Somewhere over the Rainbow, way up High... - Fiberglass RV
Old 09-27-2009, 01:13 PM   #1
Talking
I have been grousing about Fiber Stream's wimpy frame for a long time. The 1" x 2" box channel frame had a significant sag on the right side, starting at the entry door hinge which is in vertically line with the rearmost mounting bracket for the leaf spring suspension. The out-of-plumb door frame had to be jacked up by the stabilizer jack in order to allow the door to close.
About a month ago I met a welder I felt I could trust with my baby, and (2 weeks?) ago I delivered it to him for the repairs. I uninstalled all of the electric wires and conduits that ran beneath the floor so they would not be damaged.
He put the trailer on jack stands, uninstalled the axles and leaf springs, and cut off the mounting clips for the springs. He then "sistered" two 2" x 2" rails lengthwise to the bottom of the existing for-to-aft rails of the original frame, and installed new mounting clips for the running gear. He then re-installed the springs, axles and wheels.
The trailer already had the spring mounts changed from the factory under-mount to over-mount ("flipping" the axle) which raised the body of the trailer 5". This repair brought the body raise to a total of 7" above the factory stance, and my knees had a lot to say about it. As part of the repair, I also had a double pull-out step and beefier bumper skid wheels installed. I went to his shop yesterday and re-installed all of the electric lines, and brought it home.
Old 09-27-2009, 01:20 PM   #2
Talking
The "sistering" corrected the frame sag, and the trailer's door opens and closes properly! The double step makes entering and exiting the trailer much more comfortable. I was worried that the step would hang too low and drag, especially when backing the trailer over a steel plate bridging the curb (no curb cut) and into my back yard. Not a problem! The closed step clears with several inches to spare!
Old 09-27-2009, 01:23 PM   #3
Talking
View of the added frame rails from under the bumper looking forward.
Old 09-27-2009, 01:31 PM   #4
Talking
While I'm down there, a view of my leaf spring suspension... These are the driver's side wheels, with the picture taken from the curb side of the trailer.
Old 09-27-2009, 01:32 PM   #5
Looks good Frederick I'll be curious to see what you say about towing it at freeway speed for any distance. Like change in MPG, etc. I like my Scamp up higher, I think you'll like you're trailer sitting higher too!
Old 09-27-2009, 02:33 PM   #6
Talking
One thing I had to do when I delivered the trailer to the welder was to empty out the contents, or at least those that aren't in some way fastened down. So for the last 2 weeks the contents of my trailer have been stored in the spare bedroom. When I brought the trailer home, the 1st thing I did was to take it to my office and weigh it using the portable wheel weighers that I used at the Oregon Gathering. While not completely empty, the following conditions exist for my "empty" weight:
  1. All storage empty
  2. Freshwater, Gray and Black Tanks Empty
  3. 1 Full and 1 Half-full Propane Tank onboard
  4. Waterheater NOT drained
  5. 1 Group 27 Battery onboard
  6. 1 13" TV/VCR on ceiling mount onboard
  7. 5000 BTU window air conditioner onboard
  8. small convection/microwave oven onboard
  9. all gaucho/dinette/bed cushions onboard
  10. spare tire onboard
Under the above conditions, my "Light Weight" is as follows:
78 FIBER STREAM 16 "Empty"
Trailer axle 1: Left Wheel=940, Right Wheel=660
Trailer axle 2: Left Wheel=220, Right Wheel=460
TRAILER’S TOTAL AXLE WEIGHT=2280
TRAILER HITCH WEIGHT=220
TOTAL TRAILER WEIGHT=2500
Old 09-27-2009, 06:51 PM   #7
Raya's Avatar
Lookin' good!
You know, I could never visualize "flipping" the axle, but now I think I see it. So "unflipped" the shackes that hold the leaf springs would go the opposite way, right? So the axle would run through inside the "bow" of the springs instead of beneath it?
