Source for a 110v exterior outlet - Fiberglass RV
Old 10-20-2012, 07:14 AM   #1
Trailer: Scamp 16'
Indiana
Can anyone point me toward a weatherproof 110vac outlet that I can mount in the side of my Scamp. Single outlet, the smaller the better.
Thanks, Tom
FlyboyTJ is offline   Reply With Quote
Old 10-20-2012, 07:27 AM   #2
Like this? Outdoor Receptacle for 110 Volt - PPL Motor Homes
Old 10-20-2012, 07:33 AM   #3
cpaharley2008's Avatar
I think you may need the double outlet because it has to be a GFI outlet and I have not seen a single gang GFI outlet, just double. Both of the above items are male outlets, I thought you wanted a female outlet?
Old 10-20-2012, 08:00 AM   #4
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
You could power the outside outlet off a GFCI elsewhere and have it protected.
I think these are female outlets. of course it has been a long time since my 6th grade sex education class.
Old 10-20-2012, 08:16 AM   #5
the description states for Donna's link says "This Outdoor receptacle 110 is a MALE 15 amp plug and has a weatherproof plate and cover. This outdoor receptacle for 110 volt is to be used with a three-prong, 15 amp female end of an extension cord. 1 per pack."
If you are referring to my post then yes, they are female. It is unclear at present what the op was asking for. If he wants to bring power in, you need a male end, if he wants to let power out, a female end.
Old 10-20-2012, 08:19 AM   #6
honda03842's Avatar
Name: Norm and Ginny
I simply went down to my local Lowes and bought an outside outlet and mounted it to the bottom of floor of the trailer near the rear bumper. I simply drilled a hole through the floor under a dinette and wired it to an existing dinette outlet.
It is a weather proof outlet, a double that looks similar to the PPL outlet that Donna referenced, though less costly. One can chose to put a GFI outlet in it, I did not. My outlet is a dual male outlet.
I mostly use it when I am working on the trailer.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-20-2012, 08:23 AM   #7
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
I too would use a double GFI plug. GFI is code here for outside plugs. Ours mostly get used for our little electrical kettle we bring along for coffee and hot drinks when hooked up to the grid, or for charging stuff when we are sitting around outside.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 10-20-2012, 08:23 AM   #8
Thomas G.'s Avatar
Good point. I was going off OP, which was unclear, but I interpreted it to mean female.
Old 10-20-2012, 08:26 AM   #9
Trailer: Casita 17 ft DLX SD
Gfci
Thanks, Tom
An outside outlet needs to be GFCI protected . You could use a single receptacle protected by a GFCI circuit breaker but the breaker costs about 5 times what a GFCI receptacle costs . A standard single receptacle, duplex receptacle or GFCI receptacle all require the same size opening (single gang) All single gang weatherproof covers are the same dimensions The only size that varies is the size of the receptacle box required based on size and number of wires , type of cable clamps , size & number of devices being installed in the box and whether wires splice or go straight thru the box . Jim is correct a standard GFCI is a duplex receptacle , Square D did make a single GFCI years ago but it had the same dimensions as a duplex GFCI and was not code compliant
Sizes for Electrical devices are pretty standard based on NEC, NEMA and UL standards so small goes second to safety
Old 10-20-2012, 08:34 AM   #10
Thomas G.'s Avatar
Originally Posted by steve dunham View Post
An outside outlet needs to be GFCI protected . You could use a single receptacle protected by a GFCI circuit breaker but the breaker costs about 5 times what a GFCI receptacle costs ........
Alternative:
Old 10-20-2012, 09:55 AM   #11
Jim it is here as well but I was told that if you replace the first plug on the line with a GFI plug (which I did on the one inside my Scamp near the sink) and put the exterior plug in line with it that the exterior one would be protected by the first GFI plug. The paper work that came with the GFI also indicated that. So I taped into the interior GFI plug and just put a water proof box on the exterior plug. Now you have me wondering.......
Old 10-20-2012, 10:10 AM   #12
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
I hope you meant "Female" unless you are using it as a inlet to power the trailer...
Old 10-20-2012, 10:16 AM   #13
LOL who would have thought that a question regarding outlets could lead to a Saturday morning sex education class
Old 10-20-2012, 10:19 AM   #14
Carol, you certainly can do this. Just make certain that you are using the 'load' connections on the GFI plug, and not pigtailing the feed and the load wires. The only problem with this is, that if it trips you may not realize what the problem is at the remote one you installed. This is more prevalent on a house where they do the same thing, and run from one side to the other. Not too much of a problem if you do remember though.
2017 Escape 5.0 TA
exterior access hatch and exterior shower aimeelightsey General Chat 36 10-06-2012 03:15 PM
Need help with exterior 110 power outlet install Carol H Electrical | Charging, Systems, Solar and Generators 25 08-20-2012 12:33 PM
Small 110v Refrigerator Spanke Problem Solving | Owners Helping Owners 9 02-28-2012 07:28 PM
Need source for exterior metal seam on '73 Love Bug Christopher Singer Care and Feeding of Molded Fiberglass Trailers 5 06-02-2009 11:55 AM
110v Dinete Florescent RonnieV Problem Solving | Owners Helping Owners 5 08-28-2006 06:27 PM
