Starting my new woodwork. - Page 4 - Fiberglass RV
Old 07-25-2012, 08:19 AM   #43
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Nice work!
Old 07-25-2012, 08:26 AM   #44
Trailer: 2014 Escape 21
Virginia
Dylan
Everything is really looking great with the woodwork and framing. You could have saved a lot of time if you used the Kreg Jig System for your joints. In most cases you don't need clamps and you don't have to wait for the glue to dry. I'm not connected with Kreg and not trying to tell you how to do your thing just letting you know about other options. Again really great looking woodwork.
Eddie
Eddie Longest is online now   Reply With Quote
Old 07-25-2012, 09:14 AM   #45
dylanear's Avatar
Trailer: 2001 Scamp 13'
Originally Posted by Eddie Longest View Post
Dylan
Eddie
I'll check that out, for the next project! But the clamping has been working well for me. Mostly I don't leave it clamped more than 5 or 10 minutes. The Gorilla wood glue in this climate dries fast. Really easy to work with. I'll be drilling and adding wood screws to reinforce places. But the glueing allows for very precise fitting and feels incredibly strong as it is. Pretty much all the glue joints all have plenty of surface area and often multiple angles that give strength.
dylanear is offline   Reply With Quote
Old 07-25-2012, 09:17 AM   #46
dylanear's Avatar
OK, I took a look. Does seem like a great system if you want to use screws, and they would be faster than my gluing. But I think my glue then screw system is very precise and will be stronger than screwing alone.
Old 07-25-2012, 10:12 AM   #47
GPJ
Trailer: Looking
Actually, most people use glue with the Kreg or other pocket hole systems. Just drill the pocket hole, add glue to the joint, reposition, temporarily clamp to line the pieces up perfectly, drive the pocket screw and unclamp. The screws keep the wood "clamped" while the glue dries, although the glue is just an extra strength option - the screws are usually strong enough on their own - even for chair legs, etc. Plugs are available to hide the screws, although they are usually positioned to be hidden. Some folks like to leave the glue out to allow some joint flexing to occur in applications like boat and RV cabinetry.
Pocket screw systems have really taken over in small woodworking shops - they work well, are fast (ready to use immediately, no leaving items in the clamps overnight) and are so easy to use. Even if you don't use them in your panel shelves and doors, they may be of use elsewhere in face framing, etc. in your other cabinet work in the trailer. There is even a micro jig version for finer work.
I'm sure you have already looked, but the Kreg web site (kregtool.com) has some demo videos under the media center tab that show how easy the system is to use, and projects made with it.
GPJ is offline   Reply With Quote
Old 08-07-2012, 08:24 PM   #48
Trailer: 13 Trillium
Oooooohhh!
Oohs and awwws - Looking great! Can't wait to see the finished beauty!
lhanna is offline   Reply With Quote
Old 08-16-2012, 03:14 PM   #49
dylanear's Avatar
Thanks Laurie, I'm darn eager to see it done myself, getting closer. Here's the last two major pieces.
Front left shelf/seat.
All the woodwork is painted or being painted. Should be installed in the next few days. More pics then.
Old 08-16-2012, 03:17 PM   #50
dylanear's Avatar
I'll have to look at this closer, perhaps find some video of these things being used before my next project (but I don't plan on anything like this again any time soon). My techniques on this worked well, but were just darn slow.
Old 08-16-2012, 08:26 PM   #51
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Great job Dylan, love watching your progress! Creative, you must have an engineer's mind. I knew a boat builder who reminds me of you. Can't wait for more pics of the finished product. Fine, really fine.
So looks like a shower, What will you use for a floor under and drain? Curious.
I Boone Dock and an outside shower has been on my mind as an addition in the future.
D Davis is offline   Reply With Quote
Old 08-17-2012, 12:06 PM   #52
dylanear's Avatar
Thanks! My training is in Art/Design, but I do think I missed my calling as an Engineer/Industrial designer some times. I really wish I had more training in those areas. I'll try to get some pics of the painting in progress, I get a real kick out of seeing them smooth and white even if many pieces are just being primered/prepped.
Yes, There is a shower fixture, but no drain is planned at this point. Almost decided to tackle that, but for now I'll continue using a 10 gallon plastic storage tub which fits under the shelf on the left side when not in use. That's what I did all winter. Works fine, but you do have to lift it and pour it in the sink when your done. Removable shower curtains hang from the ceiling when in use, fit in the tub when not in use. Having that fixture will be very nice as I've been using a shower head hose that went all the way back to a quick release on the kitchen sink faucet, with an on/off valve near the shower. I had to set the temperature at the kitchen sink, then climbing in the shower, hit the on/off valve. Thankfully the Suburban water heater kept a consistent temp and I never needed to adjust the temp while showering, but now I can if need be and i'll skip the sink dance ritual before getting in the shower. The previous set up sounds ridiculous and it sort of was, but actually worked very well and was a lot more comfortable than making my way across a cold campground in my PJs, to use the token based, time limited shower.
The wacky thing is that shower space, will also have a fold up/down table/desk surface as well! Not sure how that's going to be attached/hinged. I'm looking at options. I have an extra shower fixture box that may go on the outside at some point for humid, hot weather showering. Eventually I'll get a drain in the floor, either fiberglass some wood or perhaps modify a utility sink as a shower floor. Probably do that when I add a grey water tank, but not sure how well I can get water from a drain under that front floor past the frame and into the tank in back. Curious how a factory front shower drain is plumbed.
Old 09-03-2012, 08:38 PM   #53
dylanear's Avatar
Figured the final product deserved it's own topic.
Finishing installing my new woodwork!!
Old 09-05-2012, 10:19 AM   #54
Trailer: gave up!!
Bout time!! I was getting tired of waiting to see it....
John_M is offline   Reply With Quote
Old 09-07-2012, 06:53 PM   #55
dylanear's Avatar
Sorry I was failing to keep you entertained!
There was some slow going, and I wasn't take many pictures for a while there.
Just starting to look... Mtnbyker Hi, I am.... 4 08-23-2011 07:39 PM
Starting over with paint highlandsgirl Problem Solving | Owners Helping Owners 1 10-03-2010 11:49 AM
Starting to look at the project Archie J Problem Solving | Owners Helping Owners 28 11-29-2009 09:52 AM
Just Starting Out Roxanne General Chat 3 10-21-2007 02:42 PM
Starting project Legacy Posts Problem Solving | Owners Helping Owners 8 05-22-2003 07:39 AM