Thanks for the photos and the weighing details. Interesting how on the one side, one axle is "heavy" and the other one is "light." I suppose there must be something permanently mounted over the "heavy" one?
Very spiffy, and you must feel great having it done, and done competently and tidily.
Old 09-27-2009, 07:35 PM   #8
Lizbeth's Avatar
Trailer: 1979 13 ft Boler and 1987 Bigfoot 5th Wheel
That is just too sexy Fred! I'm so happy it's fixed!
Old 09-27-2009, 07:37 PM   #9
brian m.'s Avatar
Trailer: 17 ft Casita Spirit Deluxe
Looks very solid Frederick! Do you think you need to cover the brake wires somehow to protect them from road debris?
brian
2003 Casita SD 17'
https://www.coolcampcreations.com/
brian m. is offline   Reply With Quote
Old 09-27-2009, 08:12 PM   #10
Talking
So "unflipped" ... the axle would run through inside the "bow" of the springs instead of beneath it?
Yes, you got it right.
Old 09-27-2009, 08:26 PM   #11
Thumbs up
The Water heater (with 50 pounds of water in it) is just forward of the heaviest wheel, and the converter/power center is right over it. I suspect the cantilever effect increases the weight on the front and decreases the weight on the rear?
Old 09-27-2009, 08:29 PM   #12
Talking
I hadn't thought of that; those wires were always exposed in the past. I think that's a good idea.
Old 11-09-2009, 07:15 AM   #13
Trailer: 13 ft Scamp Deluxe 2007 and 40' Allegro Bus
Send a message via AIM to RSchleder Send a message via Yahoo to RSchleder
Looks strong. I must assume your going to paint the bare metal on the "new frame", right?
2007 Scamp 13' deluxe
RSchleder is offline   Reply With Quote
Old 11-09-2009, 09:51 AM   #14
Talking
I was so excited about getting this fix done, I rushed to post pictures... and showed the new part as bare metal.
It is all painted now with "Rust Destroyer" primer. The old frame was very rusty and did not look like it ever had paint on it, so I used this product from Home Depot on the whole thing. So far I like the Red look of the primer.
Old 11-18-2009, 12:48 AM   #15
Trailer: *Percheron
Send a message via Yahoo to Jim Manley
This is 1 awesome trailer I think I'm looking for its sister. Do you have time to chat some time manleyjames62[at]yahoo.com I'm not sure I can find my way back here!
Jim Manley is offline   Reply With Quote
Old 11-18-2009, 08:24 AM   #16
Trailer: 1999 21 ft Bigfoot (2500 series)
Watch out now you can REALLY get out in the middle of no where. Great job Fred...
Alexandra and Mataniu
Alexandra B is offline   Reply With Quote
Old 11-18-2009, 08:47 PM   #17
Arrow
I would need one of those ridiculously high lift kits for the Odyssey, too. It rides like a Mexican Low-Rider in comparison.
Old 11-18-2009, 09:32 PM   #18
Trailer: 1985 13 ft U-Haul
Frederick The modification looks really great. My wife and I have seen your rig at a couple of the gatherings and this is a noticeable improvement. You had mentioned to us that the frame was a weak link so I know you are pleased to have it cured !! If you are like the rest of us ( and I know you are ) that is one more mod down and how many more to go ? Lee
Lee Senn is offline   Reply With Quote
Rainbow Springs State Park - Dunnellon, FL August Trometer Camping, Campout Reports 0 06-17-2010 08:02 AM
The Pot at the End of the Rainbow Frederick L. Simson Jokes, Stories & Tall Tales 1 04-14-2006 09:05 PM
Another New Mexico rainbow Legacy Posts Rallies, Get-togethers, Molded Meets (Archive) 0 10-13-2002 11:50 AM
End of the rainbow Legacy Posts General Chat 1 09-26-2002 06:28 PM
High end uhaul Classified Archives 0 01-01-1970 12:00 AM
