Old 07-17-2012, 09:59 AM   #1
Trailer: 1979 Triple e / 6cyl 09 Escape
Northern Ontario
Stone Guard holding mechanism
The previous owner of my Triple e fashioned a stoneguard out of plywood held together with light aluminium trim. To hold it up in the open position, two short rods are used, with hair clips and washers as the original mechanism is no longer there.
Has anyone fashioned anything to this nature or is there a source where I might locate an original type mechanism. I looked at gas struts, but most of them have too much pressure for such a light guard.
Hope I have explained this correctly. If not, I can take pictures,. Please advise.
Thanks Ed
SurfsideEd is offline   Reply With Quote
Old 07-17-2012, 12:34 PM   #2
Trailer: 77 Scamp 13
Pictures are great idea, helps a lot in finding a solution, plus someone may look at it and decide they want to make one like it.
Old 07-17-2012, 03:52 PM   #3
Trailer: Bigfoot 21
I will be watching this with great interest - my son's Surfside has the same issue and the P.O. did about the same solution.
Old 07-17-2012, 06:20 PM   #4
P. Raz's Avatar
Vermont
McMaster Carr is one of those sites where I can spend hours. Don't know if this is what you have in mind. If not, poke around and you might find what you need.
McMaster-Carr
In Canada Lee Valley might be a good place to look.
Lee Valley Tools
Raz
P. Raz is offline   Reply With Quote
Old 07-23-2012, 08:31 PM   #5
Trailer: 85 Uhaul CT 13
Ordered my struts from McMaster-Carr: look under Hardware, Lid Supports, Gas Springs. I installed the 15 lb. gas springs with ball-joint fittings on my Uhaul rock shield; they fit perfect and work great. Ordered on a Thurs. and arrived the following Tues. Part #4138T541 / $14.47 ea. plus shipping.
George Lauver is offline   Reply With Quote
Old 07-26-2012, 07:43 PM   #6
Northern Ontario
Thanks all, for your replies. I'll look into the gas struts. I like the idea but couldn't find anything lower than 28 lbs and that was way too much. Will see if I can get some 15 pound models. For now, I drilled a hole in each end of the guard, and used a rod with each end of the rod (last inch) bent at 90 degrees with a hole drilled in the end of the bent section, for a pin type keeper. Requires a little more effort than struts but does the job .
Ed
Old 08-23-2012, 06:55 PM   #7
Northern Ontario
I've done a very simple mod to get me through this summer. I would still like to use gas struts and is just a matter of finding a pair with just the right pressure. I've included pictures of my modification which can easily be done in a day and takes 5 minutes or less to open or close the stone guard.
The rods are bent at each end and holes are drilled in the ends for the pins. Holes are also drilled to accommodate the ends of the rods. I screwed little rubber lined keepers on the inside of the guard to hold the rods in place while travelling.
To put the guard down, the lower hair pins are removed, the rods moved out of their holes and lifted up and placed into their respective keepers. Process done in reverse to hold guard open.
No issues over 3000 kilometres. All the gear can be purchased at your nearest NAPA or other hardware/autoparts stores.
Ed
Old 08-24-2012, 05:10 AM   #8
P. Raz's Avatar
Vermont
A simple solution at a very good price I'm sure. Alternate application on the wire tie, very clever. Raz
Old 08-28-2012, 06:47 PM   #9
Northern Ontario
Hi George,
My stone guard is made of very light material. How much force did you have after you installed the two 15 pound gas springs? Was it hard to close the guard? I tried a couple of 28 lb gas springs and they were way way too much, and had to take them back. I'm still interested in doing the gas spring mod though. I would say at best, my stone guard weighs 15 pounds.
Ed
Old 08-28-2012, 08:37 PM   #10
At the bottom of this page is Part #4138T541 / $14.47 ea. plus shipping that George referrenced in post #5 McMaster Carr page 1204 of catalog
Double Yolk
1988 16' Scamp Deluxe
Old 08-29-2012, 05:40 AM   #11
Originally Posted by SurfsideEd View Post
Hi George,
Ed
Ed,
The 15 lb struts work great. I went for the 12.2" length which was longer than my origional; however I like that they lift my guard a little higher for a better view outside.
Old 09-02-2012, 08:32 PM   #12
Northern Ontario
Ed,
George,
Thanks a million. I think they should work fine for my guard as well. Appreciate your time in adding a pic to go with it.
Ed
surfside
Stone Guard added theresa p Modifications, Alterations and Updates 25 09-07-2012 08:06 PM
chip/stone guard theresa p Care and Feeding of Molded Fiberglass Trailers 14 03-29-2012 08:51 PM
Scamp stone guard supports? Nick Glenney Modifications, Alterations and Updates 7 04-20-2009 04:50 AM
Window Stone Guard james kent Problem Solving -- Owners Helping Owners 4 12-19-2006 07:47 AM
Front Window Stone Guard Legacy Posts Problem Solving -- Owners Helping Owners 16 05-11-2003 10:54 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
