Solar wiring - Page 2 - Fiberglass RV
Old 09-07-2016, 10:27 AM   #15
John Linck's Avatar
Madison, Wisconsin
Originally Posted by John Linck View Post
Conductor size over such short distances makes very little difference at these low amperages. Just use #12 wire and you will be fine. Line losses pale in comparison to poor orientation, shading losses or lack of LED lights.
Got to thinking about my statements above. They apply to most 12 volt circuits in your trailer, but not to a large inverter if you have one. These 1000-3000 watt beasts can really suck the battery amps. Most Scamp circuits do well with 10 amp (or less) fuses. Some large inverters need 100 amps or more. Now we are talking large heavy copper wires and very short runs. Follow the manufacturer's instruction and be careful with online forum arm chair advice.
OTOH if you have a small inverter (<100 watts) for your phone/laptop charging a 10 amp fused circuit is probably enough. Remember, Volts X Amps = Watts so a 100 watt 12 volt inverter will draw as much as 8.5 amps, usually less.
Good camping, john
John Michael Linck - Toymaker
Subaru Outback 4 cyl cvt
John Linck is online now   Reply With Quote
Old 09-08-2016, 11:13 AM   #16
for instance....
and FWIW....my little 150W portable inverter has a built-in fuse inside the plug.... and it specs an 8A.....YMMV
solar
Solar Power Wiring Martin B. Problem Solving | Owners Helping Owners 10 07-21-2015 01:23 PM
Solar Panel Wiring Choices Ken in Philly Modifications, Alterations and Updates 61 05-25-2013 08:17 PM
solar hook up wiring question jimtesla Modifications, Alterations and Updates 3 05-07-2010 02:37 AM
PowerPole connectors for Solar Wiring OK? Pamela S. Problem Solving | Owners Helping Owners 7 01-23-2010 03:10 PM
Wiring Solar Bigfoot Mike Problem Solving | Owners Helping Owners 4 08-16-2009 10:33 AM
