04-21-2013, 12:57 PM
#21
Trailer: '98 BURRO 17WB
Delaware
What's the effect on choice of conductor size of having controller as close as possible to panel (talking distances inside junction box common to panel and controller) and the battery at large multiples of this distance, say 50', from both?
jack
04-21-2013, 01:06 PM
#22
Trailer: 2012 Escape 19
Originally Posted by rabbit
Look at it this way. You're camping and you need a half-pail of water. You walk to the campground's spigot (halfway across the CG) and fill your pail 7/8 full. On the way back, 1/8 of the water sloshes out while you carry the pail. When you get back to the trailer, you have 3/4 pail of water. Recall that you only needed 1/2 a pail. Do you get upset about losing 1/8? I hope not! After you use your 1/2 pail, the rest might even get dumped out if you don't have room for it.
That is what's going on here with the voltage. I need 14.1V at the controller; any more than that is wasted. The panel puts out up to 18V. But the delivery method lets some slosh out, so maybe only 16V arrives. The current still gets delivered, just not at as high a voltage. Do I need to rework my wiring to avoid losing 2V? Nah, I don't need it. The PWM controller dumps the excess voltage.
Now, if I had a MPPT controller, that could take the extra voltage and use it to boost current flow into the battery. But at what expense? And the logic circuitry uses up some of that current internally, so waste still exists. The MPPT controller only pays off when more solar panels are present (and needed).
04-21-2013, 01:12 PM
#23
jack
I could improve performance slightly (1.5%?) by attaching 1 foot long leads of 6 or 8 gauge wire from the controller directly to the battery terminals.
50 feet or even 75 feet of 16 gauge wire between the controller and panel should not reduce performance appreciably. 100 feet is a 3.5V drop, though.
04-21-2013, 01:23 PM
#24
Delaware
Good dry camp analogy, Mike and I understand tour conclusion that the losses involved are not appreciable in the case of a 12V battery. It could be that site I linked to assumes 24V storage. That part isn't mentioned; smallest recommended conductor mentioned is 12awg.
jack
04-21-2013, 01:27 PM
#25
From Thomas' site 16 ga. R= 4.1 ohms/1000ft
so R=0.004ohms/ft
@ 25 ft two conductors there is 50ft of wire ( Byron used 25 ft. For 50 ft just double.)
Rt=0.004 x 50 = 0.2 ohms
75 watt panel........ Assume I max 5 amps
V=I x R= 5x0.2=1volt
16 ga is what I would use. Light, flexible and cheap. This same discussion occurred when another member asked the same question. I said 16 ga lamp cord. One individual suggested 10 ga romex! I think the poster used a 12 ga extension cord. His money.
On soldering. I prefer to solder and have not had issues but on the road I carry a crimping tool. No AC. Soldering is an aquired skill. Crimping is probably better for the neophyte. I have never used Scotch locks (loks?). While being a big fan of 3M products, they just don't look good to me. Raz
04-21-2013, 01:42 PM
#26
Originally Posted by Byron Kinnaman
Solar panel voltage is above 20 volt out put.
With an open circuit, yes. It would be very surprising if this were the output under load.
Originally Posted by Mike Magee
I was envisioning that the controller would take the higher voltage and translate it into a current boost as it stepped the voltage down for the battery. But PWM controllers don't do that, do they? Only MPPT controllers do that.
Correct. A basic controller is just a switch; a non-MPPT PWM controller is essentially a throttle.
So yeah, as long as the long cords from panel to controller deliver at least 14.1V (set point of this controller is 14.1, not 13.9), the voltage loss they cause is pretty much inconsequential.
If the panel output measured at the controller input is over 14.1 V, it will just be throttled down... but is it really higher than that under load (while delivering charge current to a run-down battery)?
04-21-2013, 02:03 PM
#27
Interesting. I have an old charger that uses PWM. I've always assumed the off time was to provide the sensing circuitry with a "disconnect" to check the battery voltage and the lowering of the duty cycle was to slow the charging down to avoid overheating the electrolyte. I'm not sure what you mean by throttle.
04-21-2013, 02:10 PM
#28
Voltage drop is not the only concern with wire size . Mechanical strength plays a factor IE smaller wire breaks easier than larger wire . Wire connectors which utilize set screws are not considered as a crimp connection . Crimp connections are not reversible
04-21-2013, 02:20 PM
#29
What do you think about scotch lock?
04-21-2013, 02:28 PM
#30
Trailer: Escape 19 ft 2010
Is the Scotch Lock what are commonly referred to as suitcase connectors?
04-21-2013, 02:38 PM
#31
Originally Posted by P. Raz
I've always assumed the off time was to provide the sensing circuitry with a "disconnect" to check the battery voltage...
I don't think the small fraction of a second of "off" time is enough to be useful to check battery voltage.
... the lowering of the duty cycle was to slow the charging down to avoid overheating the electrolyte.
