Spare Tire Cover - Matches Tablecloth - Fiberglass RV
Old 08-05-2013, 10:19 PM   #1
Gilda's Avatar
Trailer: 2011 Scamp 13'
[Moderator's note: This thread was split from the Interiors thread.]
Note that the spare tire cover matches the tablecloth. (Yes, I made it out of a second tablecloth!)
The Gleeful Glamper
Gilda (Jill-da)
Old 08-06-2013, 05:52 AM   #2
Trailer: Oliver
Spare Tire Cover
Gilda, did you make your tire cover? We're looking to replace the one that came with our trailer.
Marsha D is offline   Reply With Quote
Old 08-06-2013, 01:48 PM   #3
Name: Steve and Rosemary
Utah
I'm with Marsha -- do you have a pattern or tips on how to make a new tire cover?
SERENITY 1989 Scamp 16' Side Toilet | Steve, Rosemary, Maude Pod & Tripawd Hope | Next trip: The Weber for some fishing
Moab Maiden Voyage 03/10 * The Swell 5/26/11 * Antelope Island 12/31/11 * Strawberry Res 6/12 * Whitney Res 6/14 * Uintahs 07/15 * East Fork of Black's 06/16
Steve and Rosemary is offline   Reply With Quote
Old 08-12-2013, 10:32 PM   #4
Gilda's Avatar
Yes, I made the spare tire cover and it is "sew" easy! I used a waterproof tablecloth for the fabric. (Buy two so you have a matching picnic tablecloth.) Because mine is lightweight it was easy to sew. If you use heavy vinyl it will be much more difficult to sew, but more sturdy. Because I store my trailer outdoors I put on a utilitarian spare tire cover and only use the decorative one when I am on the road.
Instructions: (read all the way through before beginning)
Simply cut a circle with a 25" diameter. (this allows for a 1/2 " seam all around). Cut a strip 8 1/2" deep and 80" long. Purchase about 6' of 1/4" elastic cord used to make thin bungee cords (available by the foot from a hardware store). Note: If you can't cut a strip 80" long simply piece one together ( I used about 3 strips). Optional: Homemade piping 80" long.
1. Pin the right sides together of the circle and strip.
2. Sew the strip to the circle.(Alternatively, you could sew homemade piping in the seam, but this is a lot of work if you don't sew much.)
3. Optional if you did not sew in the piping: Turn the seam allowance toward the strip and topstitch 1/8" away from seam on the strip. This keeps the seam smooth.
4. Fold edge of strip in about 1" and sew 1/4" from edge, forming a channel for the elastic and put the elastic in the casing as you sew. This is the trickiest part as you have to cinch up the casing as you sew.
5. Try on the cover on the tire, tie and cut the excess cord.
6. There you have it a brand new spare tire cover!
The Gleeful Glamper
Gilda (Jill-da)
Old 08-13-2013, 05:15 AM   #5
Trailer: Oliver
Sounds easy enough. Thanks Gilda!
Old 08-13-2013, 11:26 AM   #6
Utah
Thanks Gilda -- I think even I can figure that out!
Spare Tire Cover Tom U Modifications, Alterations and Updates 33 01-01-2015 10:20 AM
Spare tire cover cpaharley2008 Care and Feeding of Molded Fiberglass Trailers 11 10-27-2010 06:26 PM
Spare Tire Cover David and Nancy Modifications, Alterations and Updates 4 05-18-2009 10:07 PM
Spare Tire Cover Terry F Care and Feeding of Molded Fiberglass Trailers 17 09-05-2006 09:11 PM
Spare tire cover General Chat 0 12-31-1969 07:00 PM
