I finally put together a cooling fan for my
refrigerator compartment, which holds a lot of heat when the sun is on that side of the
Scamp. I have 3 computer fans wired in parallel and they are powered with a 5 amp 12V
battery that I can recharge with my
solar panel. I can also run the fans directly from the portable
solar panel when it is not in use elsewhere.
I'm taking unit for a test run this weekend. The fans are attached directly to the rear of the vent panel. (The photo shows the vent panel propped in place backwards, for photo purposes only).
While not very sophisticated, my setup should work well and keep the
fridge compartment a bit cooler.
Peg
