy all of them won't you? Oh, I will need to keep two for myself.....
Owner:
Old 04-01-2008, 01:53 AM   #107
Everything arrived alive and well.
I am pleased with the size and the ease of setup.
I had one question for those of you who have done this before, can I clip off the connector to say the alligator clips and wire that to the charge controller so I have a like connector for the panel? I'm guessing it won't matter as long as the connection is strong and protected.
Old 04-01-2008, 02:13 AM   #108
Gina D.'s Avatar
Bonnie, yes you can.
Just be careful that you know which is + and -. I think you already knew that tho.
Old 08-11-2008, 10:04 PM   #109
Roy in TO's Avatar
[quote]Thank you, Gina!
The guitar case works perfectly.
Attachment 7576
I've been hunting for the right guitar case since it was first posted. Tonight I stumbled across a brand new soft sided keyboard case on Craigslist. It's a little bigger than a guitar case, but will hold everything for my solar setup in one package. It's even got wheels on one end.
Gator GK61 SEMI Harshell Keyboard Case
Thank you for the idea!
Old 08-11-2008, 10:41 PM   #110
Talking
It's a little bigger than a guitar case, but will hold everything for my solar setup in one package. [b]It's even got wheels on one end.
That would be a great feature!
solar, solar power
Adding Solar Panels Bigfoot Mike Problem Solving | Owners Helping Owners 50 09-25-2009 08:59 PM
Chinese Solar Panels Lisa H. Care and Feeding of Molded Fiberglass Trailers 10 05-31-2009 12:05 AM
Solar panels on eBay peterh Care and Feeding of Molded Fiberglass Trailers 8 08-07-2008 07:43 PM
Solar Panels Barbara Gardin Electrical | Charging, Systems, Solar and Generators 7 06-02-2007 09:30 PM
Solar Panels Legacy Posts Electrical | Charging, Systems, Solar and Generators 13 04-24-2003 09:09 AM
