Steps to get into 5th wheel bed - Fiberglass RV
Old 11-18-2013, 06:58 AM   #1
Trailer: Scamp 19ft 5th wheel
Hi: Jerry here.
My wife and I have a 2008 5th wheel Scamp---we love it.
Problem: We are getting older---tougher to get into the front bed. Our Scamp has the full couch just below the front bed----no steps. Have any of you faced this? Is there a portable step or anything that can be built that can help. (The step from the top of the couch into bed is the toughest).
Thanks All: Jerry
Jerry in Colorado is offline   Reply With Quote
Old 11-18-2013, 07:18 AM   #2
No steps needed. Just get about a 6' pole and take a run at the bed Plant the pole into the floor at the front wall and SHAZAAM, your are in the bed....
In lieu of the pole trick, you might consider a small trampoline.
I used to suggest Elevator Shoes, but OSHA put to many requirements on them and the ACME Elevator Shoe Company's stock got stuck in the basement and they had to close.
BTW: This IS NOT indicative of the usual quality of help you will get here.....
Old 11-18-2013, 08:40 AM   #3
Herman M Parker's Avatar
Name: Herman & Ann
Trailer: Scamp 5th Wheel
Pensacola Florida
Step for bed
We have a Scamp 5er my wife is short and has the same problem. I took a small plastic foot stool attached a thin plywood piece under the feet then glued a piece of carpet to the plywood to protect the seat cushin. Works fine for us. Herman
Herman M Parker is online now   Reply With Quote
Old 11-18-2013, 08:56 AM   #4
There are all kinds of steps made for this issue. We have the following that was purchased at Tractor Supply.
Bully® Tailgate Hitch Step - Tractor Supply Co.
Old 11-18-2013, 09:31 AM   #5
Raz
Raz's Avatar
Vermont
You might find a solution here. Raz
Steps/stairs for Scamp 5er
Old 11-18-2013, 01:45 PM   #6
Trailer: Escape Trailers
Massachusetts
store bought stepstool works for us.
Here are some pictures of a Gorilla Ladders 'EasyReach' stepstool purchased from Home Depot that stands on the couch base with the cushion removed. We had turned the bed to run front to back and installed a conventional full-size mattress on a plywood base. The top of the stepstool is attached to the back end of the mattress base, but you could probably come up with another way of securing it.
Stretcher is offline   Reply With Quote
Old 11-19-2013, 06:10 AM   #7
Trailer: 2014 Escape 21
Virginia
I extended the upper deck and added steps on a 5er after knee surgery.
Eddie
Eddie Longest is online now   Reply With Quote
5th Wheel Hitch Installation with a Bed Mat Gail Shook Towing, Hitching, Axles and Running Gear 3 03-29-2008 01:00 PM
5TH WHEEL, TOP BED Karalyn General Chat 7 09-07-2007 08:34 PM
Scamp 5th Wheel Loft Bed peterh Classified Archives 0 05-06-2007 09:55 PM
Like new Scamp 5th Wheel loft Bed Pat And Arleen Classified Archives 0 12-11-2005 01:33 PM
5th Wheel Hitch Installation with a Bed Mat Gail Shook Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
