sticky muck. - Fiberglass RV
Old 07-04-2016, 08:04 PM   #1
Trailer: '79 13' trillium
sticky muck.
Hi folks. I need help. The previous owner of our trillium used a one sided sticky foam built up around the door,as a short term fix. I now have the proper seal for the door. The question: how do I get the stuck on foam off? Is there a product that will cut the sticky part on the door? Thanks.
Ksimdjembe is offline   Reply With Quote
Old 07-04-2016, 08:44 PM   #2
jaye580's Avatar
Trailer: Two 13 ft Scamps
Try OOPS it takes off all sorts of icky goo. It is available at Walmart etc in the paint thinner section.
Owner of 1978 Scamp named the KRAKEN
Owner of 1987 Scamp named ANBOLINN
https://www.facebook.com/Jayes-87-L-...0486405460995/
jaye580 is offline   Reply With Quote
Old 07-04-2016, 09:19 PM   #3
Scrape what you can using a plastic scraper, then use Brakleen on a rag to clean it followed by isopropyl alcohol.
Old 07-05-2016, 03:51 AM   #4
Raz
Raz's Avatar
I've had good luck with Goo Gone, a citrus based adhesive remover. Be patient and give it time to work. I use a plastic scraper that won't gouge the surface and sometimes a hair dryer to soften things up. Raz
Old 07-05-2016, 06:55 AM   #5
Whoa. Lots of items! Thanks. I'll start with goo gone.
Old 07-06-2016, 08:19 AM   #6
The best I have found to remove sticky residue is wd-40. Then you have to wash off the WD-40.
Silicon Muck, FG & Fresh Hands D Davis Problem Solving | Owners Helping Owners 2 03-23-2012 12:46 PM
sticky mod drew l. Modifications, Alterations and Updates 1 11-29-2005 08:18 AM
The Hot Bridgeford Sticky Buns? Shannon and Ross Camp Cooking, Food & Recipes 2 11-20-2005 01:02 AM
