Solar Charger and Panels - Fiberglass RV
Old 12-22-2006, 09:46 PM   #1
Trailer: Fiber Stream
Talking
I am modifying my battery installation to include the ability to connect Solar Panels for recharging. My Fiber Stream has it's battery box accessable from the front of the trailer through a vented hatch door.
A previous owner added a cord hatch to the access door.
What could this be for?
I think I found a use for it...
Old 12-22-2006, 09:50 PM   #2
Talking
I bought a Solar Charge Controller on eBay and installed it to the inside of the access door.
Battery (Red/Black block)
Now I can feed the Solar Panels' wires through the little hatch in the larger access door and connect them to the charge controller next to it and close the door.
Edit Note*
I corrected the errors in my wiring and replaced the photograph and wiring diagram.
Thank you, Gina!
Old 12-22-2006, 09:53 PM   #3
Talking
While I was at it, I made the Battery Wires long enough to set the battery on the ground while it is connected to make servicing easier.
Old 12-22-2006, 09:56 PM   #4
Chester Taje's Avatar
I like that hatch idea.
Old 12-23-2006, 10:54 AM   #5
Gina D.'s Avatar
West Coast USA
Fred, are you running your car charge line into the controller?
If so, you will damage the controller. It can not handle that type of current.
Never plug anything into the input of a solar charge controller but a solar panel.
Old 12-23-2006, 11:40 AM   #6
Thumbs down
OK. I will change that.
Old 12-23-2006, 12:15 PM   #7
Gina D.'s Avatar
West Coast USA
from the owners manual from one of my units, but I have seen the same for others
OTHER CHARGING SOURCES: Do not use the ASC to regulate a power source other
than a photovoltaic panel, such as a hydro or wind generator/alternator or an AC battery
charger. To do so could result in damage to the ASC and/or the generating equipment
because the ASC regulates charging by short circuiting the input. Connect other
charging sources directly to the battery.
The ASC and array can remain connected to a battery that is being charged by an
additional source, (alternator, battery charger, etc.) without damage to the controller or
solar panels.
This also explains how the unit cuts off. Would hate to see what happens when your alternator or battery has a dead short underway.
Old 12-23-2006, 01:37 PM   #8
Brian B-P's Avatar
My solar panel charge controller doesn't short the input like Gina's (it just opens a relay) so it wouldn't be a problem in that respect, but I agree that connecting the power from the tow vehicle on the output/battery side of the controller rather than the input/panel side would be a good idea anyway - the tow vehicle does its own regulation.
Slick setup, Frederick!
Old 12-24-2006, 06:04 PM   #9
Pete Dumbleton's Avatar
Yep, the battery should be the common point for all charging arrangements that I know of (Converter, battery charger, battery maintainer, generator, tow vehicle, solar and hamster in a wheel).
Old 03-19-2007, 07:42 PM   #10
Talking
I purchased the solar panels from Harbor Freight.
Old 03-19-2007, 07:56 PM   #11
Talking
It comes with a rather large charge controller that I am not going to use in the trailer, since I have already installed one inside the battery compartment of the Fiber Stream.
I did buy 2 extra items:
72" x 1.5" Aluminum Piano Hinge
12' of 3/4" diameter Yellow Heat Shrink Tube.
I cut the Piano Hinge into two 3' pieces.
I had to carefully drill offset screw holes in both the hinge and the edge of the Panels' aluminum frame so not to damage the glass part of the panel. I attached the 3 panels together, with the hinges facing opposite directions. Then I bundled the wires together into 1 cable with the heat shrink.
Old 03-19-2007, 08:00 PM   #12
Talking
Now the panels stow compactly. I show them folded, along with the collapsed angled mounting frame:
My next project will be to build a carrying case, or box, to store them in.
Old 03-19-2007, 08:03 PM   #13
Talking
I open the panels and assemble the frame:
Old 03-19-2007, 08:06 PM   #14
Talking
... and lay the panels into the frame. There are pins in the frame that fit into receiving holes in the back of the panels.
Old 03-19-2007, 08:08 PM   #15
Talking
And then I connect the panels to the charge controller.
Old 03-19-2007, 08:10 PM   #16
Talking
Now I close the battery box, and Wa-La!
Old 03-20-2007, 08:51 AM   #17
Gina D.'s Avatar
West Coast USA
Looks good!
Old 03-20-2007, 05:39 PM   #18
Lizbeth's Avatar
OMG Fred it's a thing of beauty! You'll have to let us know how those panels work. I've looked at them several times but didn't have the spare change. They seemed like a great deal but like you I thought the controller was heavy and big and the included lites were "interesting".
How much do the panels by themselves weigh?
Old 03-20-2007, 07:38 PM   #19
Talking
30 pounds together; 10 pounds each How did you know I'd weigh them?
Old 03-20-2007, 09:21 PM   #20
Darren C's Avatar
Trailer: Star Stream 19ft Aluminum
Does anyone use (READ : do I need) a fuse and/or ground for a 12V solar system? It feeds a 100Ah deep cycle marine battery.
Also, while I'm on the subject, how do I check the ground on my 120V plug-in?
Darren C is offline   Reply With Quote
solar, solar power
Adding Solar Panels Bigfoot Mike Problem Solving | Owners Helping Owners 50 09-25-2009 08:59 PM
Chinese Solar Panels Lisa H. Care and Feeding of Molded Fiberglass Trailers 10 05-31-2009 12:05 AM
Solar panels on eBay peterh Care and Feeding of Molded Fiberglass Trailers 8 08-07-2008 07:43 PM
Solar Panels Barbara Gardin Electrical | Charging, Systems, Solar and Generators 7 06-02-2007 09:30 PM
Solar Panels Legacy Posts Electrical | Charging, Systems, Solar and Generators 13 04-24-2003 09:09 AM
