Solar Panel Wiring Choices - Page 2 - Fiberglass RV
Old 05-14-2013, 02:17 PM   #15
Originally Posted by multi-task View Post
Sigh, why must you drone on about this. For someone who hates the internet you sure make a lot of your own posts. You're presuming you are actually getting the voltage from the panel you expect to get, likely you aren't. Those ARE considered low voltage, look them up, I don't need to hold your hand and explain the brands and their open/closed circuit voltages. Take your attitude over to a solar forum, perhaps your 60 years of experience will school the experts and we'll all have 40ft runs of 18g wire to skip rope with and charge our batteries at the same time.
Hating on someones install is childish and petty. A couple of us responded to the OP to guide them in the right direction and give them ideas. If you don't like someones post keep it to yourself or present your knowledge in a more professional way expectant of your age.
I don't know who is doing this hating you're talking about. All I'm trying to do is correct misinformation. The OP had a question and was instantly filled with misinformation. If it bothers you to be corrected then who has the problem?
Your install is working, doing what you want it to do. That doesn't mean it best install in world. Your misinformation and misunderstanding then coming down hard on someone that attempts to correct the misinformation... well, we'll leave it at that.
Old 05-14-2013, 02:49 PM   #16
Trailer: Trillium Outback - 2004
Originally Posted by Thomas G. View Post
Drew, you are new here. This group will spend days arguing over half full or half empty, party sunny or partly cloudy.
Don't take it seriously or it will pi$$ you off.
Agreed!
Where weíre going, we donít need a plug-in.
multi-task is offline   Reply With Quote
Old 05-14-2013, 05:19 PM   #17
KevinPete's Avatar
Trailer: 1995 Scamp 13
The NEC requires at least 12 AWG copper or equivalent in PV systems operating under 50 volts. The NEC also covers RV's in the US. Also required that all devices in the system be UL listed, not just "recognized".
Agree or not, NEC is the electrical "law of the land".
KevinPete is offline   Reply With Quote
Old 05-14-2013, 05:27 PM   #18
Interesting. Truck manufacturers (Freightliner, Peterbuilt, Kenworth, etc.) require minimum 18 awg for most wiring. Don't quote me on this one, but I believe CAN BUSS runs on 22 awg.
Old 05-14-2013, 05:27 PM   #19
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I'm envisioning a black helicopter with the letters "NEC" on the side....whump.....whump.....whump......
Old 05-14-2013, 05:42 PM   #20
Furthermore the NEC website doesn't say anything about RVs or Trailers. It does apply to RV Parks. Please report chapter and paragraph number.
Old 05-14-2013, 05:44 PM   #21
Raz
Raz's Avatar
Vermont
I'm past arguing over this.
And I'm tired of people who substitute "Internet experts" of unknown credential for actual knowledge in the field.
Old 05-14-2013, 05:45 PM   #22
Mike Magee's Avatar
Trailer: Li'l Hauley
The example given was 18 gauge wire over 20' distance, for a voltage loss of .19V. Ok, now make it 35 feet which is what you have (but you are using 10 gauge, of course). Probably closer to .4V, I'm guessing?
I know that my controller takes the panel voltage down to an output of 14.1V. If I ran 35' of 18Ga. wire from controller to battery, wouldn't I get a max of something like 13.7 or 13.8V? How in the world can one expect to top off a typical rv battery with such a low voltage?
My point is simply that large wire and/or a short run seems to make good sense between the controller and the battery. Am I right?
How to prepare Tofu
Step 2: grill some meat
Old 05-14-2013, 05:50 PM   #23
KevinPete's Avatar
Cars and trucks don't fall under the NEC, nor do trains, boats, and aircraft. RV's do. There is some talk of electrical inspectors allowing conductor sizing by calculations (using NEC tables), but most will fall to the safe side and pick the clearly-stated minimum size. NEC is a whole other kettle of dead horses, don't get me started on arc-faults!
I don't think there are too many thorough inspections of RV wiring, because some I've seen are a dog's breakfast. I haven't even gotten my Scamp home yet, and I've already got the spools of wire out! Going to be adding an 85-watt panel to mine, will document the process with my electrician relative who teaches the PV course looking over my shoulder to make sure I do it right.
Old 05-14-2013, 05:57 PM   #24
Raz
Raz's Avatar
Vermont
Sorry, I don't have an ignore list.
Old 05-14-2013, 05:58 PM   #25
Thomas G.'s Avatar
You are an "internet expert of unknown credential" as far as I know.
Old 05-14-2013, 06:17 PM   #26
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
Article 551.
Old 05-14-2013, 06:18 PM   #27
Oswego, NY
Try Article 551 of the NEC.
Old 05-14-2013, 06:20 PM   #28
Oswego, NY
Probably shouldn't try to post from my phone!
Fuse panel and 12 VDC wiring Eddie Longest Problem Solving | Owners Helping Owners 9 09-08-2012 05:53 PM
Solar Panel Set up Question - Grounding the panel? Anne H Electrical | Charging, Systems, Solar and Generators 2 09-07-2012 04:48 PM
solar panel h.mike Care and Feeding of Molded Fiberglass Trailers 4 07-17-2012 09:01 AM
Wanted: Solar panel Roger Kimble Parts: Buy | Sell | Trade 4 11-05-2011 02:01 PM
solar panel Judith Kennedy Problem Solving | Owners Helping Owners 2 10-29-2009 11:30 AM
