Solar power added to my scamp - Fiberglass RV
Old 03-06-2010, 03:28 PM   #1
Joe N's Avatar
Trailer: none
Wyoming
I just added 135 watts of solar power to my scamp, I could of mounted the panel long ways but did not like the way it stuck out at the front. The morningstar controller was mounted under the front bed for easy access to the wiring and an easy way to the battery.
Joe N is offline   Reply With Quote
Old 03-07-2010, 08:58 AM   #2
GuyB's Avatar
Trailer: 1979 Triple E Surfside
how stable is the panel when towing? looks like the wind could catch it and rip it off
GuyB is offline   Reply With Quote
Old 03-07-2010, 09:29 AM   #3
Joe N's Avatar
Trailer: none
Wyoming
It seems pretty stable, i'll know more when we start uning it shortly. I looked at other installations on motor homes and other travel trailers and they seem to have no problems. It weighs 28 lbs and is mounted with four standrad RV flush panel mounts.
Old 04-29-2010, 09:39 AM   #4
Trailer: Scamp Custom Deluxe 16 ft
I am about to install solar in my 16' Scamp. I've been advised to run the wire down the refer. race. How do I access the race from inside the trailer?
pat gipson is offline   Reply With Quote
Old 04-29-2010, 04:50 PM   #5
Trailer: 2000 Scamp 16 ft Side Dinette Deluxe / 2006 Toyota Tundra
The solar on my Scamp is not mounted so in the summer we can park in the shade and put the panels in the sun and we can reorient them during the day.
D Tharp is offline   Reply With Quote
Old 05-02-2010, 07:01 PM   #6
Bill F.'s Avatar
Trailer: 92 Bigfoot 13.5 ft / 05 Freestar
I used a 115 watt panel with a group 27 battery and found the battery charged to 100% by 10:30 AM most mornings this past winter in Texas. We run LED lights, a 15" LCD TV, AM/FM/CD, 12v water pump, furnace, and once in awhile a 90 watt crock pot for 4 hrs/ day. The crock pot was started by 10 and off by 2(only on sunny days) so the panel could charge the battery before 5 PM. This summer I intend to double the battery capacity so we should be able to survive longer without sun(up to 3 days with the extra battery). A single group 24 battery would suffice if we didn't need the furnace and got some sun each day. With your 135 watt panel and LED lights you should be able to light the entire neighborhood.
Bill
Bill F. is offline   Reply With Quote
Old 05-08-2010, 10:00 PM   #7
Danielle Ash's Avatar
Trailer: 1977 13 ft Scamp
That's a great idea! We've been wanting to do something like that. How much does a 115 watt panel cost - and the price of batteries? Does it have to be a special solar panel (i.e. for RV's, lightweight etc) or can you just look up solar panels and buy one?
Danielle Ash is offline   Reply With Quote
Old 05-09-2010, 04:31 AM   #8
Joe N's Avatar
Trailer: none
Wyoming
I do not know if you can access the refer area from the inside, what I did was go through the roof in the closet area, with an strain relief box connector.
I went down the inside of the closet, then through the floor and to the front of the trailer then came into the front bed area where I mounted the controller and made all my connections.
You can get these at most hardware stores, (I got mine at ace hardware)
Old 05-09-2010, 04:51 AM   #9
Joe N's Avatar
Trailer: none
Wyoming
I got my 135 watt panel from Northern Arizona Wind and Sun The panel ($375), controller($51), and wire 50' with MC4 connectors ($60) came to $532 including shipping.
A group 27 battery deep cycle battery can be had for $80 to $100
This setup gives me enough charge to run lights, furnace, and CPAP machine.
Old 05-10-2010, 09:29 AM   #10
Cool! Thanks!
scamp, solar, solar power
Solar Power Workshop peterh Oregon Gatherings 11 09-02-2010 04:38 PM
Getting started with Solar Power Anne3358 Problem Solving | Owners Helping Owners 7 02-19-2010 11:14 AM
Xantrex power pack with solar panel Daniel V. Modifications, Alterations and Updates 9 03-05-2008 08:26 AM
Residential Solar Power Mary F General Chat 13 10-22-2006 06:09 PM
Solar Power Andrew D Modifications, Alterations and Updates 9 08-20-2006 06:27 PM
