Stainless steel bolts seizing up ... - Fiberglass RV
Old 04-09-2012, 09:49 PM   #1
Trailer: 1978 Trillium 4500
Today I learned (the hard way) that stainless steel bolts are finicky. Handle them like normal bolts and you'll end up quite unhappy.
Stainless Steel Galling / Locking Up / Freezing Up
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
freddo411 is offline   Reply With Quote
Old 04-09-2012, 10:37 PM   #2
Yes like materials will tend to gall when mated. Stainless steel and aluminum are especially susceptible. A drop of blue loctite or some anti-seize compound should kill the likelihood of any problems.
Russ
Old 04-10-2012, 03:54 AM   #3
Raz
Raz's Avatar
Vermont
Good article Fred. It confirms what I've read elsewhere, that slower rpm was a cure. You can't get much slower than hand tightening. And as Russ suggests there is always loctite. Raz
Old 04-10-2012, 10:03 AM   #4
Kenny Strong's Avatar
Trailer: Bigfoot 13'
Utah
thanks for this tip,,,,would not have known.
Kenny Strong is offline   Reply With Quote
Old 04-10-2012, 08:02 PM   #5
Dave Thompson's Avatar
Trailer: Scamp 16 Custom Deluxe
Most any threaded fittings should be greased to prevent seizing/galling.
Trying to cram the rest of my life into the rest of my life!
Dave Thompson is offline   Reply With Quote
Old 04-10-2012, 09:03 PM   #6
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
Yea, I learned that the other day installing a roof rack for my spare tire. Had to hacksaw 2 bolts before I caught on!
Old 06-19-2013, 11:26 PM   #7
Trailer: 81 Dolphin
Use wax door ease (less messy) on your bolts to stop them from seizing and low speed.
Ynotrusty is offline   Reply With Quote
Old 06-20-2013, 08:13 AM   #8
Trailer: castia 16ft
Kansas
Work with as and alum every day. First thing I tell the new guys is always use blue licorice or never seize. You might want to take it apart someday. Remember alum will corrode so always use something on the threads.
dave in kc is offline   Reply With Quote
Old 06-20-2013, 10:06 AM   #9
Trailer: Escape 19
Delaware
Fastest and easiest Anti seize I use is found in the pharmacy lol Phillips Milk Of Magnesia you might not think so but it works even in high heat applications. We used a lot on bolts and screws as structural repair for the Air Force, even our jet engine troops used it on a lot of bolts that had to be removed often.
Cypherian
Cypherian is offline   Reply With Quote
Wanted: stainless steel sink Cheri in MN Parts: Buy | Sell | Trade 12 12-28-2011 08:03 PM
Stainless Steel Tissue Box Frederick L. Simson Modifications, Alterations and Updates 2 06-26-2009 10:57 PM
Stainless Steel Fasteners Steve Dunkel General Chat 2 06-14-2009 06:28 PM
Stainless Steel and Aluminum d_wildemann Problem Solving | Owners Helping Owners 5 08-16-2006 01:33 PM
Stainless steel stove Maggie O. Care and Feeding of Molded Fiberglass Trailers 24 11-19-2005 07:43 PM