Adjusting the width (time duration) of the "on" portion of the cycle is how a PWM controller works - it depends on the switching between fully on and fully off being frequent enough that the result is essentially being partially on. Yes, the purpose of not being fully on in any controller design is to keep the current to a safe (for the battery) level (which of course is nearly zero when fully charged).
Sorry, that was supposed to be a helpful analogy, not a source of confusion...
A throttle valve - such as the throttle on a gas engine - limits the flow by being partially closed by an adjustable amount. A PWM controller acts like an electrical equivalent, allowing some fraction (up to 100%) of the "flow" that direct connection would.
04-21-2013, 02:42 PM
#32
I've never heard the term "suitcase connectors", but it makes sense: the connector body hinges closed over the pair of wires being connected... so yes, that would be a Scotchlok (using the 3M brand name) or insulation-displacement connector.
04-21-2013, 02:46 PM
#33
Good article here on controllers. RV Solar System Charge Controllers | PowerMyRV
The throttling effect that Brian is referring to might be clearer with this illustration:
Now let’s take a look at the fundamental operation of a PWM controller. These controllers use a Pulse Width Modulation scheme, aka Duty Cycle Change, to directly connect and disconnect the panel to the battery. When “on” the panel and battery are directly connected together.
The repetition or operating frequency is fixed by the green hash marks, while the on versus off duration, aka duty cycle, varies depending on how much charge the battery requires. Note when the waveform is high the panel and battery are directly connected. The panel’s voltage drops to the match the batteries voltage when connected together.
#34
Is the location of the controller the prime consideration in determining the conductor size required, Brian?
jack
Not necessarily. My controller is mounted on the solar panel. Then I have about 12' of wire to the battery, and can add another 15' if desired. Even that way the wire resistance is a not a concern since the maximum current is in the 4 to 5 amp area.
I chose to put the controller on the solar panel since I charge more than one battery in different locations. One battery in on the tongue of trailer and other sits in the back of the truck. I have short pig tails on each battery with the same connector (Anderson Power Pole) and mating on the cable from the controller. Makes it very easy to switch from charging one battery to charging the other.
There's a lot of misconception about wire size and gain by going to larger sizes. Yes there can be a little gain, but very little and usually not worth the cost of the copper. There might be cases where you gain a bit more, but knowing Ohm's law and reading resistance/ft(often listed as ohms/1000') charts can give some sort of idea how much gain.
I'm using 12 awg wire only because that what I had for ham radio operations, where I need a peak of 22 amps, so used what I had left over. The larger Anderson wire has some pretty thick tough insulation which withstands abrasion better.
04-21-2013, 02:48 PM
#35
I try to stay away from scotch locks mostly, but have used them for an interior application.
04-21-2013, 03:40 PM
#36
In the electrical world milliseconds are a long time. All chargers be they analog or digital sample battery voltage and compare to a preprogrammed value. From my readings electrolyte temperature would be a better measure. (Perhaps there is a chemist in the house that would comment) That's my gripe on smart chargers but that's a different discussion.
04-21-2013, 03:44 PM
#37
Delaware
I have a rig nearly identical to Byron's--80watt single panel with the controller mounted on the junction box rear of panel, 22' of 12awg SG connects to pigtail on the battery, A-frame leg on the back of panel. I used common calculator formulas from solar suppliers to calculate. Perhaps, despite my ignorance of theory, I have "erred on the conservative side" and avoided bottle necking my setup despite the location of the controller. Anyone concur, disagree?
jack
04-21-2013, 03:50 PM
#38
Yes, but in battery electrochemistry it is a very short time, which is why a resting voltage is measured after many minutes, not a few milliseconds. My understanding is that multi-stage "smart" chargers watch the current/voltage relationship to determine where they are in the charge cycle, not an assessment of non-charging voltage.
04-21-2013, 04:12 PM
#39
........Anyone concur, disagree?
jack
I think ya done good, Jack
I know that generally it is recommended to put the controller close to the battery, but using heavier wiring would help to mitigate the controller being on panel from being a problem
04-21-2013, 04:29 PM
#40
In the electrical world milliseconds are a long time. All chargers be they analog or digital sample battery voltage and compare to a preprogrammed value. From my readings electrolyte temperature would be a better measure. (Perhaps there is a chemist in the house that would comment) That's my grip on smart chargers but that's a different discussion.
Some solar controllers have a temp probe that is placed in the battery box, and the controller's output is based partly on that temperature.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Solar Panel Set up Question - Grounding the panel?
Anne H |
Electrical | Charging, Systems, Solar and Generators |
2 |
09-07-2012 04:48 PM |
solar panel
h.mike |
4 |
07-17-2012 09:01 AM |
solar panel
Judith Kennedy |
2 |
10-29-2009 11:30 AM |
solar panel help
Maggie |
9 |
07-18-2006 04:38 PM |
