Source for a 110v exterior outlet - Page 2 - Fiberglass RV
Old 10-20-2012, 10:23 AM   #15
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
LOL who would have thought that a question regarding outlets could lead to a Saturday morning sex education class
It is important to learn these things, Carol. Even at the ages of many here.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 10-20-2012, 10:37 AM   #16
No matter your going to have to put a hole (wire or receptical) in the body somewhere. I cut a hole for the box and tapped into the 110 v line inside. Depending on your wire configeration inside you could put your GFI on1 ist item on the same line which would protect all down the line or put it in the outside only. Then a weather tight cover on outside. I placed mine on the rear panewl (door side) also put in a double while your at it, woul'nt regret.
Ron
RRJR is offline   Reply With Quote
Old 10-20-2012, 10:43 AM   #17
Thanks for the clarification Jim I feel better. I believe I got the GFI connected correctly: line (from the panel) and load (to the extra plug). It actually took me a long time to get up the courage to add the connection not due to worry about cutting another hole in the trailer but due to fear of getting the electrical wrong. I have very few electrical appliances and it would be very rare for more than one to be running at the same time so it shouldn't be to hard to figure out which plug/appliance caused the trip should it happened.
Old 10-20-2012, 10:45 AM   #18
Yup agree due to the age factor it is possible that some us may have actually forgot the details.
Old 10-20-2012, 10:46 AM   #19
Trailer: Scamp 16'
Indiana
Thanks for all the great ideas. I'm sorry that I didn't specify that I want a female outlet so that I can bring power out to a crock pot.
Tom
FlyboyTJ is offline   Reply With Quote
Old 10-20-2012, 10:49 AM   #20
cpaharley2008's Avatar
here are some pictures for visceral reasons, female and then male
Old 10-20-2012, 10:54 AM   #21
and finally your GFCI type outlet
Old 10-20-2012, 10:55 AM   #22
I have often wondered, does the odd shaped hole go up or down?
Old 10-20-2012, 10:59 AM   #23
"Then a weather tight cover on outside. I placed mine on the rear panewl (door side) also put in a double while your at it, woul'nt regret."
Ron, in your pictures, your exterior outlet cover maybe better if the hinge was reversed/upside down so that wind driven water can not lift the cover and gain access.
Old 10-20-2012, 11:18 AM   #24
Trailer: 2008 13' Scamp
Carol, yes, as others have said, you're OK the way you've wired your exterior outlet. In the event of a problem the interior GFCI will protect the exterior outlet. Just don't do that at home. In BC exterior GFCIs must be on a completely separate circuit.
Jim, the odd shaped ground hole should be on the bottom. Think of a plug that is starting to pull out and tilt down. With the ground pin on the bottom it's the last pin to disconnect. Much safer than if the ground disconnects while the circuit is still hot.
Ron
Old 10-20-2012, 12:07 PM   #25
Thanks Ron I did know that having had a new exterior plug added to the house not long ago. Its also why I thought I had better double checked with a few more knowledge folks than I prior to doing the trailer after I read in the GFCI instructions that I could put them in line.
Old 10-20-2012, 12:10 PM   #26
Trailer: Escape 19
I'm thinking about Carol's comment "I *believe* I got the GFI connected correctly" (emphasis mine). If I were in that position, I'd test it. Get a 14 gauge wire with two bare ends, and touch it from hot to ground and see if the GFI triggered. But I'm wondering how wise that attitude of mine is... For that reason I won't recommend anybody else do it. But I'll ask: am I being "unwise" (aka "stupid") doing such things?
dbailey is offline   Reply With Quote
Old 10-20-2012, 12:17 PM   #27
honda03842's Avatar
Name: Norm and Ginny
Tom,
In case you haven't considered it, the reason for mounting mine to the bottom of the floor near the bumper is to eliminate another hole thru the fiberglass. In my case the plug is rarely used, a few times a year.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
honda03842 is online now   Reply With Quote
Old 10-20-2012, 12:19 PM   #28
Doug I think you are being wise to double check but I cant comment on how best to - hopefully someone else well.
The reason I said "believe" is mainly due to having done the install a few months ago so from the comfort of my chair I can say I am 99.9% sure its correct based on memory of following the line and load instructions, just dont feel comfortable saying 100% sure without going out to the trailer and taking the outlet cover off to reconfirm it.
exterior access hatch and exterior shower aimeelightsey General Chat 36 10-06-2012 03:15 PM
Need help with exterior 110 power outlet install Carol H Electrical | Charging, Systems, Solar and Generators 25 08-20-2012 12:33 PM
Small 110v Refrigerator Spanke Problem Solving | Owners Helping Owners 9 02-28-2012 07:28 PM
Need source for exterior metal seam on '73 Love Bug Christopher Singer Care and Feeding of Molded Fiberglass Trailers 5 06-02-2009 11:55 AM
110v Dinete Florescent RonnieV Problem Solving | Owners Helping Owners 5 08-28-2006 06:27 PM
