Solar charging system completed - Page 2 - Fiberglass RV
Old 12-07-2013, 06:40 PM   #15
Originally Posted by peterh View Post
A bit late to point his out now, but had wired your solar panels in series (charge controller wired to panel one, panel one wired to panel two, then panel two wired back to the charge controller) instead of in parallel (charge controller wired to both panels one and two, then the panels wired back to the controller) you could have gone with 14g wire and had an almost identical drop in current. Unlike older Pulse Wave Modulation (PWM) controllers, most most modern Maximum Power Point Tracking (MPPT) controllers can handle two, sometimes even three or four panels wired in series, and wiring them in series increases the voltage and watts carried by the system without increasing the loss-inducing current.
Peter,
Yes, I read about that option. There are a few drawbacks to doing it that way. I don't recall all of them, but partial shading is one, and smaller arrays are not ideal for series wiring. I weighed it out and selected parallel. I can also only use one panel if conditions are right. Parallel wiring the output current doubles too, but you need the big wire to keep the waste down. I think my 8 gauge wire loses about .2V with the 30 foot reach. The panels produce about 18v, so still plenty to work with.
Russ
Old 12-07-2013, 07:56 PM   #16
cpaharley2008's Avatar
Russ,
Nice set up on the outside box, I see a lot thought there.
Jim
Never in doubt, often wrong
solar
Bigfoot Solar System Tim D. Modifications, Alterations and Updates 16 04-09-2018 11:07 AM
My New Solar System Sharon G Modifications, Alterations and Updates 28 05-20-2013 05:12 PM
Parkliner Electrical System & AGM Battery Charging-Maintaining accrete Electrical | Charging, Systems, Solar and Generators 15 05-16-2013 06:03 PM
Dream Solar system Steve Hammel Modifications, Alterations and Updates 37 10-28-2012 03:02 PM
Solar System Advice Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 05-13-2003 10:03 PM
